This fixes some remaining checkpatch.pl warnings.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Add several levels of DEBUG prints so that you can limit the noise to
the severety of your problem.
DEBUG_LL_STATE = Link local state machine changes
DEBUG_DEV_PKT = Packets or info directed to the device
DEBUG_NET_PKT = Packets on info on the network at large
DEBUG_INT_STATE = Internal network state changes
* 'master' of git://git.denx.de/u-boot-net:
net: move bootfile init into eth_initialize
net: punt bd->bi_ip_addr
net: cosmetic: netconsole.c checkpatch compliance
net: cosmetic: tftp.* checkpatch compliance
net: cosmetic: sntp.* checkpatch compliance
net: cosmetic: rarp.* checkpatch compliance
net: cosmetic: nfs.* checkpatch compliance
net: cosmetic: net.c checkpatch compliance
net: cosmetic: eth.c checkpatch compliance
net: cosmetic: bootp.* checkpatch compliance
net: cosmetic: net.h checkpatch compliance
net: Remove volatile from net API
This macro is generally useful to make it available in common.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Acked-by: Tom Rini <trini@ti.com>
The standalone example does not have get_timer() defined, so we cannot
rely on it being available.
Move the timer function into boootstage.c to avoid this problem.
This corrects a build breakage for the standalone example on some boards.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This reverts commit 295d3942b806552503243f5cfb36aec6f1b5a9bf.
It turns that this really doesn't work very nicely. Instead we should
have a pre-console panic function so that we know that further execution
is impossible and we don't need to worry about trampling on UARTs, etc.
Define timer_get_boot_us() which returns the number of microseconds
since boot. If undefined then we use get_timer() * 1000.
We can fit this in a 32-bit register which keeps everyone happy on
the efficiency side. It will wrap around after about an hour. If we
are still looking at it after an hour then we had better not be
timing the boot.
At present boot_stage_progress() is called with various magic numbers. The
new bootstage.h header will be used to turn these into symbolic names
throughout the code.
The intent is not that these numbers are passed to Linux. In fact by using
an enum to track them we should eventually be able to remove the explict
numbers and just have the stages count up from 0.
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
This is a more sensible name, so rename it.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
It really isn't clear why this is here and there is no comment, so
drop it.
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Tom Rini <trini@ti.com>
add possibility to add a timeout when reading a line
into a buffer.
Cc: Mike Frysinger <vapier@gentoo.org>
This reverts commit 914c9ee971924665c9d2927fe83d8d70060b1eb8
which is causing tons of build warnings like
start.S:39:0: warning: "_LINUX_CONFIG_H" redefined [enabled by
default]
/home/wd/git/u-boot/work/include/common.h:28:0: note: this is the
location of the previous definition
/work/wd/tmp-ppc/nand_spl/board/freescale/mpc8315erdb/start.S:39:0:
warning: "_LINUX_CONFIG_H" redefined [enabled by default]
etc.
Several boolean defines have a value assigned.
Remove the value as defining the symbol is enough.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
common.h is very large, so before changing the vsprintf functions, move the
prototypes into their own header file.
This patch adds support for console output before the console is inited.
The main purpose of this is to deal with a very early panic() which would
otherwise cause a silent hang.
A new board_pre_console_putc() function is added to the board API. If
provided by the board it will be called in the event of console output
before the console is ready. This function should turn on all UARTs and
spray the character out if it possibly can.
The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option.
Acked-by: Graeme Russ <graeme.russ@gmail.com>
Extract all extern declarations for console_buffer[] out of c files into
the common.h header.
Cc: Frank Gottschling <fgottschling@eltec.de>
Cc: Murray Jensen <Murray.Jensen@csiro.au>
The current implementation of debug doesn't play well with GCC4.6.
This implementation also fixes GCC4.6 complaints about unused variables
while maintaining code size.
Also, drop the debugX() as that's not used anywhere anymore.
This new option allows U-Boot to embed a binary device tree into its image
to allow run-time control of peripherals. This device tree is for U-Boot's
own use and is not necessarily the same one as is passed to the kernel.
The device tree compiler output should be placed in the $(obj)
rooted tree. Since $(OBJCOPY) insists on adding the path to the
generated symbol names, to ensure consistency it should be
invoked from the directory where the .dtb file is located and
given the input file name without the path.
This commit contains my entry for the ugliest Makefile / shell interaction
competition.
We need something akin to load_addr to handle saving data.
It seems we put numbers and addresses into environment variables a lot.
We should have some functions to do this.
This function is generally useful and shouldn't hide away in hush. It
has been moved as is.
This macro is used to allocate cache line size aligned stack
buffers for use with DMA hardware.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Aneesh V <aneesh@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
This is not an uncommon operation in U-Boot, so let's put it in a common
function.
ARCH_DMA_MINALIGN will be used to allocate DMA buffers that are
aligned correctly. In all current cases this means that the DMA
buffer will be aligned to at least the L1 data cache line size of
the configured architecture. If the board configuration file
does not specify the architecture L1 data cache line size then the
maximum line size of the architecture is used to align DMA buffers.
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Laurence Withers <lwithers@guralp.com>
There are several mdelay() definitions in the driver and
board code. Remove them all and provide a common mdelay()
in lib/time.c.
Add NDS32 support into common header file.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
This adds required header files for the sandbox architecture, and a basic
description of what sandbox is (README.sandbox).
Add pxe command, which is intended to mimic PXELINUX functionality.
'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP
address. 'pxe boot' interprets the contents of PXELINUX config like file
to boot using a specific initrd, kernel and kernel command line.
This patch also adds a README.pxe file - see it for more details on the
pxe command.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
No code defines or calls this, so drop the prototype.
This is needed for the patch "cache: add default setting for
CONFIG_SYS_CACHELINE_SIZE" from Anton Staaf. As cache.h defines
CONFIG_SYS_CACHELINE_SIZE for PPC targets.
This will remove the following warnings/errors:
include/common.h:819:2: warning: #warning CONFIG_SYS_CACHELINE_SIZE not defined, using __BIGGEST_ALIGNMENT__
cache.c:33: error: '__BIGGEST_ALIGNMENT__' undeclared (first use in this function)
Cc: Anton Staaf <robotboy@chromium.org>
Unified DDR driver is maintained for better performance, robustness and bug
fixes. Upgrading to use unified DDR driver for MPC83xx takes advantage of
overall improvement. It requires changes for board files to customize
platform-dependent parameters.
To utilize the unified DDR driver, a board needs to define CONFIG_FSL_DDRx
in the header file. No more boards will be accepted without such definition.
Note: the workaround for erratum DDR6 for the very old MPC834x Rev 1.0/1.1
and MPC8360 Rev 1.1/1.2 parts is not migrated to unified driver.
Signed-off-by: York Sun <yorksun@freescale.com>
Some SOCs have discontiguously-numbered cores, and so we can't determine the
valid core numbers via the FRR register any more. We define
CPU_TYPE_ENTRY_MASK to specify a discontiguous core mask, and helper functions
to process the mask and enumerate over the set of valid cores.
assert() is like BUG_ON() but compiles to nothing unless DEBUG is defined.
This is useful when a condition is an error but a board reset is unlikely
to fix it, so it is better to soldier on in hope. Assertion failures should
be caught during development/test.
It turns out that assert() is defined separately in a few places in U-Boot
with various meanings. This patch cleans up some of these.
Build errors exposed by this change (and defining DEBUG) are also fixed in
this patch.
Currently when you call ROUND with a value that is already a
multiple of the second parameter it will return a value that is
one multiple larger, instead of returning the value passed in.
There are only two types of usage of ROUND currently, one in
various config files to round CONFIG_SYS_MALLOC_LEN to a multiple
of 4096 bytes. The other in cmd_sf.c where the incorrect behavior
of ROUND is worked around be subtracting one from the length argument
before passing it to ROUND.
This patch fixes ROUND and removes the workaround from cmd_sf. It
also results in all of the malloc pools that use ROUND to compute
their size shrinking by 4KB.
c2dd0d45540397704de9b13287417d21049d34c6 added dcache_enable()
to board_init_r(). This enables d-cache for all ARM boards.
As a result some of the arm boards that are not cache-ready
are broken. Revert this change and allow platform code to
take the decision on d-cache enabling.
Also add some documentation for cache usage in ARM.
Signed-off-by: Aneesh V <aneesh@ti.com>
Clean up some duplicated prototype declarations.
Get rid of now useless AVR32 initcalls.h file.
Cc: Albert Aribaud <albert.aribaud@free.fr>
Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Cc: Graeme Russ <graeme.russ@gmail.com>
This is needed to get rid of build warnings like
main.c:311: warning: passing argument 2 of 'setenv' discards qualifiers from pointer target type
which result from commit 09c2e90 "unify version_string".
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
see discussion also here:
http://patchwork.ozlabs.org/patch/75309/
cc: Wolfgang Denk <wd@denx.de>
cc: Holger Brunck <holger.brunck@keymile.com>
Since panic() never returns, we should add an appropriate attribute to
let gcc improve optimization around it.
For people who want to manually extract the embedded environment so that
it can be manually packed into the final u-boot image, add a config opt
to force building of the envcrc tool.
Checkpatch.pl complains about the volatile qualifier in calls to
get_ram_size(). Remove this qualifier in the prototype and in the
calls where it is useless, and leave it only in the function body
where it is needed.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
- Add a framework for layered cache maintenance
- separate out SOC specific outer cache maintenance from
maintenance of caches known to CPU
- Add generic ARMv7 cache maintenance operations that affect all
caches known to ARMv7 CPUs. For instance in Cortex-A8 these
opertions will affect both L1 and L2 caches. In Cortex-A9
these will affect only L1 cache
- D-cache operations supported:
- Invalidate entire D-cache
- Invalidate D-cache range
- Flush(clean & invalidate) entire D-cache
- Flush D-cache range
- I-cache operations supported:
- Invalidate entire I-cache
- Add maintenance functions for TLB, branch predictor array etc.
- Enable -march=armv7-a so that armv7 assembly instructions can be
used
The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
