path: root/include/config_cmd_default.h
2015-03-25config_cmd_default.h: Add 'env exists' commandSjoerd Simons
env exists allows scripts to query whether an environment variable exists. Enable by default as it adds only a trivial amount of code and can be useful in scripts. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-19config_cmd_default.h: Remove CONFIG_CMD_MEMTESTTom Rini
As per doc/feature-removal-schedule.txt, remove CONFIG_CMD_MEMTEST from default list of commands. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11Feature Removal: disable "mtest" command by defaultWolfgang Denk
The "mtest" command is of little practical use (if any), and experience has shown that a large number of board configurations define useless or even dangerous start and end addresses. If not even the board maintainers are able to figure out which memory range can be reliably tested, how can we expect such from the end users? As this problem comes up repeatedly, we rather do not enable this command by default, so only people who know what they are doing will be confronted with it. As this changes the user interface, we allow for a grace period before this change takes effect. For now, we make "mtest" configurable through the CONFIG_CMD_MEMTEST variable, which is defined in include/config_cmd_default.h; we also add an entry to doc/feature-removal-schedule.txt which announces the removal of this default setting in two releases from now, i. e. with v2013.07. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com>
2009-10-27Add 'editenv' commandPeter Tyser
The editenv command can be used to edit an environment variable. Editing an environment variable is useful when one wants to tweak an existing variable, for example fix a typo or change the baudrate in the 'bootargs' environment variable. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-17include/config_cmd_default.h cleanupPrafulla Wadaskar
arranged configurations in alphabetical order CONFIG_CMD_FLASH moved under ifndef CONFIG_SYS_NO_FLASH Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-18disable imls command if no flash is definedValeriy Glushkov
Default CONFIG_CMD_IMLS must be disabled when CONFIG_SYS_NO_FLASH is defined Signed-off-by: Valeriy Glushkov <gvv@lstec.com>
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-07-04Introduce initial versions of new Command Config files.Jon Loeliger
Derive three new files from cmd_confdefs.h: config_bootp.h - Has BOOTP related config options, not commands config_cmd_all.h - Has a CONFIG_CMD_* definition for every command config_cmd_default.h - Has a CONFIG_CMD_* definition for default cmds. For now, include "config_bootp.h" for compatability until all users of it directly include it properly. Signed-off-by: Jon Loeliger <jdl@freescale.com>
