path: root/include/asm-sparc
2010-01-21lmb: only force on arches that use itMike Frysinger
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-04-28Replace __attribute references with __attribute__Peter Tyser
__attribute__ follows gcc's documented syntax and is generally more common than __attribute. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-20remove bi_enet*addr from global data for all archesMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-02-10Add an architecture specific config.h for common definesKumar Gala
We have common defines that we duplicate in various ways. Having an arch specific config.h gives us a common location for those defines. Eventually we should be able to replace this when we have proper Kconfig support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-15Introduce virt_to_phys()Kumar Gala
virt_to_phys() returns the physical address given a virtual. In most cases this will be just the input value as the vast majority of systems run in a 1:1 mode. However in systems that are not running this way it should report the physical address or ~0 if no mapping exists for the given virtual address. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-06Allow console input to be disabledMark Jackson
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE. When CONFIG_DISABLE_CONSOLE is defined, setting GD_FLG_DISABLE_CONSOLE disables all console input and output. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-07-10SPARC: Build error fixDaniel Hellstrom
(introduced by commit 391fd93ab23e15ab3dd58a54f5b609024009c378) This patch makes SPARC targets build again. It is caused by phys_addr_t and phys_size_t being defined in the wrong header file. include/lmb.h need those typedefs to build. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-20POST: replace the LOGBUFF_INITIALIZED flag in gd->post_log_word (1 << 31) ↵Yuri Tikhonov
with the GD_FLG_LOGINIT flag in gd->flags. This way we become able to utilize the full post_log_word for POST activities (overwise, POST ECC, which has 0x8000 ID, could be erroneously treated as started in post_output_backlog() even if there was actually no POST ECC run (because of OCM POST failure, for example). Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-08SPARC: Added support for SPARC LEON2 SOC Processor.Daniel Hellstrom
2008-04-08SPARC: Added support for SPARC LEON3 SOC processor.Daniel Hellstrom
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
