path: root/include/common.h
2016-01-25bug.h: move BUILD_BUG_* defines to include/linux/bug.hMasahiro Yamada
BUILD_BUG_* macros have been defined in several headers. It would be nice to collect them in include/linux/bug.h like Linux. This commit is cherry-picking useful macros from include/linux/bug.h of Linux 4.4. I did not import BUILD_BUG_ON_MSG() because it would not work if it is used with include/common.h in U-Boot. I'd like to postpone it until the root cause (the "error()" macro in include/common.h causes the name conflict with "__attribute__((error()))") is fixed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13Fix board init code to respect the C runtime environmentAlbert ARIBAUD
board_init_f_mem() alters the C runtime environment's stack it is actually already using. This is not a valid behaviour within a C runtime environment. Split board_init_f_mem into C functions which do not alter their own stack and always behave properly with respect to their C runtime environment. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2015-12-01dm: pci: Convert 'pci' command to driver modelSimon Glass
Adjust this command to use the correct PCI functions, instead of the compatibility layer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-21eeprom: Add bus argument to eeprom_init()Marek Vasut
Add bus argument to eeprom_init(), so that it can select the I2C bus number on which the eeprom resides. Any negative value of the $bus argument will preserve the old behavior. This is in place so that old code does not randomly break. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de> [trini: Wrap i2c_set_bus_num() call with CONFIG_SYS_I2C test] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-21eeprom: Zap eeprom_probe()Marek Vasut
Remove this function as it's no longer used. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-10-29armv8/fsl_lsch2: Add fsl_lsch2 SoCMingkai Hu
Freescale LayerScape with Chassis Generation 2 is a set of SoCs with ARMv8 cores and 2rd generation of Chassis. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-29armv8/fsl_lsch3: Change arch to fsl-layerscapeMingkai Hu
There are two LS series processors are built on ARMv8 Layersacpe architecture currently, LS2085A and LS1043A. They are based on ARMv8 core although use different chassis, so create fsl-layerscape to refactor the common code for the LS series processors which also paves the way for adding LS1043A platform. Signed-off-by: Mingkai Hu <Mingkai.Hu@freescale.com> Signed-off-by: Hou Zhiqiang <B48286@freescale.com> Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-11Add support for LZ4 decompression algorithmJulius Werner
This patch adds support for LZ4-compressed FIT image contents. This algorithm has a slightly worse compression ration than LZO while being nearly twice as fast to decompress. When loading images from a fast storage medium this usually results in a boot time win. Sandbox-tested only since I don't have a U-Boot development system set up right now. The code was imported unchanged from coreboot where it's proven to work, though. I'm mostly interested in getting this recognized by mkImage for use in a downstream project. Signed-off-by: Julius Werner <jwerner@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-11Move ALLOC_CACHE_ALIGN_BUFFER() to the new memalign.h headerSimon Glass
Now that we have a new header file for cache-aligned allocation, we should move the stack-based allocation macro there also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11Move malloc_cache_aligned() to its own headerSimon Glass
At present malloc.h is included everywhere since it recently was added to common.h in this commit: 4519668 mtd/nand/ubi: assortment of alignment fixes This seems wasteful and unnecessary. We have been trying to trim down common.h and put separate functions into separate header files and that change goes in the opposite direction. Move malloc_cache_aligned() to a new header so that this can be avoided. The header would perhaps be better named as alignmem.h but it needs to be included after common.h and people might be confused by this. With the name memalign.h it fits nicely after malloc() in most cases. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-08-28mtd/nand/ubi: assortment of alignment fixesMarcel Ziswiler
Various U-Boot adoptions/extensions to MTD/NAND/UBI did not take buffer alignment into account which led to failures of the following form: ERROR: v7_dcache_inval_range - start address is not aligned - 0x1f7f0108 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x1f7f1108 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Scott Wood <scottwood@freescale.com> [trini: Add __UBOOT__ hunk to lib/zlib/zutil.c due to malloc.h in common.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-14Allow arch-specific setting of global_data in board_init_f_mem()Simon Glass
At present we have a simple assignment to gd. With some archs this is implemented as a register or through some other means; a simple assignment does not suit in all cases. Change this to a function and add documentation to describe how this all works. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-12spl, common, serial: build SPL without serial supportHeiko Schocher
This patch enables building SPL without CONFIG_SPL_SERIAL_SUPPORT support. Signed-off-by: Heiko Schocher <hs@denx.de> [trini: Ensure we build arch/arm/imx-common on mx28] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-21Add a way of checking the position of a structure memberSimon Glass
U-Boot uses structures for hardware access so it is important that these structures are correct. Add a way of asserting that a structure member is at a particular offset. This can be created using the datasheet for the hardware. This implementation uses Static_assert() since BUILD_BUG_ON() only works within functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10arm: Allow cleanup_before_linux() without disabling cachesSimon Glass
This function is used before jumping to U-Boot, but in that case we don't always want to disable caches. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
2015-05-28meminfo cmd: Enable printing >=4GiB SDRAM sizesAndrew Bradford
gd->ram_size is stored as phys_size_t type which can be bigger than an unsigned long on some architectures. When using unsigned long type, SDRAM of 4GiB or larger will not print the correct size, but using phys_size_t will. Signed-off-by: Andrew Bradford <andrew.bradford@kodakalaris.com>
2015-04-29Move display_options functions to their own headerSimon Glass
Before adding one more function, create a separate header to help reduce the size of common.h. Add the missing function comments and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-22gunzip: add gzwrite routine for extracting compresed images to block deviceEric Nelson
Initial filesystem images are generally highly compressible. Add a routine gzwrite that allows gzip-compressed images to be written to block devices. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Reviewed-by: Tom Rini <trini@ti.com>
2015-04-20powerpc/mpc85xx: Remove some dead codeScott Wood
U-Boot does not have system calls (the services it exposes to standalone commands use a different mechanism), so the syscall handler is dead code. It's also broken code, as it assumes it is located at 0xc00 -- while even before the patch to stop relocating exception vectors to 0, U-Boot had the syscall at 0x900. The critical and machine check return paths are never called -- the regular exception return path is used instead, which works because xSRR0/1 have already been saved and can be restored via the regular SRR0/1 (we don't care too much in U-Boot about taking a critical/mcheck inside another exception prolog/epilog). Also remove a few other small unused functions. Signed-off-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18common: Make sure arch-specific map_sysmem() is definedJoe Hershberger
In the case where the arch defines a custom map_sysmem(), make sure that including just mapmem.h is sufficient to have these functions as they are when the arch does not override it. Also split the non-arch specific functions out of common.h Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-16dm: Add a new CPU init function which can use driver modelSimon Glass
Since driver model is set up after arch_cpu_init(), that function cannot use drivers. Add a new arch_cpu_init_dm() function which is called immediately after driver model is ready, and can reference devices. This can be used to probe essential devices for the CPU. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-04powerpc/mpc85xx: Add DSP side awareness for Freescale Heterogeneous SoCsShaveta Leekha
The code provides framework for heterogeneous multicore chips based on StarCore and Power Architecture which are chasis-2 compliant, like B4860 and B4420 It will make u-boot recognize all non-ppc cores and peripherals like SC3900/DSP CPUs, MAPLE, CPRI and print their configuration in u-boot logs. Example boot logs of B4860QDS: U-Boot 2015.01-00232-geef6e36-dirty (Jan 19 2015 - 11:58:45) CPU0: B4860E, Version: 2.2, (0x86880022) Core: e6500, Version: 2.0, (0x80400120) Clock Configuration: CPU0:1600 MHz, CPU1:1600 MHz, CPU2:1600 MHz, CPU3:1600 MHz, DSP CPU0:1200 MHz, DSP CPU1:1200 MHz, DSP CPU2:1200 MHz, DSP CPU3:1200 MHz, DSP CPU4:1200 MHz, DSP CPU5:1200 MHz, CCB:666.667 MHz, DDR:933.333 MHz (1866.667 MT/s data rate) (Asynchronous), IFC:166.667 MHz CPRI:600 MHz MAPLE:600 MHz, MAPLE-ULB:800 MHz, MAPLE-eTVPE:1000 MHz FMAN1: 666.667 MHz QMAN: 333.333 MHz Top level changes include: (1) Top level CONFIG to identify HETEROGENUOUS clusters (2) CONFIGS for SC3900/DSP components (3) Global structures like "cpu_type" and "MPC85xx_SYS_INFO" updated for dsp cores and other components (3) APIs to get DSP num cores and their Mask like: cpu_dsp_mask, cpu_num_dspcores etc same as that of PowerPC (5) Code to fetch and print SC cores and other heterogenous device's frequencies (6) README added for the same Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-17common/board_f: factor out reserve_stacksAndreas Bießmann
Introduce arch_reserve_stacks() to tailor gd->start_addr_sp and gd->irq_sp to the architecture needs. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-09common: Move dram_init() declaration to common locationMichal Simek
Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-29generic-board: show model name in board_init_f() tooMasahiro Yamada
The common/board_r.c has show_model_r() to display the model name if the DTB has a "model" property. It sounds useful to have a similar function in common/board_f.c too because most of the boards show their board name before relocation. Instead of implementing the same function in both common/board_f.c and common/board_r.c, let's split it up into common/show_board_info.c. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-16powerpc: 74xx_7xx: remove 74xx_7xx cpu supportMasahiro Yamada
All the 74xx_7xx boards are still non-generic boards: P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2 Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <yorksun@freescale.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2015-01-05mpc8xx: remove lwmon board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-12-15ARM: remove redundant asmlinkage defineMasahiro Yamada
Use asmlinkage defined in include/linux/linkage.h if necessary. Actually no ARM board uses asmlinkage, so this commit has no impact. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-12-15x86: move arch-specific asmlinkage to <asm/linkage.h>Masahiro Yamada
Commit 65dd74a674d6 (x86: ivybridge: Implement SDRAM init) introduced x86-specific asmlinkage into arch/x86/include/asm/config.h. Commit ed0a2fbf14f7 (x86: Add a definition of asmlinkage) added the same macro define again, this time, into include/common.h. (Please do not add arch-specific stuff to include/common.h any more; it is already too cluttered.) The generic asmlinkage is defined in <linux/linkage.h>. If you want to override it with an arch-specific one, the best way is to add it to <asm/linkage.h> like Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08powerpc: mpc8xx: remove hermes board supportMasahiro Yamada
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board. It has not been converted to generic board yet and mpc8xx is old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-11-25x86: Add a definition of asmlinkageSimon Glass
This is needed to permit calling C from assembler without too much pain. Add a definition for x86. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23Add pr_fmt() macroThierry Reding
This macro can be overridden in source files (before including common.h) and can be used to specify a prefix for debug and error messages. An example of how to use this is shown below: #define pr_fmt(fmt) "foo: " fmt #include <common.h> ... debug("bar"); The resulting message will read: foo: bar Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-20linux/kernel.h: add typechecking to roundup macroMasahiro Yamada
This commit replaces roundup macro with the one from Linux Kernel. DEFINE_ALIGN_BUFFER must be fixed because typechecking can not be used in this context. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20include: move various macros to include/linux/kernel.hMasahiro Yamada
U-Boot has imported various utility macros from Linux scattering them to various places without consistency. In include/common.h are min, max, min3, max3, ARRAY_SIZE, ALIGN, container_of, DIV_ROUND_UP, etc. In include/linux/compat.h are min_t, max_t, round_up, round_down, etc. We also have duplicated defines of min_t in some *.c files. Moreover, we are suffering from too cluttered include/common.h. This commit moves various macros that originate in include/linux/kernel.h of Linux to their original position. Note: This commit simply moves the macros; the macros roundup, min, max, min2, max3, ARRAY_SIZE are different from those of Linux at this point. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-20include/common.h: remove DIV_ROUND definitionMasahiro Yamada
All the references of DIV_ROUND have been replaced with DIV_ROUND_CLOSEST. Remove DIV_ROUND. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-27Tidy up data sizes and function comment in display_optionsSimon Glass
Use inttypes.h and uint64_t to correct the code so that it will not issue warnings on 64-bit machines where 'uint64_t' is 'unsigned long'. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27Use uint64_t for time typesSimon Glass
Unfortunately 'unsigned long long' and 'uint64_t' are not necessarily compatible on 64-bit machines. Use the correct typedef instead of writing the supposed type out in full. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27Add some standard headers external code might needGabe Black
inttypes.h defines format specifiers for printf which work with data types of particular sizes. stdlib.h is currently just a passthrough to malloc.h which has declarations of the various *alloc functions. Add the required #define to common.h so that these printf format specifiers will be made available. Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-by: Gabe Black <gabeblack@chromium.org> Tested-by: Gabe Black <gabeblack@chromium.org> Reviewed-by: Bill Richardson <wfrichar@google.com> Signed-off-by: Simon Glass <sjg@chromium.org> (Replaced with a GPL version from glibc)
2014-10-27ppc: Zap Hymod boardMarek Vasut
Remove this board as this is the only one last user of eeprom_probe(), which is pretty non-standard stuff. This patch also removes all the PHP, SQL and CSS stuff from U-Boot, which probably makes U-Boot a bit less IoT ;-) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2014-10-23serial: add static directive to local functionsMasahiro Yamada
The functions _serial_putc, _serial_putc_raw, _serial_puts, _serial_getc, _serial_tstc, _serial_setbrg are defined and used locally in each of serial_ns16550.c and serial_s3c24x0.c. Add static directive to them and remove declarations from include/common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-09-24common.h: remove MIN, MAX, MIN3, MAX3 macrosMasahiro Yamada
Now MIN, MAX, MIN3, MAX are not used. Going forward, use min, max, min3, max3. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-05arm:reset: call the reset_misc() before the cpu resetPrzemyslaw Marczak
On an Odroid U3 board, the SOC is unable to reset the eMMC card in the DWMMC mode by the cpu software reset. Manual reset of the card by switching proper gpio pin - fixes this issue. Such solution needs to add a call to pre reset function. This is done by the reset_misc() function, which is called before reset_cpu(). The function reset_misc() is a weak function. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Changes v4: - arch/arm/reset: fix weak function attribute to proper style Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-21powerpc: mpc8xx: remove stxxtc board supportMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-28ARM: convert arch_fixup_memory_node to a generic FDT fixup functionMa Haijun
Some architecture needs extra device tree setup. Instead of adding yet another hook, convert arch_fixup_memory_node to be a generic FDT fixup function. [maz: collapsed 3 patches into one, rewrote commit message] Signed-off-by: Ma Haijun <mahaijuns@gmail.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove RPXlite_dw, quantum board supportMasahiro Yamada
