path: root/include/command.h
2019-06-14cmd: define CMD_DATA_SIZE when CONFIG_CMD_SETEXPR is selectedBartosz Golaszewski
The setexpr shell command calls cmd_get_data_size() which is only built when CMD_DATA_SIZE is defined. We need to define CMD_DATA_SIZE if CONFIG_CMD_SETEXPR is selected or the build will fail if no other command selecting this option is enabled. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
2019-03-22cmd: set CONFIG_SYS_HELP_CMD_WIDTH = 10Heinrich Schuchardt
CONFIG_SYS_HELP_CMD_WIDTH is used to format the output of help without any arguments. CONFIG_SYS_HELP_CMD_WIDTH = 8 is too narrow to fit all our commands. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-02-25cmd: env: add "-e" option for handling UEFI variablesAKASHI Takahiro
"env [print|set] -e" allows for handling uefi variables without knowing details about mapping to corresponding u-boot variables. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-01-15command: commands: Add macros to declare commands with subcmdsBoris Brezillon
Most cmd/xxx.c source files expose several commands through a single entry point. Some of them are doing the sub-command parsing manually in their do_<cmd>() function, others are declaring a table of sub-commands and then use find_cmd_tbl() to delegate the request to the sub command handler. In either case, the amount of code to do that is not negligible and repetitive, not to mention that almost no commands are implementing the auto-completion hook, which means most u-boot commands lack auto-completion. Provide several macros to easily define commands exposing sub-commands. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-15common: command: Rework the 'cmd is repeatable' logicBoris Brezillon
The repeatable property is currently attached to the main command and sub-commands have no way to change the repeatable value (the ->repeatable field in sub-command entries is ignored). Replace the ->repeatable field by an extended ->cmd() hook (called ->cmd_rep()) which takes a new int pointer to store the repeatable cap of the command being executed. With this trick, we can let sub-commands decide whether they are repeatable or not. We also patch mmc and dtimg who are testing the ->repeatable field directly (they now use cmd_is_repeatable() instead), and fix the help entry manually since it doesn't use the U_BOOT_CMD() macro. Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-01-15common: command: Expose a generic helper to auto-complete sub commandsBoris Brezillon
Some commands have a table of sub-commands. With minor adjustments, complete_cmdv() is able to provide auto-completion for sub-commands (it's just about passing the table of commands instead of taking the global one). We rename this function into complete_subcmd() and implement complete_cmdv() as a wrapper around complete_subcmdv(). Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-10-19common: command: fix typoHeinrich Schuchardt
%s/CMD_RET_SUCCESX/CMD_RET_SUCCESS/g Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-07-19common: command: Handle USAGE failure separatelyMichal Simek
command_ret_t enum contains 3 return values but only two are handled now. Extend cmd_process_error() and handle CMD_RET_USAGE separately. These commands are affected by this change. cmd/demo.c cmd/efi.c cmd/gpio.c cmd/qfw.c cmd/x86/fsp.c test/dm/cmd_dm.c And scripts shouldn't be affected because return value is not 0. But every command implementation can choose what it is correct to pass. I would expect that RET_USAGE is called when parameters are not correctly passed (have incorrect value, missing parameters) and RET_FAILURE when correct parameters are passed but command fails. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromum.org>
2018-03-23arm64: zynqmp: Add support to load an app at EL1Nitin Jain
This patch is adding support to switch to EL1 while loading an EL1 application with u-boot running at EL above EL1 in aarch64 mode. Signed-off-by: Nitin Jain <nitinj@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-08-11Kconfig: Drop CONFIG_CMD_PORTIO and associated commandSimon Glass
This command is not used by any board. It also looks quite similar to the 'iod' and 'iow' commands which use the correct I/O macros. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2016-04-01Drop command-processing code when CONFIG_CMDLINE is disabledSimon Glass
Command parsing and processing code is not needed when the command line is disabled. Remove this code in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-22Allow command code to compile to nothingSimon Glass
When CONFIG_CMDLINE is disabled we need to remove all the command-line code. Most can be removed by dropping the appropriate linker lists from the images, but sub-commands must be dealt with specially. A simple mechanism is used to avoid 'unused static function' errors. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-13cmd_boot: Add a poweroff commandMichael van Slingerland
Add a 'poweroff' command to boot commands, this only gets enabled if the board Kconfig does a "select CMD_POWEROFF". Signed-off-by: Michael van Slingerland <michael@deviousops.nl> [hdegoede@redhat.com: Make the cmd conditional on a CMD_POWEROFF Kconfig] Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-07CONFIG_NEEDS_MANUAL_RELOC: Fix warnings when not setTom Rini
Now that we may compile (but not link) code calling fixup_cmdtable when this is not set, we need to always have the declaration available. We should also make sure that anyone calling the function includes <command.h> as that's where the function declaration is. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-07-27pxe: add AArch64 image supportStephen Warren
The sysboot and pxe commands currently support either U-Boot formats or raw zImages. Add support for the AArch64 Linux port's native image format too. As with zImage support, there is no auto-detection of the native image format. Rather, if the image is auto-detected as a U-Boot format, U-Boot will try to interpret it as such. Otherwise, U-Boot will fall back to a raw/native image format, if one is enabled. My belief is that CONFIG_CMD_BOOTZ won't ever be enabled for any AArch64 port, hence there's never a need to differentiate between CONFIG_CMD_ _BOOTI and _BOOTZ at run-time; compile-time will do. Even if this isn't true, we want to prefer _BOOTI over _BOOTZ when defined, since _BOOTI is definitely the native format for AArch64. Change-Id: I83c5cc7566032afd72516de46f4e5eb7a780284a Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-10-27cli: hush: Adjust 'run' command to run each line of the env varSimon Glass
The run command treats each argument an an environment variable. It gets the value of each variable and executes it as a command. If an environment variable contains a newline and the hush cli is used, it is supposed to execute each line one after the other. Normally a newline signals to hush to exit - this is used in normal command line entry - after a command is entered we want to return to allow the user to enter the next one. But environment variables obviously need to execute to completion. Add a special case for the execution of environment variables which continues when a newline is seen, and add a few tests to check this behaviour. Note: it's not impossible that this may cause regressions in other areas. I can't think of a case but with any change of behaviour with limited test coverage there is always a risk. From what I can tell this behaviour has been around since at least U-Boot 2011.03, although this pre-dates sandbox and I have not tested it on real hardware. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-19Avoid including config.h in command.hSimon Glass
This is not necessary and prevents using this header when building tools. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04Add cmd_process_error() to report and process errorsSimon Glass
U-Boot now uses errors defined in include/errno.h which are negative integers. Commands which fail need to report the error and return 1 to indicate failure. Add this functionality in cmd_process_error(). For now this merely reports the error number. It would be possible also to produce a helpful error message by storing the error strings in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-24bootz: un-staticize do_bootzRob Herring
Make do_bootz available for other functions like do_bootm is. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-02-04cmd_time: merge run_command_and_time_it with cmd_processRichard Genoud
As far as every arch has a get_timer function, run_command_and_time_it code can now disappear. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-By: Che-Liang Chiou <clchiou@chromium.org> [trini: s/ulong/unsigned long/ in command.h portion] Signed-off-by: Tom Rini <trini@ti.com>
2012-12-11Add console command to access io space registersVadim Bendebury
Provide u-boot console functions to access IO space registers. A no thrills implementation, accessing one register at a time. For example: boot > iod 80 0080: 00000094 boot > iod.w 80 0080: 0094 boot > iod.b 80 0080: 94 boot > iow.b 0x80 12 boot > iod 0x80 0080: 00000012 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-09-25combine block device load commands into common functionRob Herring
All the raw block load commands duplicate the same code. Starting with the ide version as it has progress updates convert ide, usb, and scsi boot commands to all use a common version. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-06Add cmd_process() to process commands in one placeSimon Glass
We currently have the same code in hush.c and main.c. This brings the code into one place. As an added feature, if the command function returns CMD_RET_USAGE then cmd_process() will print a usage message for the command before returning the standard failure code of 1. ARM code size increases about 32 bytes with this clean-up. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-06Create a single cmd_call() function to handle command executionSimon Glass
We should aim for a single point of entry to the commands, whichever parser is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-22env: clean cmd_nvedit.c checkpatch and code styleIgor Grinberg
Cleanup the cmd_nvedit.c checkpatch warnings, errors and coding style. There are 10 wanrings left about the simple_strtoul() function: WARNING: simple_strtoul is obsolete, use kstrtoul instead #359: FILE: cmd_nvedit.c:359: + load_addr = simple_strtoul(argv[2], NULL, 16); ... total: 0 errors, 10 warnings, 1043 lines checked Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-10-17sandbox: Force command sections to be 4-byte alignedSimon Glass
By default sections are 16-byte aligned on some architectures, but the command name structure (struct cmd_tbl_s) does not have padding to 16 bytes. This reduces the alignment to 4-bytes so that the command table can be accessed correctly on any architecture. (Note: this needs doing properly) Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-26cmd_usage: constifyMike Frysinger
The usage helper doesn't modify the command, so constify its input arg. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28autocomplete: remove runtime handler installMike Frysinger
Rather than add runtime overhead of installing completion handlers, do it statically at build time. This requires a new build time helper macro to declare a command and the completion handler at the same time. Then we convert the env related funcs over to this. This gives an opportunity to also unify the U_BOOT_CMD macros. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootd: unify duplicate prototypesMike Frysinger
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28command_t: punt unused typeMike Frysinger
The recent command clean up to constify the argv option to command funcs missed the command_t type itself. This is probably because there are no build time warnings from it because no one is actually using this thing. So just punt it rather than fix it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-06-12Make "usage" messages more helpful.Wolfgang Denk
In case of incorrect command invocations U-Boot used to print pretty useless "usage" messages, for example: => nand markbad Usage: nand - NAND sub-system In the result, the user would have to run the "help" command to get the (available) information about correct command usage. Change this, so that this information gets always printed. Note that this changes the user interface of all commands, but hopefully to the better. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27command.c: Expose the core of do_help as _do_help to the rest of u-boot.Detlev Zundel
Other commands implementing subcommands can reuse this code nicely. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-18Expose command table search for sub-commandsKumar Gala
Sub-command can benefit from using the same table and search functions that top level commands have. Expose this functionality by refactoring find_cmd() and introducing find_cmd_tbl() that sub-command processing can call. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-06Fix merge problemsStefan Roese
