Using IP version for different setting
- Higher version supports 8bit mode
- Higher version bus width setting is different
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Since the at91sam9263, the mmc hardware support multi blocks read/write. So this driver enable it.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
New gen_atmel_mci driver does not use the outated register access macros. Since
the old atmel_mci driver is deleted these macros are no longer necessary.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
gen_atmel_mci works on AVR32 as well, so no need to use the legacy
mmc driver. This also has the nice side effect of being able to use
SDHC cards an those boards.
Signed-off-by: Sven Schnelle <svens@stackframe.org>
