path: root/include/bootcount.h
2021-02-02common: Drop asm/global_data.h from common headerSimon Glass
Move this out of the common header and include it only where needed. In a number of cases this requires adding "struct udevice;" to avoid adding another large header or in other cases replacing / adding missing header files that had been pulled in, very indirectly. Finally, we have a few cases where we did not need to include <asm/global_data.h> at all, so remove that include. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2021-01-27bootcount: allow to use this feature on TPLPhilippe Reynes
This commit add an option TPL_BOOTCOUNT_LIMIT to use bootcount on TPL. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-02common: Move bootcount functions to their header fileSimon Glass
These don't need to be in common.h so move them out. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-12-02spl: bootcount: Move code out of header fileSimon Glass
It is not good practice to write code in a header file. If it is included multiple times then the code can cause duplicate functions. Move the bootcount_store() and bootcount_load() functions into SPL. Note: bootcount is a bit strange in that it uses driver model but does not define proper drivers. This should be fixed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set_ulong() to env.hSimon Glass
Move env_set_ulong() over to the new header file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-12-10bootcount: add uclass for bootcountPhilipp Tomsich
The original bootcount methods do not provide an interface to DM and rely on a static configuration for I2C devices (e.g. bus, chip-addr, etc. are configured through defines statically). On a modern system that exposes multiple devices in a DTS-configurable way, this is less than optimal and a interface to DM-based devices will be desirable. This adds a simple driver that is DM-aware and configurable via DTS. If ambiguous (i.e. multiple bootcount-devices are present) the /chosen/u-boot,bootcount-device property can be used to select one bootcount device. Initially, this provides support for the following DM devices: * RTC devices Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
2018-05-10bootcount: Add function wrappers to handle bootcount increment and error ↵Lukasz Majewski
checking Those two functions can be used to provide easy bootcount management. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefan Roese <sr@denx.de>
2018-05-10bootcount: Add include guards into bootcount.h fileLukasz Majewski
This patch adds missing include guards for bootcount.h file. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
