NetLoop polls every cycle with getenv some environment variables.
This is horribly slow, especially when the environment is big.
This patch reads only the environment variables in NetLoop,
when they were changed.
Also moved the init part of the NetLoop function in a seperate
function.
This patch adds flush_/invalidate_dcache_range() to the MIPS architecture.
Those functions are needed for the upcoming dcache support for the USB
EHCI driver. I chose this API because those cache handling functions are
already present in the PPC architecture.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Modifications to support console multiplexing. This is controlled using
CONFIG_SYS_CONSOLE_MUX in the board configuration file.
This allows a user to specify multiple console devices in the environment
with a command like this: setenv stdin serial,nc. As a result, the user can
enter text on both the serial and netconsole interfaces.
All devices - stdin, stdout and stderr - can be set in this manner.
1) common/iomux.c and include/iomux.h contain the environment setting
implementation.
2) doc/README.iomux contains a somewhat more detailed description.
3) The implementation in (1) is called from common/cmd_nvedit.c to
handle setenv and from common/console.c to handle initialization of
input/output devices at boot time.
4) common/console.c also contains the code needed to poll multiple console
devices for input and send output to all devices registered for output.
5) include/common.h includes iomux.h and common/Makefile generates iomux.o
when CONFIG_SYS_CONSOLE_MUX is set.
Signed-off-by: Gary Jennejohn <garyj@denx.de>
There were several, now there is one (two if you count the lower-case
versions).
Signed-off-by: Andy Fleming <afleming@freescale.com>
Round clock frequencies for printing.
Many boards printed off clock frequencies like 399 MHz instead of the
exact 400 MHz because numberes were not rounded. This is fixed now.
missing doc_probe() prototype.
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
ARM, i386, m68k and ppc all have identical implementations of strmhz().
Other architectures don't provide this function at all.
This patch moves strmhz() into lib_generic, reducing code duplication
and providing a more unified API across architectures.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: William Juul <william.juul@tandberg.com>
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
The compiler will help find mismatches between printf formats and
arguments if you let it. This patch adds the necessary attributes to
declarations in include/common.h, then begins to correct the resulting
compiler warnings. Some of these were bugs, e.g., "$d" instead of
"%d" and incorrect arguments. Others were just annoying, like
int-long mismatches on a system where both are 32 bits. It's worth
fixing the annoying errors to catch the real ones.
Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
Currently, the setenv function does not return an error code.
This patch allows to test for errors.
Signed-off-by: Steve Falco <sfalco@harris.com>
ALIGN() returns the smallest aligned value greater than the passed
in address or size. Taken from Linux.
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
AVR32 and AT91SAM9 both have their own identical definitions of
container_of() taken from the Linux kernel. Move it to common.h so
that all architectures can use it.
container_of() is already used by some drivers, and will be used
extensively by the new and improved SPI API.
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93
which is known to break booting from dataflash and NAND.
common/cmd_bootm.c
common/cmd_log.c
include/common.h
post/board/lwmon5/Makefile
post/board/lwmon5/dsp.c
post/board/lwmon5/dspic.c
post/board/lwmon5/fpga.c
post/board/lwmon5/gdc.c
post/board/lwmon5/sysmon.c
post/board/lwmon5/watchdog.c
Implement watchodg-aware variants of hash calculation functions:
- crc32_wd()
- md5_wd()
- sha1_csum_wd()
The above functions calculate the hash of the input buffer in chunks,
triggering the watchdog after processing each chunk. The chunk size
is given as a function call parameter.
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
in commit fad634071 "make show_boot_progress () weak."
show_boot_progress is supposed to be declared as weak but declared as
inline instead.
eg. because of rounding error we can get 799Mhz instead of 800Mhz.
Introduced DIV_ROUND_UP and roundup taken from linux kernel.
Signed-off-by: Dejan Minic <minic@freescale.com>
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
The envcrc.c does sizeof(unsigned long) when calculating the crc, but
this is done with the build toolchain instead of the target tool
chain, so if the build is a 64bit system but the target is 32bits,
the size will obviously be wrong. This converts all unsigned long
stuff related to crc32 to uint32_t types. Compile tested only: output
of ./tools/envcrc when run on a 32bit build system matches that of a
64bit build system.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Introduce the new logical option CONFIG_HAS_POST which is set when the
platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles
to determine should the POST libs be compiled for the selected target
platform, or not.
To avoid breaking u-boot linking process, the empty post/libpost.a file is
created for platforms which do not have POSTs.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
This avoids an early global data reference.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
The following changes are needed to be inline with ePAPR v0.81:
* r4, r5 and now always set to 0 on boot release
* r7 is used to pass the size of the initial map area (IMA)
* EPAPR_MAGIC value changed for book-e processors
* changes in the spin table layout
* spin table supports a 64-bit physical release address
Added the cpu command that provides a generic mechanism to get status,
reset, and release secondary cores in multicore processors.
Added support for using the ePAPR defined spin-table mechanism on 85xx.
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
This patch adds basic support for the AMCC 460EX/460GT PPC's.
autoscript() routine is updated to accept second argument, which
is only used for FIT images and provides a FIT subimage unit name.
autoscript() routine callers must now pass two arguments. For
non-interactive use (like in cmd_load.c, cmd_net.c), new environment
variable 'autoscript_uname' is introduced and used as a FIT
subimage unit name source.
autoscript command accepts extended syntax of the addr argument:
addr:<subimg_uname>
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Makefile
doc/README.standalone
This patch adds a IRQ demultiplexer callback to the arm920 cpu core code,
plus a stub implementation of it for the S3C2410.
The purpose is to allow arm920t implementations such as the s3c24x0 to
implement interrupt handlers in u-boot without having to touch core
arm920t code.
Signed-off-by: Harald Welte <laforge@openmoko.org>
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Add new function readline_into_buffer() that allows the
output of readline to be put into a pointer to char buffer.
This refactoring allows other functions besides the
main command loop to also use the same input mechanism.
Signed-off-by: James Yang <James.Yang@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
This is an API for external (standalone) applications running on top of
U-Boot, and is meant to be more extensible and robust than the existing
jumptable mechanism. It is similar to UNIX syscall approach. See api/README
for more details.
Included is the demo application using this new framework (api_examples).
Please note this is still an experimental feature, and is turned off by
default.
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
The newly introduced API (routines related to env vars) will need to call
it.
Signed-off-by: Rafal Zabdyr <armo@semihalf.com>
Signed-off-by: Martin Krause <martin.krause@tqs.de>
The MPC8572 introduces the concept of an asynchronous DDR clock with
regards to the platform clock.
Introduce get_ddr_freq() to report the DDR freq regardless of sync/async
mode.
drivers/rtc/Makefile
Till now the UTL registers on 405EX were not initialized but left with
their default values. This patch new initializes some of the UTL
registers on 405EX.
This reverts commit 3649cd99ba815b6601868735765602f00ef3692b.
This reverts commit 6f7576b20ecf0d040c3ac3b032b5cbc860e38a90.
