path: root/include/common.h
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-07-01Make setenv() return statusSteven A. Falco
Currently, the setenv function does not return an error code. This patch allows to test for errors. Signed-off-by: Steve Falco <sfalco@harris.com>
2008-06-28Add ALIGN() macroAndy Fleming
ALIGN() returns the smallest aligned value greater than the passed in address or size. Taken from Linux. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-12Change print_size to take phys_size_tBecky Bruce
2008-06-03Move definition of container_of() to common.hHaavard Skinnemoen
AVR32 and AT91SAM9 both have their own identical definitions of container_of() taken from the Linux kernel. Move it to common.h so that all architectures can use it. container_of() is already used by some drivers, and will be used extensively by the new and improved SPI API. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-04-28MPC8323ERDB: fix implicit declaration of function 'mac_read_from_eeprom'Wolfgang Denk
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24Fix show_boot_progress prototypeJean-Christophe PLAGNIOL-VILLARD
in commit fad634071 "make show_boot_progress () weak." show_boot_progress is supposed to be declared as weak but declared as inline instead. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-2485xx: Round up frequency calculations to get reasonable outputKumar Gala
eg. because of rounding error we can get 799Mhz instead of 800Mhz. Introduced DIV_ROUND_UP and roundup taken from linux kernel. Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-03-2685xx: Update multicore boot mechanism to ePAPR v0.81 specKumar Gala
The following changes are needed to be inline with ePAPR v0.81: * r4, r5 and now always set to 0 on boot release * r7 is used to pass the size of the initial map area (IMA) * EPAPR_MAGIC value changed for book-e processors * changes in the spin table layout * spin table supports a 64-bit physical release address Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Added support for multicore boot mechanismKumar Gala
Added the cpu command that provides a generic mechanism to get status, reset, and release secondary cores in multicore processors. Added support for using the ePAPR defined spin-table mechanism on 85xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-15ppc4xx: Add basic support for AMCC 460EX/460GT (4/5)Stefan Roese
This patch adds basic support for the AMCC 460EX/460GT PPC's. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-12[new uImage] Add new uImage format support to autoscript routineMarian Balakowicz
autoscript() routine is updated to accept second argument, which is only used for FIT images and provides a FIT subimage unit name. autoscript() routine callers must now pass two arguments. For non-interactive use (like in cmd_load.c, cmd_net.c), new environment variable 'autoscript_uname' is introduced and used as a FIT subimage unit name source. autoscript command accepts extended syntax of the addr argument: addr:<subimg_uname> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-21[new uImage] Rename and move print_image_hdr() routineMarian Balakowicz
2008-02-15Fix compile warning on lib_ppc/board.cAnatolij Gustschin
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Mark board_init_[fr] as noreturnMike Frysinger
2008-02-14Remove duplicate defines for ARRAY_SIZEKumar Gala
2008-02-04always pull in asm/blackfin.h for Blackfin portsMike Frysinger
2008-02-04ARM: arm920/s3c24xx: IRQ demulitplexer callbackHarald Welte
This patch adds a IRQ demultiplexer callback to the arm920 cpu core code, plus a stub implementation of it for the S3C2410. The purpose is to allow arm920t implementations such as the s3c24x0 to implement interrupt handlers in u-boot without having to touch core arm920t code. Signed-off-by: Harald Welte <laforge@openmoko.org>
2008-01-12MPC512X: Fixed typo in macro name.Grzegorz Bernacki
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2008-01-09Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-01-09Expose parse_line() globally.James Yang
Add new function readline_into_buffer() that allows the output of readline to be put into a pointer to char buffer. This refactoring allows other functions besides the main command loop to also use the same input mechanism. Signed-off-by: James Yang <James.Yang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-09API for external applications.Rafal Jaworowski
This is an API for external (standalone) applications running on top of U-Boot, and is meant to be more extensible and robust than the existing jumptable mechanism. It is similar to UNIX syscall approach. See api/README for more details. Included is the demo application using this new framework (api_examples). Please note this is still an experimental feature, and is turned off by default. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-01-09Globalize envmatch()Rafal Jaworowski
The newly introduced API (routines related to env vars) will need to call it. Signed-off-by: Rafal Zabdyr <armo@semihalf.com>
2007-12-27Merge branch 'master' of /home/stefan/git/u-boot/u-boot into for-1.3.2-ver2Stefan Roese
2007-12-27Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2007-12-27TQM885D: adjust for doubled flash sector size + some minor fixesMartin Krause
Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-12-11Handle Asynchronous DDR clock on 85xxKumar Gala
The MPC8572 introduces the concept of an asynchronous DDR clock with regards to the platform clock. Introduce get_ddr_freq() to report the DDR freq regardless of sync/async mode. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Merge commit 'u-boot/master' into for-1.3.1Stefan Roese
Conflicts: drivers/rtc/Makefile
2007-11-16ppc4xx: Enable 405EX PCIe UTL register configurationStefan Roese
Till now the UTL registers on 405EX were not initialized but left with their default values. This patch new initializes some of the UTL registers on 405EX. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-15Revert "Correct relocation fixup for mpc5xx"Grant Likely
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for MPC5xxx"Grant Likely
This reverts commit 6f7576b20ecf0d040c3ac3b032b5cbc860e38a90. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc8220"Grant Likely
This reverts commit a85dd254c0577fca13627c46e93fc2ad4c4f1f00. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc824x"Grant Likely
This reverts commit f3a52fe05923935db86985daf9438e2f70ac39aa. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc8260"Grant Likely
This reverts commit 5af61b2f4b838a05f79be274f3e5a66edd2d9c96. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "Correct fixup relocation for mpc83xx"Grant Likely
This reverts commit 057004f4a4863554d56cc56268bfa7c7d9738e27. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-15Revert "[MPC512x] Correct fixup relocation"Grant Likely
This reverts commit 8d17979d0359492a822a0a409d26e3a3549b4cd4. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add PPC405EX supportStefan Roese
2007-09-07[PPC440SPe] Improve PCIe configuration space accessGrzegorz Bernacki
- correct configuration space mapping - correct bus numbering - better access to config space Prior to this patch, the 440SPe host/PCIe bridge was able to configure only the first device on the first bus. We now allow to configure up to 16 buses; also, scanning for devices behind the PCIe-PCIe bridge is supported, so peripheral devices farther in hierarchy can be identified. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-08-29Add mii_init() prototypeWolfgang Denk
to get rid of a *lot* of compiler warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-18Merge with /home/wd/git/u-boot/custodian/u-boot-coldfireWolfgang Denk
