Patch by Stefan Roese, 4 Oct 2005
Patch by Daniel Eisenhut, 25 Mar 2005
now handling all 4xx cpu's.
Patch by Stefan Roese, 16 Aug 2005
Patch by Stefan Roese, 08 Aug 2005
- C++ comments
- Trailing white space
- Indentation not by TAB
- Excessive amount of empty lines
- Trailing empty lines
Patch by Steven Blakeslee, 27 Jul 2005
Add support for the Freescale MPC8349ADS board.
Implemented support for MPC8548CDS board.
Added DDR II support based on SPD values for MPC85xx boards.
This roll-up patch also includes bugfies for the previously
published patches:
DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
- Add support for HIDDEN_DRAGON board
- fix endianess problem in driver/rtl1839.c
* Patch by Allen Curtis, 21 Oct 2004:
support multiple serial ports
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
- Make MPC5200 boards evaluate the SVR to print processor name and
version in checkcpu() (cpu/mpc5xxx/cpu.c).
* Patch by Kai-Uwe Bloem, 06 May 2004:
Fix endianess problem in cramfs code
- flash.h: more flash types added
- immap_8260.h: some bits added (useful for RMII)
- cmd_coninfo.c: typo corrected, printf -> puts
- reduced size by replacing spaces with tab
(partially, as they contained a lot of crap)
- Rename DUET_ADS to MPC885ADS
- Rename CONFIG_DUET to CONFIG_MPC885_FAMILY
- Rename CONFIG_866_et_al to CONFIG_MPC866_FAMILY
- Clean up FADS family port to use the new defines
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
* Patch by Rune Torgersen, 06 Apr 2004:
- Fix some PCI problems on the MPC8266ADS board
- Fix the location of some PCI entries in the immap structure
Improve and fix various things in the MPC8xx FEC driver:
1. The new 87x and 88x series of processors have two FECs,
and the new driver supports them both.
2. Another change in the 87x/88x series is support for
the RMII (Reduced MII) interface. However numerous
changes are needed to make it work since the PHYs
are connected to the same lines. That means that
you have to address them correctly over the MII
interface.
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
- show PCI clock frequency on MPC8260 systems
- add FCC_PSMR_RMII flag for HiP7 processors
- in do_jffs2_fsload(), take load address from load_addr if not set
explicit, update load_addr otherwise
- replaced printf by putc/puts when no formatting is needed
(smaller code size, faster execution)
Add support for NFS for file download
* Minor code cleanup
* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
o 440GX:
- Fix PCI Indirect access for type 1 config cycles with ppc440.
- Add phymode for 440 enet
- fix pci pre init
o XPedite1K:
- Change board_pre_init to board_early_init_f
- Add user flash to bus controller setup
- Fix pci pre init
- Fix is_pci_host to check GPIO for monarch bit
- Force xpedite1k to pci conventional mode (via #define option)
* Patch by Brad Kemp, 4 Feb 2004:
- handle the machine check that is generated during the PCI scans
on 82xx processors.
- define the registers used in the IMMR by the PCI subsystem.
* Patch by Pierre Aubert, 03 Feb 2004:
cpu/mpc5xxx/start.S: copy MBAR into SPR311
* Patch by Jeff Angielski, 03 Feb 2004:
Fix copy & paste error in cpu/mpc8260/pci.c
* Patch by Reinhard Meyer, 24 Jan 2004:
Fix typo in cpu/mpc5xxx/pci_mpc5200.c
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
* Patch by Scott McNutt, 02 Jan 2004:
Add support for the Nios Active Serial Memory Interface (ASMI)
on Cyclone devices
* Patch by Andrea Marson, 16 Dec 2003:
Add support for the PPChameleon ME and HI modules
* Patch by Yuli Barcohen, 22 Dec 2003:
Add support for Motorola DUET ADS board (MPC87x/88x)
update for for Atmel AT91RM9200DK development kit:
- support for environment variables in DataFlash
- Atmel DataFlash AT45DB1282 support
* Patch by Jeff Carr, 11 Nov 2003:
add support for new version of 8270 processors
* Patches by George G. Davis, 05 Nov 2003:
- only pass the ARM linux initrd tag to the kernel when an initrd
is actually present
- update omap1510inn configuration file
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
for more information
enable watchdog support for all MPC824x boards that have a watchdog
* On MPC5200, restrict FEC to a maximum of 10 Mbps to work around the
"Non-octet Aligned Frame" errors we see at 100 Mbps
* Patch by Sharad Gupta, 14 Sep 2003:
fix SPR numbers for upper BAT register ([ID]BAT[4-7][UL])
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
make logbuf compile without POST
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
* Patch by Murray Jensen, 24 Jun 2003:
- make sure to use only U-boot provided header files
- fix problems with ".rodata.str1.4" section as used by GCC-3.x
added CONFIG_750FX support for IBM 750FX processors
Fix clock divider rounding problem in drivers/serial.c
* Patch by Ken Chou, 19 June 2003:
Added support for A3000 SBC board (Artis Microsystems Inc.)
- rewrite of the S3C24X0 register definitions stuff
- "driver" for the built-in S3C24X0 RTC
* Patches by Yuli Barcohen, 12 Jun 2003:
- Add MII support and Ethernet PHY initialization for MPC8260ADS board
- Fix incorrect SIUMCR initialisation caused by wrong Hard Reset
configuration word supplied by FPGA on some MPC8260ADS boards
* Patch by Pantelis Antoniou, 10 Jun 2003:
Unify status LED interface
