Read boot reason from SRC(system reset controller) and report
it to kernel by "androidboot.bootreason=<>" kernel commandline.
This is enabled on imx6/7/7ulp/8m, imx8 will report default value
"androidboot.bootreason=reboot" since it can't get such info on
A core at u-boot stage.
Test: Boot reason report ok on imx6qp/imx7ulp/imx8qxp.
Change-Id: I03effaa03bc513bec6153e82c1a04e29c07e7db8
Signed-off-by: Ji Luo <ji.luo@nxp.com>
Porting the FSL android fastboot features from imx u-boot v2017.03 to
support all SoCs: imx6/imx7/imx7ulp/imx8/imx8m
Signed-off-by: Ye Li <ye.li@nxp.com>
Support EPDC.
E-Ink feature is supported by i.MX6DL/SL/SLL/ULL and i.MX7D.
This driver supports user defined logo file, if there is no logo file, it will
draw a black border around a white screen.
If need to enable EPDC, a waveform file is required to let all
work.
Since we need LCD_MONOCHROME mode for EPDC, we introduce LCD_MONOCHROME
support.
Please refer to Linux Reference Manual for how to flash WAVEFORM file.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Signed-off-by: Robby Cai <R63905@freescale.com>
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
(cherry picked from commit a7244f279cc3c3994bcd103f5e9a183b1075ae71)
Adds a VID specific API in init_sequence_f and spl code flow
namely init_func_vid which is required to adjust core voltage.
VID specific code is required in spl, hence moving flag CONFIG_VID
out of spl flags.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Before adding new features, move these definitions to a separate header
to avoid further cluttering common.h.
Building spl with CONFIG_OF_EMBED enabled results in an error message
on my board: "SPL image too big". This is because the fdtgrep build
step is only executed for CONFIG_OF_SEPARATE.
Fix this by moving the fdtgrep build step ('cmd_fdtgreo') from
scripts/Makefile.spl to dts/Makefile so that the reduced dtb is
available for all kinds of spl builds.
The resulting variable name for the embedded device tree blob changes,
too, which is why common.h and fdtdec.c have tiny changes.
Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
When compiling with W=1 the following warning is observed:
arch/arm/mach-imx/mx6/soc.c:590:6: warning: no previous prototype for ‘s_init’ [-Wmissing-prototypes] void s_init(void)
Remove this warning by adding the function prototype into include/common.h file.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Collect runtime BUG/WARN into a self-contained header <linux/bug.h>
to make these macros easier to use.
This macro prevents us from using compiletime_error/assert defined
in <linux/compiler.h>.
Now we can remove it, then we will be able to import more BUILD_BUG
macros from Linux.
When we import code from Linux, with regular re-sync planned, we want
to use printk() and pr_*(). U-Boot does not support them in a clean
way. So, people end up with local macros, or compat headers here and
there, then we occasionally see build errors of definition conflicts.
We have include/linux/compat.h, but putting all sorts of unrelated
things into a single header is just a temporal workaround. Hence this
patch, to find the best home for all printk variants. If you want to
use printk() and friends, please include <linux/printk.h>. This header
is self-contained, and pulls in only a few headers.
When I was testing this clean-up, I noticed the image size exceeded
its platform limit on some boards. This is because all pr_*() that
were previously defined as no-op in include/linux/mtd/mtd.h (unless
CONFIG_MTD_DEBUG is set), are now enabled.
To make such boards happy, this commit also implements CONFIG_LOGLEVEL.
The concept is similar to the kernel parameter "loglevel". (Actually,
the Kconfig help message was taken from kernel-paremeter.txt of Linux)
Messages with a loglevel smaller than console loglevel will be printed.
The difference is the loglevel is build-time determined. To save the
image size, lower priority pr_*() are compiled out. I set the default
of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages
are compiled in.
I adjusted CONFIG_LOGLEVEL to avoid build error for some boards.
[trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL]
<common.h> pulls in a lot of headers. Including it from every .c
file is a bad idea. We need to remove contents until it contains
nothing.
Move printf() and friends to <stdio.h>.
We are now using an env_ prefix for environment functions. Rename these
other functions as well, for consistency:
getenv_vlan()
getenv_bootm_size()
getenv_bootm_low()
getenv_bootm_mapsize()
env_get_default()
Suggested-by: Wolfgang Denk <wd@denx.de>
for consistency. Also add function comments in common.h.
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
commonly used functions, for consistency. Also add function comments in
common.h.
We are now using an env_ prefix for environment functions. Rename setenv()
Use the env_save() function directly now that there is only one
implementation of saveenv().
Reviewed-by: Wolfgang Denk <wd@denx.de>
Make reserve_mmu a weak so that it provides an option
to customize this routine as per platform need
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Runtime U-boot dtb selection is generally a two step process. First step
is to simply use an initial generic dtb. The second step is to select
the dtb and perhaps execute additional code ones U-boot knows what board
it is running on. Embedded_dtb_select handles the second step by allowing
board specific code to run and perform what ever necessary configuration
that is needed.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Add missing static to serial_stub_puts().
Unexport serial_stub_{getc,tstc} because they are used locally.
These are not needed and should not be in common.h. Drop them.
We should not have an arch-specific header file in common.h. Adjust the
board files a little so it is not needed, and drop it.
We should not have an arch-specific header file in common.h. Instead, use
the asm/hardware.h header to provide the required declarations, and drop
the common.h changes.
These declarations should not be in common. Remove those that are not
needed and move the others to an arch-specific location.
These declarations should not be in common.h. Move them to an
arch-specific header.
The declarations should not be in common.h. Move them to the arch-specific
headers.
[trini: Fixup thinko defined(FSL_LSCH3) -> defined(CONFIG_FSL_LSCH3)]
Set up a new asm/ppc.h header file to hold this arch-specific stuff. It
should not be in common.h. It probably should be refactored to use
asm/arch instead, but that is a job for the maintainer.
These definitions should not be in common.h. Move them to an arch-specific
header file.
These arch-specific declarations should not be in common.h. Drop them.
These arch-specific functions are not needed here.
With a small tweak we can avoid including these files for all boards.
With a few tweaks we can avoid including these files, which are only
needed by two C files.
With a small fixup to u-boot-x86.h, this is not actually needed anywhere,
so drop it.
This is not actually needed anywhere, so drop it.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Rather than including this arch-specific header file in common.h, include
it from within nds32's u-boot.h header.
it from within mips's u-boot.h header.
it from within arm's u-boot.h header.
Also drop the comment about something to be fixed. It has been there
forever and it is not clear what it means.
it from within x86's u-boot.h header.
Also drop the comment about something to be fixed. It is not clear what
needs fixing.
it from within sandbox's u-boot.h header.
it from within arc's u-boot.h header.
This is not used anymore. Drop it.
Put this in its own header instead of using common.h.
These should not be in common.h. Move the to an arch-specific header.
Only one board needs this definition. Move it to an arch-specific header.
This should not be in common.h. Drop it.
Only one boards needs this definition. Move it to an arch-specific header.
These should not be in common.h. They are used in some legacy PowerPC
code. Just drop them.
