path: root/include/bzlib.h
2016-01-20bzip2: Support compression for sandboxSimon Glass
Add the missing code to allow bzip2 compression to be used. This is useful for sandbox tests. These files are taken from the bzip2 1.0.6 release. The license text is copied to the top of each file as is done with other bzip2 files in U-Boot. The only other change is to squash a compiler warning with nBytes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2003-08-29Patch by Yuli Barcohen, 14 Aug 2003:wdenk
add support for bzip2 uncompression
