2002-11-19 | * Patch by Thomas Frieden, 13 Nov 2002: | wdenk | |
Add code for AmigaOne board (preliminary merge to U-Boot, still WIP) * Patch by Jon Diekema, 12 Nov 2002: - Adding URL for IEEE OUI lookup - Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED being defined. - In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and root-on-nfs macros are designed to switch how the default boot method gets defined. | |||
2002-11-03 | Initial revision | wdenk | |
2002-11-02 | Initial revision | wdenk | |
2002-10-21 | Initial revision | wdenk | |
2002-10-07 | Initial revision | wdenk | |
2002-09-07 | Initial revision | wdenk | |
2002-08-06 | Initial revision | wdenk | |
2002-05-15 | Initial revision | wdenk | |
2002-03-31 | Initial revision | wdenk | |
2002-03-10 | Initial revision | wdenk | |
2001-09-06 | Initial revision | wdenk | |
2001-08-05 | Initial revision | wdenk | |
2001-04-28 | Initial revision | wdenk | |
2000-11-23 | Initial revision | wdenk | |
2000-11-20 | Initial revision | wdenk | |
2000-10-11 | Initial revision | wdenk | |
2000-08-21 | Initial revision | wdenk | |
