path: root/include/bootm.h
2019-07-29common: Move bootm_decomp_image() to image.c (as image_decomp())Julius Werner
Upcoming patches want to add decompression to use cases that are no longer directly related to booting. It makes sense to retain a single decompression routine, but it should no longer be in bootm.c (which is not compiled for all configurations). This patch moves bootm_decomp_image() to image.c and renames it to image_decomp() in preparation of those upcoming patches. Signed-off-by: Julius Werner <jwerner@chromium.org> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fix warning around handle_decomp_error being unused] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-09Make FIT support really optionalFabrice Fontaine
Due to some mistakes in the source code, it was not possible to really turn FIT support off. This commit fixes the problem by means of the following changes: - Enclose "bootm_host_load_image" and "bootm_host_load_images" between checks for CONFIG_FIT_SIGNATURE, in common/bootm.c. - Enclose the declaration of "bootm_host_load_images" between checks for CONFIG_FIT_SIGNATURE, in common/bootm.h. - Condition the compilation and linking of fit_common.o fit_image.o image-host.o common/image-fit.o to CONFIG_FIT=y, in tools/Makefile. Signed-off-by: Carlos Santos <casantos@datacom.ind.br> [fabio: adapt for 2016.07] Signed-off-by: Fabio Estevam <festevam@gmail.com> [Ricardo: fix conditional compilation and linking of the files mentioned above for 2016.07] Signed-off-by: Ricardo Martincoski <ricardo.martincoski@gmail.com> [Jörg: adapt for 2019.01] Signed-off-by: Jörg Krause <joerg.krause@embedded.rocks> [Retrieved from: https://git.buildroot.net/buildroot/tree/package/uboot-tools/0003-Make-FIT-support-really-optional.patch] Signed-off-by: Fabrice Fontaine <fontaine.fabrice@gmail.com>
2019-02-13efi_loader: refactor switch to non-secure modeHeinrich Schuchardt
Refactor the switch from supervisor to hypervisor to a new function called at the beginning of do_bootefi(). Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-12-31bootm: vxworks: Make do_bootm_vxworks() non-staticBin Meng
For future extension to other architectures, make do_bootm_vxworks() a non-static function. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-06-03Add a comment for board_quiesce_devices()Simon Glass
This exported function should have a comment describing what it does. Also it should really be removed in favour of device_remove(), which handles this sort of thing now. Add a comment with a TODO. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-06-03Define board_quiesce_devices() in a shared locationSimon Glass
This undocumented function relies on arch-specific code to declare a nop weak version. Add the weak function in common code instead to avoid having to duplicate the same function in each arch. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2015-05-28Combine bootm_find_<thing> functions togetherKarl Apsite
bootm_find_ramdisk_fdt() renamed to bootm_find_images() for readability. The function bootm_find_ramdisk_fdt() appears to be a simple wrapper for bootm_find_ramdisk(), bootm_find_fdt(), and now bootm_find_loadables(). I didn't see any other callers entering a bootm_find<thing>, so removing the wrapper, and condensing these together hopefully makes the code a little simpler. Signed-off-by: Karl Apsite <Karl.Apsite@dornerworks.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-01-14bootm: Export bootm_decomp_image()Simon Glass
Export this function for testing. Also add a parameter so that values other than CONFIG_SYS_BOOTM_LEN can be used for the maximum uncompressed size. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-25bootm: add prototype for arch_preboot_osJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-08-30cmd_bootm.c: Add 'booti' for ARM64 Linux kernel ImagesTom Rini
The default format for arm64 Linux kernels is the "Image" format, described in Documentation/arm64/booting.txt. This, along with an optional gzip compression on top is all that is generated by default. The Image format has a magic number within the header for verification, a text_offset where the Image must be run from, an image_size that includes the BSS and reserved fields. This does not support automatic detection of a gzip compressed image. Signed-off-by: Tom Rini <trini@ti.com>
2014-06-19Enhance fit_check_sign to check all imagesSimon Glass
At present this tool only checks the configuration signing. Have it also look at each of the images in the configuration and confirm that they verify. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de> (v1)
2014-06-19bootm: Split out code from cmd_bootm.cSimon Glass
This file has code in three different categories: - Command processing - OS-specific boot code - Locating images and setting up to boot Only the first category really belongs in a file called cmd_bootm.c. Leave the command processing code where it is. Split out the OS-specific boot code into bootm_os.c. Split out the other code into bootm.c Header files and extern declarations are tidied but otherwise no code changes are made, to make it easier to review. Signed-off-by: Simon Glass <sjg@chromium.org>
