path: root/include/cbfs.h
2019-11-02cbfs: do not pack struct cbfs_cachenodeHeinrich Schuchardt
With the __packed attribute sandbox_defconfig cannot be compiled with GCC 9.2.1: fs/cbfs/cbfs.c: In function ‘file_cbfs_fill_cache’: fs/cbfs/cbfs.c:164:16: error: taking address of packed member of ‘struct cbfs_cachenode’ may result in an unaligned pointer value [-Werror=address-of-packed-member] 164 | cache_tail = &new_node->next; | ^~~~~~~~~~~~~~~ struct cbfs_cachenode is only an internal structure. So let's rearrange the fields such that the structure is naturally packed and remove the __packed attribute. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-08-18cbfs: Add functions to support multiple CBFSsSimon Glass
Sometimes an image has multiple CBFS. The current CBFS API is limited to handling only one at time. Also it keeps track of the CBFS internally in BSS, which does not work before relocation, for example. Add a few new functions to overcome these limitations. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-08-18cbfs: Move result variable into the structSimon Glass
Move the result variable into the struct also, so that it can be used when BSS is not available. Add a function to read it. Note that all functions sill use the BSS version of the data. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2019-07-23cbfs: Rename checksum to attributes_offsetSimon Glass
It seems that this field has been renamed in later version of coreboot. Update it. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-23cbfs: Add an enum and comment for the magic numberSimon Glass
This field is not commented in the original file. Add a comment. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-31fs: cbfs: Add missing standard CBFS component typesBin Meng
Current CBFS component type list is incomplete. Add missing ones. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-31fs: cbfs: Make all CBFS_TYPE_xxx macros consistentBin Meng
At present there are 2 macros that are named as CBFS_COMPONENT_xxx. Change them to CBFS_TYPE_xxx for consistency. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2012-12-06cbfs: Add docbook templateSimon Glass
This adds a docbook template for fs, and makes CBFS use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-06cbfs: Remove mention of CREDITS filesSimon Glass
As requested by Wolfgang, remove references to CREDITS in the CBFS files. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22fs: Add a Coreboot Filesystem (CBFS) driver and commandsGabe Black
This change adds CBFS support and some commands to use it to u-boot. These commands are: cbfsinit - Initialize CBFS support and pull all metadata into RAM. The end of the ROM is an optional parameter which defaults to the standard 0xffffffff and can be used to support multiple CBFSes in a system. The last one set up with cbfsinit is the one that will be used. cbfsinfo - Print information from the CBFS header. cbfsls - Print out the size, type, and name of all the files in the current CBFS. Recognized types are translated into symbolic names. cbfsload - Load a file from CBFS into memory. Like the similar command for fat filesystems, you can optionally provide a maximum size. Support for CBFS is compiled in when the CONFIG_CMD_CBFS option is specified. The CBFS driver can also be used programmatically from within u-boot. If u-boot needs something out of CBFS very early before the heap is configured, it won't be able to use the normal CBFS support which caches some information in memory it allocates from the heap. The cbfs_file_find_uncached function searches a CBFS instance without touching the heap. Signed-off-by: Gabe Black <gabeblack@google.com> Signed-off-by: Stefan Reinauer <reinauer@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
