Subordinate regulator drivers can use this enumerated ID instead of
matching the compatible string again.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Samuel Holland <samuel@sholland.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
A single DM-based driver should be able to support some feature for
several PMIC variants where the interface is the same. For example,
all PMIC variants use the same register bit to trigger poweroff.
However, currently only definitions for a single PMIC are available at
a time. This requires drivers to use #ifdefs and different indentifiers
for each variant they support.
Let's simplify this by making register definitions for all variants
available from the header. Then no preprocessor conditions are needed;
the driver can use the register definition from any variant that
supports the relevant feature.
An exception is the GPIO-related definitions, which do not use unique
identifiers. So for now, keep them like before. They will be cleaned up
along with the GPIO driver.
This header attempted to avoid multiple inclusion using a header guard.
But the preprocessor symbol was never defined, so the guard had no
effect. Fix this by defining the symbol.
This bus controller is used to communicate with an X-Powers AXP PMIC.
Currently, various drivers access PMIC registers through a platform-
specific non-DM "pmic_bus" interface, which depends on the legacy I2C
framework. In order to convert those drivers to use DM_PMIC, this bus
needs a DM_I2C driver.
Refactor the rsb functions to take the base address as a parameter,
and implement both the existing interface (which is still needed in
SPL) and the DM_I2C interface on top of them.
The register for switching between I2C/P2WI/RSB mode is the same across
all PMIC variants, so move that to the common header.
There are only a couple of pairs of hardware/runtime addresses used
across all PMIC variants. So far the code expected only the "primary"
pair, but some PMICs like the AXP305 and AXP805 use the secondary pair,
so add support for that to the DM driver as well.
Refactor the p2wi functions to take the base address as a parameter,
all PMIC variants. Move that to the common header, so it can be used by
both interface implementations.
This PMIC can be found on H616 boards and it's very similar to AXP805
and AXP806.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
The A80 uses the AXP809 as its primary PMIC.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The AXP818 has a switchable output, SW. This is commonly used for
controlling power to the LCD backlight.
The FLDOs on AXP818 PMIC normally provide power to CPUS and USB HSIC PHY
on the A83T/H8.
Instead of one function for each DLDO regulator, make 1 function that
takes an extra "index". Since the control bits for the DLDO regulators
are contiguous, this makes the function very simple. This removes a lot
of duplicate code.
Acked-by: Hans de Goede <hdegoede@redhat.com>
AXP818 is rsb based PMIC and used on Allwinner A83T H8 Homlet dev board.
It's registers are different and calculating reg config is different than
that of earlier axp power ICs.
DCDC1, DCDC2, DCDC3 and DCDC5 is implemented at the moment.
all other voltages can be added subsequently.
AXP datasheet is uploaded to wiki:
http://linux-sunxi.org/File:AXP818_datasheet_Revision1.0.pdf
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Stop prefixing the axp functions for setting voltages, etc. with the
model number, there ever is only one pmic driver built into u-boot,
this allows simplifying the callers.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
