This helps to clean up the include/ directory so that it only contains
non-architecture-specific headers and also matches Linux's directory
layout which many U-Boot developers are already familiar with.
zlib.c demands asm/unaligned.h. But, SH does not have these.
This commit add asm/unaligned.h and asm/unaligned-sh4a.h from Linux
kernel and modifyf for u-boot.
These architectures don't need relocation fixups, so reduce their
codesize a bit by defining CONFIG_RELOC_FIXUP_WORKS.
Also remove the reloc_off field from their global data structures
as it is no longer needed.
Note that the location of the standalone application jump table pointer
in the global data structure is affected by this change, breaking
execution of standalone applications compiled for previous versions of
U-Boot. We will therefore increment XF_VERSION in the next commit,
which also touches this area.
Commits
02f99901ed1c9d828e3ea117f94ce2264bf8389e
52d61227b66d4099b39c8309ab37cb67ee09a405
introduced a regression where platform-specific ffs/fls implementations
were defined away. This patch corrects that by using PLATFORM_xxx
instead of the name itself.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
UBIFS requires fls(), which is not defined for arm (and some other
architectures) and this patch adds it. The implementation is taken from
Linux and is generic. ffs() is also defined for those that miss it.
This patch use blackfin errno.h implementation which
correspond Linux kernel one.
MIPS implemetation is different that's why I keep it.
I removed ppc_error_no.h from Marvell boards which
was the same too.
I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians.
The check of data became severe from newest gcc.
This patch checked in gcc-4.2 and 4.3 .
Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Daniel Hellstrom <daniel@gaisler.com>
CC: Michal Simek <monstr@seznam.cz>
CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
CC: Scott McNutt <smcnutt@psyent.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
We have common defines that we duplicate in various ways. Having an
arch specific config.h gives us a common location for those defines.
Eventually we should be able to replace this when we have proper
Kconfig support.
virt_to_phys() returns the physical address given a virtual. In most
cases this will be just the input value as the vast majority of
systems run in a 1:1 mode.
However in systems that are not running this way it should report the
physical address or ~0 if no mapping exists for the given virtual
address.
SH4 is different a value of CACHE_OC_NUM_ENTRIES and
CACHE_OC_WAY_SHIFT every CPU.
This patch corrects these values.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE.
When CONFIG_DISABLE_CONSOLE is defined, setting
GD_FLG_DISABLE_CONSOLE disables all console input and output.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Renesas SH7723 has 5 SCIF, SD, Camera, LCDC and other.
This patch supports CPU register's header file and SCIF serial driver.
Add support SH2/SH2A basic function.
Renesas SH7785 has DDR2-SDRAM controller, PCI, and other.
This patch supports CPU register's header file.
Currently, both are defined as an unsigned long, but
should be phys_size_t. This should result in no real change,
since phys_size_t is currently an unsigned long for all the
default configs. Also add print_lnum to cmd_bdinfo to deal
with the potentially wider memsize.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Renesas SH7763 has 3 SCIF, MMC, LCDC, Ethernet and other.
This patch supprts CPU register's header file.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
with the GD_FLG_LOGINIT flag in gd->flags.
This way we become able to utilize the full post_log_word for POST
activities (overwise, POST ECC, which has 0x8000 ID, could be
erroneously treated as started in post_output_backlog() even if there
was actually no POST ECC run (because of OCM POST failure, for
example).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Don't run futher tests in case of a test fails that is marked as
POST_STOP.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's
that have larger physical addresses like 44x, 85xx, and 86xx.
Add support SH4 cache control and flash_cache function
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com>
This patch add support PCI of SuperH base code and SH7780 specific code.
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
SH7780 is CPU of Renesas Technology.
This CPU has
- CPU clock 400MHz
- PCI support
- DDR-SDRAM controller
- etc ...
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
targets.
Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)]
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
The address of SH7722 is wrong by old document.
This patch fixes this problem.
SH7710/SH7712 of SH3 CPU are supported.
SH771X is called SH-Ether, and has the Ether controller in CPU.
The driver of Ether is not included in this patch.
This patch add the support of map_physmem() and unmap_physmem()
used with Common Flash Interface(CFI) driver.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
