path: root/include/asm-sh
2008-09-19sh: Fix compile warningNobuhiro Iwamatsu
2008-09-06Allow console input to be disabledMark Jackson
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE. When CONFIG_DISABLE_CONSOLE is defined, setting GD_FLG_DISABLE_CONSOLE disables all console input and output. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-08-31sh: add support Renesas SH7723Nobuhiro Iwamatsu
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other. This patch supports CPU register's header file and SCIF serial driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: Add support Renesas SH7203 processorNobuhiro Iwamatsu
2008-08-31sh: Add support SH2/SH2A which is CPU of Renesas TechnologyNobuhiro Iwamatsu
Add support SH2/SH2A basic function. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-08-31sh: add support for SH7785Yoshihiro Shimoda
Renesas SH7785 has DDR2-SDRAM controller, PCI, and other. This patch supports CPU register's header file. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-09sh: Add support Renesas SH7763Nobuhiro Iwamatsu
Renesas SH7763 has 3 SCIF, MMC, LCDC, Ethernet and other. This patch supprts CPU register's header file. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-20POST: replace the LOGBUFF_INITIALIZED flag in gd->post_log_word (1 << 31) ↵Yuri Tikhonov
with the GD_FLG_LOGINIT flag in gd->flags. This way we become able to utilize the full post_log_word for POST activities (overwise, POST ECC, which has 0x8000 ID, could be erroneously treated as started in post_output_backlog() even if there was actually no POST ECC run (because of OCM POST failure, for example). Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-13Introduce phys_size_t and move phys_addr_t into asm/types.hKumar Gala
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's that have larger physical addresses like 44x, 85xx, and 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-03-28sh: Add support SH4 cache controlNobuhiro Iwamatsu
Add support SH4 cache control and flash_cache function Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support PCI host driver for SH7751/SH7751RNobuhiro Iwamatsu
2008-03-28sh: Add support SuperH SH7751/SH7751RNobuhiro Iwamatsu
2008-03-28sh: Added support for SH7720 based board MPR2.Mark Jonas
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support PCI of SuperH and SH7780Yusuke Goda
This patch add support PCI of SuperH base code and SH7780 specific code. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support SH7780Yusuke Goda
SH7780 is CPU of Renesas Technology. This CPU has - CPU clock 400MHz - PCI support - DDR-SDRAM controller - etc ... Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-02-23Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit ↵Shinya Kuribayashi
targets. ---------------------------------------------------------------- Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)] Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> ---------------------------------------------------------------- Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-14sh: Fix register address of SH7722Nobuhiro Iwamatsu
The address of SH7722 is wrong by old document. This patch fixes this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-01-15sh: Add support SH7710/SH7712Nobuhiro Iwamatsu
SH7710/SH7712 of SH3 CPU are supported. SH771X is called SH-Ether, and has the Ether controller in CPU. The driver of Ether is not included in this patch. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-01-15sh: Add support of map_physmem() and unmap_physmem() to SuperHNobuhiro Iwamatsu
This patch add the support of map_physmem() and unmap_physmem() used with Common Flash Interface(CFI) driver. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-01-15sh: Add support SH3 and SH7720Yoshihiro Shimoda
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2007-12-27Fix coding style issues; update CHANGELOG.Wolfgang Denk
2007-09-23sh: Add support Renesas sh7722 processor and Hitachi MS7722SE01 boardNobuhiro Iwamatsu
2007-09-23sh: Remove comment out code from include/asm-sh/cpu_sh4.hNobuhiro Iwamatsu
2007-09-23sh: Update core code of SuperH.Nobuhiro Iwamatsu
2007-05-13sh: First support code of SuperH.Nobuhiro Iwamatsu
