path: root/include/command.h
2011-11-22env: clean cmd_nvedit.c checkpatch and code styleIgor Grinberg
Cleanup the cmd_nvedit.c checkpatch warnings, errors and coding style. There are 10 wanrings left about the simple_strtoul() function: WARNING: simple_strtoul is obsolete, use kstrtoul instead #359: FILE: cmd_nvedit.c:359: + load_addr = simple_strtoul(argv[2], NULL, 16); ... total: 0 errors, 10 warnings, 1043 lines checked Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-10-17sandbox: Force command sections to be 4-byte alignedSimon Glass
By default sections are 16-byte aligned on some architectures, but the command name structure (struct cmd_tbl_s) does not have padding to 16 bytes. This reduces the alignment to 4-bytes so that the command table can be accessed correctly on any architecture. (Note: this needs doing properly) Signed-off-by: Simon Glass <sjg@chromium.org>
2011-07-26cmd_usage: constifyMike Frysinger
The usage helper doesn't modify the command, so constify its input arg. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-25autostart: unify duplicated logic into the bootm codeMike Frysinger
Rather than having a bunch of random commands handle autostart behavior, unify the logic in a single place. This also fixes building of these different commands when bootm is disabled. Acked-by: Matthew McClintock <msm@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28autocomplete: remove runtime handler installMike Frysinger
Rather than add runtime overhead of installing completion handlers, do it statically at build time. This requires a new build time helper macro to declare a command and the completion handler at the same time. Then we convert the env related funcs over to this. This gives an opportunity to also unify the U_BOOT_CMD macros. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_bootd: unify duplicate prototypesMike Frysinger
2010-11-28do_bootm: unify duplicate prototypesMike Frysinger
The duplication of the do_bootm prototype has gotten out of hand, and they're pretty much all outdated (wrt constness). Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28command_t: punt unused typeMike Frysinger
The recent command clean up to constify the argv option to command funcs missed the command_t type itself. This is probably because there are no build time warnings from it because no one is actually using this thing. So just punt it rather than fix it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-06-12Make "usage" messages more helpful.Wolfgang Denk
In case of incorrect command invocations U-Boot used to print pretty useless "usage" messages, for example: => nand markbad Usage: nand - NAND sub-system In the result, the user would have to run the "help" command to get the (available) information about correct command usage. Change this, so that this information gets always printed. Note that this changes the user interface of all commands, but hopefully to the better. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27command.c: Expose the core of do_help as _do_help to the rest of u-boot.Detlev Zundel
Other commands implementing subcommands can reuse this code nicely. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-10-18Expose command table search for sub-commandsKumar Gala
Sub-command can benefit from using the same table and search functions that top level commands have. Expose this functionality by refactoring find_cmd() and introducing find_cmd_tbl() that sub-command processing can call. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-10move cmd_get_data_size to command.cJean-Christophe PLAGNIOL-VILLARD
add CMD_DATA_SIZE macro to enable it Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-06Fix merge problemsStefan Roese
2007-07-08Remove references to the old cmd_confdefs.h include file.Jon Loeliger
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
