path: root/include/config_cmd_default.h
2007-07-04include/ non-config: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-07-04Introduce initial versions of new Command Config files.Jon Loeliger
Derive three new files from cmd_confdefs.h: config_bootp.h - Has BOOTP related config options, not commands config_cmd_all.h - Has a CONFIG_CMD_* definition for every command config_cmd_default.h - Has a CONFIG_CMD_* definition for default cmds. For now, include "config_bootp.h" for compatability until all users of it directly include it properly. Signed-off-by: Jon Loeliger <jdl@freescale.com>
