The removed codes are based on prior-redesigned vboot_reference and not
even written for twostop firmware.
BUG=chromium-os:17424
TEST=build cleanly
Change-Id: Ifd869d80b7aa8e11ffe948516733e0f78b170d76
Reviewed-on: http://gerrit.chromium.org/gerrit/3849
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
The command cros_rec is the main procedure the recovery firmware runs by default. It also appears in developer image for debug purpose.
BUG=chromium-os:1305
TEST=build successfully and boot like:
U-Boot 2010.09 (Mar 09 2011 - 17:16:01)
Board: Tegra2 chromeos/tegra2/seaboard/recovery
DRAM: 1 GiB
Using default environment
In: tegra-kbc
Out: serial
Err: serial
Hit any key to stop autoboot: 0
EMMC 1 Probed Successfully
EMMC 1 Probed Successfully[mmc_legacy_init:231] EMMC 1 Probe Failed
USB: Tegra ehci init hccr c5008100 and hcor c5008140 hc_length 64
Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... 1 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
USB EHCI 1.00
DEBUG: TPM: Startup
DEBUG: TPM: command 0x99 returned 0x0
DEBUG: TPM: Self test full
DEBUG: TPM: command 0x50 returned 0x0
ReadSingle Operation failed.
mmc_bread:133 READ : failed
DEBUG: GptNextKernelEntry looking at new prio partition 1
DEBUG: GptNextKernelEntry s1 t15 p15
DEBUG: GptNextKernelEntry looking at new prio partition 3
DEBUG: GptNextKernelEntry s0 t15 p0
DEBUG: GptNextKernelEntry looking at new prio partition 5
DEBUG: GptNextKernelEntry likes that one
DEBUG: Found kernel entry at 4096 size 32768
DEBUG: Checking key block signature...
DEBUG: Kernel preamble is good.
DEBUG: Partition is good.
DEBUG: In recovery mode or dev-signed kernel
DEBUG: Updating GPT header 2
Write failed. Block=8388606
mmc_bwrite:171 WRITE : failed
DEBUG: Updating GPT entries 2
Write failed. Block=8388607
DEBUG: Good_partition >= 0
Success; good kernel found on device
partition_number: 2
bootloader_address: 0x68c000bootloader_size: 0x1000partition_guid: 10 22 57 b6 1a 5f 41 e8 b9 fc 75 a2 7c a9 fa 30
## Booting kernel from Legacy Image at 0040c000 ...
Image Name: kernel
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5807272 Bytes = 5.5 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Change-Id: Iee8c703b934c7d7b7fb244355c8f4399bf3d057e
Review URL: http://codereview.chromium.org/5989010
BUG=chromium-os:1304
TEST=MAKEALL successfully
Review URL: http://codereview.chromium.org/6628008
Change-Id: I71f6ab5afbc8e9c3a569f11c4f2184a1a15c56b1
Because read-only firmware may refer to boot stub and recovery
firmware.
BUG=chromium-os:1302
Review URL: http://codereview.chromium.org/6591037
Change-Id: I40b0b4f458675b1d129fd09dc1ac7504053883c3
This CL is intended for parallelizing development and is not the final
implementation of the boot stub.
Review URL: http://codereview.chromium.org/6048006
Change-Id: I99ddbaae3e07581e9e2a024ba30dab2e2853f74e
BUG=None
TEST=Manual
Test procedure:
1. Compile with VBOOT_DEBUG flag on successfully
2. Run u-boot on dev board as follows:
(Assume you have mmc device on dev board)
CrOS> mmc init
CrOS> cros bootdev set mmc 1
CrOS> cros bootdev
(info of mmc1)
CrOS> read mmc 1 0x20000000 1 2
CrOS> md.b 0x20000000
(mmc1 content)
CrOS> cros bootdev read 0x20001000 1 2
CrOS> md.b 0x20001000
(mmc1 content)
CrOS> cmp.b 0x20000000 0x20001000 0x400
(compare the blocks, should be identical)
Review URL: http://codereview.chromium.org/4001006
Change-Id: I339f9fb63862993f8b9ced80d4c27d6bef0c1bc6
The command "time" takes a command as its argument, executes the command, and reports how much time the command has used.
Example usage:
CrOS> time sleep 1
time: 1.000 seconds, 1000 ticks
CrOS> time sleep 10
time: 10.000 seconds, 10000 ticks
R=robotboy@chromium.org,sjg@chromium.org
BUG=none
TEST=see above
Review URL: http://codereview.chromium.org/6670118
Change-Id: I97cb234c68f29e5db1f5a66abbe32ec6e575b847
Reviewed-on: http://gerrit.chromium.org/gerrit/201
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
Most people don't use the 'rarpboot' command, so only enable it when
CONFIG_CMD_RARP is defined.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
The editenv command can be used to edit an environment variable.
Editing an environment variable is useful when one wants to tweak an
existing variable, for example fix a typo or change the baudrate in the
'bootargs' environment variable.
Mflash is fusion memory device mainly targeted consumer eletronic and
mobile phone.
Internally, it have nand flash and other hardware logics and supports
some different operation (ATA, IO, XIP) modes.
IO mode is custom mode for the host that doesn't have IDE interface.
(Many mobile targeted SoC doesn't have IDE bus)
This driver support mflash IO mode.
Followings are brief descriptions about IO mode.
1. IO mode based on ATA protocol and uses some custom command. (read
confirm, write confirm)
2. IO mode uses SRAM bus interface.
Signed-off-by: unsik Kim <donari75@gmail.com>
According to the doc/feature-removal-schedule.txt, the "autoscr"
command will be replaced by the "source" command in approximately 6
months from now.
This patch prepares this change and starts a 6 month transition
period as follows:
- The new "source" command has been added, which implements exactly
the same functionlaity as the old "autoscr" command before
- The old "autoscr" command name is kept as an alias for compatibility
- Command sequences, script files atc. have been adapted to use the
- Related environment variables ("autoscript", "autoscript_uname")
have *not* been adapted yet; these will be renamed resp. removed in
a separate patch when the support for the "autoscr" command get's
finally dropped.
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
The 'license' command includes the U-Boot license (GPLv2) into the
actual bootloader binary. The license text can be shown interactively
at the U-Boot commandline.
For products where the commandline can actually be accessed by the
end user, this helps to prevent inadvertent GPL violations, since the
GPLv2 license text can no longer be 'forgotten' to be included into
the product.
The 'license' command can be enabled by CONFIG_CMD_LICENSE.
Signed-off-by: Harald Welte <laforge@openmoko.org>
[PATCH] add new 'unzip' command to u-boot commandline
common/cmd_mem.c: new command "unzip srcaddr dstaddr [dstsize]" to unzip from
memory to memory, and option CONFIG_CMD_UNZIP to enable it
Signed-off-by: Werner Almesberger <werner@openmoko.org>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
can print available cores (type: AHB Master, AHB Slave, APB Slave), their address ranges, IRQ number and version.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Add a simple expr style command that will set an env variable as the result
of the command. This allows us to do simple math in shell. The following
operations are supported: &, |, ^, +, -, *, /.
This patch adds a 'cu' like serial terminal command to u-boot
using which you can access other serial ports from the system console.
OpenMoko uses this in their Neo1973 phones to get access to the GSM
Modem and GPS chip from the bootloader.
[PATCH 3/3] OneNAND support (take #2)
OneNAND support at U-Boot
Merge to two at45.c files into a common file, split to at45.c and spi.c
Fix spelling error in DM9161 PHY Support.
Initialize at91rm9200 board (and set LED).
Add PIO control for at91rm9200dk LEDs and Mux.
Change dataflash partition boundaries to be compatible with Linux 2.6.
Signed-off-by: Peter Pearse <peter.pearse@arm.com>
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
Derive three new files from cmd_confdefs.h:
config_bootp.h - Has BOOTP related config options, not commands
config_cmd_all.h - Has a CONFIG_CMD_* definition for every command
config_cmd_default.h - Has a CONFIG_CMD_* definition for default cmds.
For now, include "config_bootp.h" for compatability until all
users of it directly include it properly.
