This option delays console initialization until after relocation. This
can save time if this init is relatively expensive, since after
relocation the CPU is often running much faster.
This option should be used in conjunction with CONFIG_PRE_CONSOLE_BUFFER
to ensure that all console output is buffered until the console is
ready for it.
This saves about 30ms boot time.
BUG=chromium-os:22938
TEST=build and boot on Kaen
Change-Id: I3a774b418d45e7be9338f9942df445c2c2baa528
Reviewed-on: https://gerrit.chromium.org/gerrit/13207
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
Commit-Ready: Simon Glass <sjg@chromium.org>
We need something akin to load_addr to handle saving data.
(cherry picked from commit 1aec244acf9daf0d4dad80fe86b2c2b7404251d6)
Change-Id: I56c586abb3e075f0ab422c833637a3160d7e2a5f
Reviewed-on: https://gerrit.chromium.org/gerrit/11800
It seems we put numbers and addresses into environment variables a lot.
We should have some functions to do this.
(cherry picked from commit d67f10c)
Change-Id: I922e72a7db872f26774459a6dc074a80016ef904
Reviewed-on: https://gerrit.chromium.org/gerrit/11792
Reviewed-by: Doug Anderson <dianders@chromium.org>
This function is generally useful and shouldn't hide away in hush. It
has been moved as is.
(cherry picked from commit 3cce8a5496452285e1828984ad3945417205cfc3)
Change-Id: I014f58e901e6b035b5eeb694c62e6e881a7b75c2
Reviewed-on: https://gerrit.chromium.org/gerrit/11791
Change-Id: I1e1cc76214cdb45399cec090677d3164ca2d33eb
Reviewed-on: http://gerrit.chromium.org/gerrit/6065
Reviewed-by: Mike Frysinger <vapier@chromium.org>
Reviewed-by: Anton Staaf <robotboy@chromium.org>
By always emitting the assert code we ensure that constructs passed
to assert will be checked by the compiler. This also ensures that
functions that are only used in asserts aren't flagged as unused
when DEBUG is not defined.
BUG=chromium-os:17999
TEST=Build firmware and boot to ChromiumOS on Aebl, Kaen and Seaboard
Change-Id: Id5f5742622d7041c2cfb7f867742701a087f3e59
Reviewed-on: http://gerrit.chromium.org/gerrit/4666
Tested-by: Anton Staaf <robotboy@chromium.org>
This moves the board name/type code to the top of the board file and removes
the unneeded function prototypes.
BUG=chromium-os:11623
TEST=build and boot
Change-Id: I0f76af84d638d8f45173ca820f00339ce45f0ff7
Reviewed-on: http://gerrit.chromium.org/gerrit/3503
This option delays loading of the environment until later, so that only the
default environment will be available to U-Boot.
BUG=chromium-os:17055
TEST=build U-Boot with option enabled, see that environment is not available
Change-Id: I99a25b468fb5d14310b00eb3fd4c3e6a0c5cbe2b
Reviewed-on: http://gerrit.chromium.org/gerrit/3534
assert() is like BUG_ON() but compiles to nothing unless DEBUG is defined.
This is useful when a condition is an error but a board reset is unlikely
to fix it, so it is better to soldier on in hope. Assertion failures should
be caught during development/test.
It turns out that assert() is defined separately in a few places in U-Boot
with various meanings.
Build errors exposed by this change (and defining DEBUG) are also fixed in
this commit.
TEST=build U-Boot for seaboard
Change-Id: I27500491d2328405694bfd65ab991d42d9641927
Reviewed-on: http://gerrit.chromium.org/gerrit/2777
The board device ID needs to be passed to the kernel for proper
initialization of the machine (until FDT is deployed for that).
The device ID is picked based on the board name in the u-boot
device tree.
BUG=chromium-os:834
TEST=manual
Tested combined with the rest of the patches in this set.
Change-Id: Ifb9395196d13e96d6616ec61ae1e6fc6bd300ab6
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/2773
This is needed for LCD support, where we want to make the LCD frame buffer
write-through (or off) rather than write-back.
BUG=chromium-os:14082
TEST=build U-Boot
Change-Id: I7e1bf9358b8c2fb7ae524cc74cdcfa5b0fb60fbe
Reviewed-on: http://gerrit.chromium.org/gerrit/2239
This defines the basics of a new boot time measurement feature. This allows
logging of very accurate time measurements as the boot proceeds, by using
an available microsecond counter.
To enable the feature, define CONFIG_BOOTSTAGE in your board config file.
Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be
printed just before handing off to the OS.
BUG=chromium-os:13875
TEST=build and boot, check that progress is reported before running Linux:
Timer summary in microseconds:
Mark Elapsed Stage
0 0 awake
2,181,078 2,181,078 usb_start
11,861,817 9,680,739 bootp_start
11,884,610 22,793 bootp_stop
11,884,689 79 tftp start
15,271,536 3,386,847 tftp done
15,271,568 32 bootm_start
15,406,551 134,983 start_kernel
Change-Id: I71b89c8402dc5dec75e68333bd24a6bab7500a1b
Reviewed-on: http://gerrit.chromium.org/gerrit/197
- Add a framework for layered cache maintenance
- separate out SOC specific outer cache maintenance from
maintenance of caches known to CPU
- Add generic ARMv7 cache maintenance operations that affect all
caches known to ARMv7 CPUs. For instance in Cortex-A8 these
opertions will affect both L1 and L2 caches. In Cortex-A9
these will affect only L1 cache
- D-cache operations supported:
- Invalidate entire D-cache
- Invalidate D-cache range
- Flush(clean & invalidate) entire D-cache
- Flush D-cache range
- I-cache operations supported:
- Invalidate entire I-cache
- Add maintenance functions for TLB, branch predictor array etc.
- Enable -march=armv7-a so that armv7 assembly instructions can be
used
Signed-off-by: Aneesh V <aneesh@ti.com>
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
as checkpatch proposes to use strict_strtoul instead of
simple_strtoul, introduce it.
Ported this function from Linux 2.6.38 commit ID:
521cb40b0c44418a4fd36dc633f575813d59a43d
cc: Wolfgang Denk <wd@denx.de>
cc: Detlev Zundel <dzu@denx.de>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
add following functions to common.h, to prevent
extern declarations:
void disable_addr_trans(void);
void enable_addr_trans(void);
void ddr_enable_ecc(unsigned int dram_size);
Acked-by: Kim Phillips <kim.phillips@freescale.com>
cc: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
There is a bug in the min and max macros in common.h which occurs if
Y is a larger type than X. For example, if Y is a 64-bit value and X
is a 32-bit value then Y will be truncated to 32-bits. This fix
matches what is done in the Linux kernel but without the additional
type checking present in the kernel version.
Signed-off-by: Aaron Williams <aaron.williams@caviumnetworks.com>
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq()
and every 86xx board uses get_bus_freq(). If implement get_ddr_freq()
as a static inline to call get_bus_freq() we can remove
fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq()
directly.
For example, an input of 0x80000000 should print:
2147.484 instead of -2147.-483.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Currently, only basic completion is supported (no globs), but this is
what we had previously.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
include/ppc4xx.h
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
Portions of this work were supported by funding from
the CE Linux Forum.
This (undocumented) concept was only in use for the MVSMR and
davinci_schmoogie Sergey Kubushyn <ksi@koi8.net> boards.
Drop it for now. If really needed, it should be reimplemented
later in the context of the new environment command set.
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Cc: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
Code adapted from uClibc-0.9.30.3
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
Change the return type of the *printf() functions to the standard
"int"; no changes are needed but returning the already available
length count.
This will save a few additional strlen() calls later...
Only one file apparently defines this function, and it merely stubs
it out. So if no one is defining/calling it, punt it.
Modify print_size() so that it can accept numbers larger than 4GB on 32-bit
systems.
Add support for display terabyte, petabyte, and exabyte sizes. Change the
output to use International Electrotechnical Commission binary prefix standard.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
Add support for the Cirrus EP93xx platform
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Acked-by: Tom <Tom.Rix@windriver.com>
Added ethernet driver for EP93xx SoCs
Add a disable sub-command to the cpu command that allows for disabling
cores in multicore processors. This can be useful for systems that are
using multicore chips but aren't utilizing all the cores as a way to
reduce power and possibly improve performance.
Also updated an added missing copyright.
- CONFIG_ENV_EEPROM_IS_ON_I2C
define this, if you have I2C and SPI activated, and your
EEPROM, which holds the environment, is on the I2C bus.
- CONFIG_I2C_ENV_EEPROM_BUS
if you have an Environment on an EEPROM reached over
I2C muxes, you can now define, how to reach this
EEPROM.
There are boards out there that do not have network support in
U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This
makes it desirable to be able to port network configuration (like
the IP address) to the Linux kernel.
We should not make the passing of the IP configuration to Linux
dependent on U-Boot features / settings.
For this, make getenv_IPaddr() global. This fixes build error
u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr'
on various architectures.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
According to the PPC reference implementation the udelay() function is
responsible for resetting the watchdog timer as frequently as needed.
Most other architectures do not meet that requirement, so long-running
operations might result in a watchdog reset.
This patch adds a generic udelay() function which takes care of
resetting the watchdog before calling an architecture-specific
__udelay().
Signed-off-by: Ingo van Lil <inguin@gmx.de>
Integrate DA830 EVM support into U-Boot.
Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum
Digital EVM board. See http://www.spectrumdigital.com/
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
This patch adds a unified s3c24x0 cpu header file that selects the header
file for the specific s3c24x0 cpu from the SOC and CPU configs defined in
board config file. This removes the current chain of s3c24-type #ifdef's
from the s3c24x0 code.
Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk>
Breaks building on many boards, and no really clean fix available yet.
This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
The env code is protected by the ENV_IS_EMBEDDED define, so attempting to
compile the code when this isn't defined is pointless. Now that the env
headers have unified around CONFIG_ENV_IS_EMBEDDED, convert the build
system to only build the env objects when this is enabled. And now that
the env code is conditionally compiled, we can drop the source code checks.
For people who want to extract the environment manually, add a new option
CONFIG_BUILD_ENVCRC that only enables the envcrc utility.
