path: root/include/bootm.h
2015-01-14bootm: Export bootm_decomp_image()Simon Glass
Export this function for testing. Also add a parameter so that values other than CONFIG_SYS_BOOTM_LEN can be used for the maximum uncompressed size. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-25bootm: add prototype for arch_preboot_osJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-30cmd_bootm.c: Add 'booti' for ARM64 Linux kernel ImagesTom Rini
The default format for arm64 Linux kernels is the "Image" format, described in Documentation/arm64/booting.txt. This, along with an optional gzip compression on top is all that is generated by default. The Image format has a magic number within the header for verification, a text_offset where the Image must be run from, an image_size that includes the BSS and reserved fields. This does not support automatic detection of a gzip compressed image. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-19Enhance fit_check_sign to check all imagesSimon Glass
At present this tool only checks the configuration signing. Have it also look at each of the images in the configuration and confirm that they verify. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> (v1)
2014-06-19bootm: Split out code from cmd_bootm.cSimon Glass
This file has code in three different categories: - Command processing - OS-specific boot code - Locating images and setting up to boot Only the first category really belongs in a file called cmd_bootm.c. Leave the command processing code where it is. Split out the OS-specific boot code into bootm_os.c. Split out the other code into bootm.c Header files and extern declarations are tidied but otherwise no code changes are made, to make it easier to review. Signed-off-by: Simon Glass <sjg@chromium.org>
