path: root/include/command.h
2008-07-30Add include for config.h in command.h.Stefano Babic
Because the cmd_tbl_s structure depends on the configuration file, it must be assured that config.h is included before the structure is evaluated by the compiler. If this is not certain, it could happen that the compiler generates structures of different size, depending on the fact if the source file includes <config.h> before or after <command.h>. The effect is that u-boot crashes when tries to relocate the command table (for ppc) or try to access to the command table for other architectures. The problem can happen on board-depending commands. All general commands under /common are unaffected, because they include already config.h before command.h. Signed-off-by: Stefano Babic <sbabic@denx.de>
2007-07-08Remove references to the old cmd_confdefs.h include file.Jon Loeliger
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2002-08-27Initial revisionwdenk
