path: root/include/ata.h
2012-11-02ahci: Perform SATA flush after disk write.Marc Jones
Writes in u-boot are so rare, and the logic to know when is the last write and do a flush only there is sufficiently difficult. Just do a flush after every write. This incurs, usually, one extra flush when the rare writes do happen. Signed-off-by: Marc Jones <marc.jones@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18CPCI750: Add CPCI-HD/2 supportReinhard Arlt
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750. As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3, the device must be swapped. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
2008-08-21Add a hook to allow board-specific PIO mode setting.Steven A. Falco
This patch adds a hook whereby a board-specific routine can be called to configure hardware for a PIO mode. The prototype for the board-specific routine is: int inline ide_set_piomode(int pio_mode) ide_set_piomode should be prepared to configure hardware for a pio_mode between 0 and 6, inclusive. It should return 0 on success or 1 on failure. Signed-off-by: Steven A. Falco <sfalco@harris.com>
2008-08-21Replace enums in ata.h with an include of libata.hSteven A. Falco
This patch removes some enums from ata.h and replaces them with an include of libata.h. This way, we eliminate duplicated code, and prevent errors whereby the different versions could be out of sync. Signed-off-by: Steven A. Falco <sfalco@harris.com>
2007-05-15Minor coding style cleanup.Wolfgang Denk
2007-05-15Add driver for S-ATA-controller on Intel processors with Southmushtaq khan
Bridge, ICH-5, ICH-6 and ICH-7. Implementation: 1. Code is divided in to two files. All functions, which are controller specific are kept in "drivers/ata_piix.c" file and functions, which are not controller specific, are kept in "common/cmd_sata.c" file. 2. Reading and Writing from the S-ATA drive is done using PIO method. 3. Driver can be configured for 48-bit addressing by defining macro CONFIG_LBA48, if this macro is not defined driver uses the 28-bit addressing. 4. S-ATA read function is hooked to the File system, commands like ext2ls and ext2load file can be used. This has been tested. 5. U-Boot command "SATA_init" is added, which initializes the S-ATA controller and identifies the S-ATA drives connected to it. 6. U-Boot command "sata" is added, which is used to read/write, print partition table and get info about the drives present. This I have implemented in same way as "ide" command is implemented in U-Boot. 7. This driver is for S-ATA in native mode. 8. This driver does not support the Native command queuing and Hot-plugging. Signed-off-by: Mushtaq Khan <mushtaq_k@procsys.com>
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2003-12-07* Patch by Pierre Aubert, 24 Nov 2003:wdenk
- add a return value for the fpga command - add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT is defined. If ide_preinit fails, ide_init is aborted. - fix an endianess problem in fat.h
