path: root/include/asm-ppc
2009-11-19ppc4xx: Consolidate pci_master_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_master_init() function by introducing a weak default function for it. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-11-04fsl_pci_init_port end-point initialization is brokenEd Swarthout
commit 70ed869e broke fsl pcie end-point initialization. Returning 0 is not correct. The function must return the first free bus number for the next controller. fsl_pci_init() must still be called and a bus allocated even if the controller is an end-point. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-04Revert "ppc/85xx/pci: fsl_pci_init: pcie agent mode support"Kumar Gala
This reverts commit 70ed869ea5f6b1d13d7b140c83ec0dcd8a127ddc. There isn't any need to modify the API for fsl_pci_init_port to pass the status of host/agent(end-point) status. We can determine that internally to fsl_pci_init_port. Revert the patch that makes the API change. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-2785xx: MP Boot Page Translation updatePeter Tyser
This change has 3 goals: - Have secondary cores be released into spin loops at their 'true' address in SDRAM. Previously, secondary cores were put into spin loops in the 0xfffffxxx address range which required that boot page translation was always enabled while cores were in their spin loops. - Allow the TLB window that the primary core uses to access the secondary cores boot page to be placed at any address. Previously, a TLB window at 0xfffff000 was always used to access the seconary cores' boot page. This TLB address requirement overlapped with other peripherals on some boards (eg XPedite5370). By default, the boot page TLB will still use the 0xfffffxxx address range, but this can be overridden on a board-by-board basis by defining a custom CONFIG_BPTR_VIRT_ADDR. Note that the TLB used to map the boot page remains in use while U-Boot executes. Previously it was only temporarily used, then restored to its initial value. - Allow Boot Page Translation to be disabled on bootup. Previously, Boot Page Translation was always left enabled after secondary cores were brought out of reset. This caused the 0xfffffxxx address range to somewhat "magically" be translated to an address in SDRAM. Some boards may not want this oddity in their memory map, so defining CONFIG_MPC8xxx_DISABLE_BPTR will turn off Boot Page Translation after the secondary cores are initialized. These changes are only applicable to 85xx boards with CONFIG_MP defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-27ppc/85xx/pci: fsl_pci_init: pcie agent mode supportVivek Mahajan
Originally written by Jason Jin and Mingkai Hu for mpc8536. When QorIQ based board is configured as a PCIe agent, then unlock/enable inbound PCI configuration cycles and init a 4K inbound memory window; so that a PCIe host can access the PCIe agents SDRAM at address 0x0 * Supported in fsl_pci_init_port() after adding pcie_ep as a param * Revamped copyright in drivers/pci/fsl_pci_init.c * Mods in 85xx based board specific pci init after this change Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-18mpc512x: fix System Clock Control constants for USB1 & USB2Martha Stan
Signer-off-by: Martha Stan <mmarx@silicontkx.com>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-08mpc512x: fix fixed_sdram() init code.Wolfgang Denk
Commit 054197ba and later fixes used an array to initialize some of the MDDRC parameters; however, the use of an array turned out to be a bad idea as it was not possible to correlate structure entries to array indices in readable and reliable way. Now we use a struct instead, which makes this self-explanatory. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-07ppc4xx: Add PPC405EX(r) Rev D supportStefan Roese
Unfortunately some Rev D PPC405EX/405EXr PVR's are identical with older 405EX(r) parts. Here a list: 0x12911475 - 405EX Rev D with Security *and* 405EX Rev A/B witout Sec 0x12911473 - 405EX Rev D without Security *and* 405EXr Rev A/B with Sec Since there are only a few older parts in the field, this patch now changes the PVR's above to represent the new Rev D versions. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Phong Vo" <pvo@amcc.com>
2009-10-03ppc: Remove reloc_off field from global_data structurePeter Tyser
Now that proper relocation is supported, the reloc_off field is no longer necessary. Note that the location of the standalone application jump table pointer in the global data structure is affected by this change, breaking execution of standalone applications compiled for previous versions of U-Boot. We therefore increment XF_VERSION to 6 Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-02ppc4xx: Merge PPC4xx DDR and DDR2 ECC handlingStefan Roese
This patch merges the ECC handling (ECC parity byte writing) into one file (ecc.c) for all PPC4xx SDRAM controllers except for PPC440EPx/GRx. This exception is because only those PPC's use the completely different Denali SDRAM controller core. Previously we had two routines to generate/write the ECC parity bytes. With this patch we now only have one core function left. Tested on Kilauea (no ECC) and Katmai (with and without ECC). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Felix Radensky <felix@embedded-sol.com> Cc: Grant Erickson <gerickson@nuovations.com> Cc: Pieter Voorthuijsen <pv@prodrive.nl>
2009-09-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-09-28ppc/85xx: Clean up immap_85xx.hKumar Gala
* Converted all white space to tabs * Converted all types to u8/u16/u32 * Reduce lines to fit in 80 columns * Renamed MPC85xx_{Q,B}MAN -> FSL_CORENET_{Q,B}MAN Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-28ppc4xx: Convert PPC4xx UIC defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed the UIC defines. This patch now changes lower case UIC defines to upper case. Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-25Fix "ppc/85xx: Clean up use of LAWAR defines" breakageWolfgang Denk
Commit 002741ae86 modified include/asm-ppc/mmu.h such that the LAWAR_ defines were only enabled for the 83xx platform, but they are also needed on MPC512x system. Enabling these for E300 systems seems thus more appropriate. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-25mpc512x: Streamlined fixed_sdram() init sequence.Martha M Stan
Signed-off-by: Martha M Stan <mmarx@silicontkx.com> Minor cleanup: Re-ordered default_mddrc_config[] to have matching indices. This allows to use the same index "N" for source and target fields; before, we had code like this out_be32(&im->mddrc.ddr_time_config2, mddrc_config[3]); which always looked like a copy & paste error because 2 != 3. Also, use NULL when meaning a null pointer. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-24ppc/p4080: Add various p4080 related defines (and p4040)Kumar Gala
There are various locations that we have chip specific info: * Makefile for which ddr code to build * Added p4080 & p4040 to cpu_type_list and SVR list * Added number of LAWs for p4080 * Set CONFIG_MAX_CPUS to 8 for p4080 Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add support for CoreNet style platform LAWsKumar Gala
On CoreNet based platforms the LAW address is split between an high & low register and we no longer shift the address. Also, the target IDs on CoreNet platforms have been completely re-assigned. Additionally, added a new find_law() API to which LAW an address hits in. This is need for the CoreNet style boot release code since it will need to determine what the target ID should be set to for boot window translation. Finally, enamed LAWAR_EN to LAW_EN and moved to header so we can use it elsewhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/p4080: Add p4080 platform immap definitionsKumar Gala
The p4080 SoC has a significant amount of commonality with the 85xx/PQ3 platform. We reuse the 85xx immap and just add new definitions for local access and global utils. The global utils is now broken into global utils, clocking and run control/power management. The offsets from CCSR for a number of blocks have also changed. We introduce the CONFIG_FSL_CORENET define to distinquish the PQ3 style of platform from the new p4080 platform. We don't use QoirQ as there are products (like p2020) that are PQ3 based platforms but have the QoirQ name. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24immap_85xx: add porpllsr's plat ratio definitionMingkai Hu
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24fsl_pci: create a SET_STD_PCI_INFO() helper wrapperPaul Gortmaker
Recycle the recently added PCI-e wrapper used to reduce board duplication of code by creating a similar version for plain PCI. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Clean up use of LAWAR definesKumar Gala
On 85xx platforms we shouldn't be using any LAWAR_* defines but using the LAW_* ones provided by fsl-law.h. Rename any such uses and limit the LAWAR_ to the 83xx platform as the only user so we will get compile errors in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Fix LCRR_CLKDIV definesKumar Gala
For some reason the CLKDIV field varies between SoC in how it interprets the bit values. All 83xx and early (e500v1) PQ3 devices support: clk/2: CLKDIV = 2 clk/4: CLKDIV = 4 clk/8: CLKDIV = 8 Newer PQ3 (e500v2) and MPC86xx support: clk/4: CLKDIV = 2 clk/8: CLKDIV = 4 clk/16: CLKDIV = 8 Ensure that the MPC86xx and MPC85xx still get the same behavior and make the defines reflect their logical view (not the value of the field). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15ppc/85xx: Repack tlb_table to save spaceKumar Gala
We can pack the initial tlb_table in MAS register format and use write_tlb to set things up. This savings can be helpful for NAND style first stage boot loaders. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-15ppc/85xx: Introduce low level write_tlb functionKumar Gala
Factor out the code we use to actually write a tlb entry. set_tlb is a logical view of the TLB while write_tlb is a low level matching the MAS registers. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-15ppc/85xx: Ensure that MAS8 is zero when writing TLB entries.Scott Wood
Its reset value is random, and we sometimes read uninitialized TLB arrays. Make sure that we don't retain MAS8 from reading such an entry if the VF bit in MAS8 is set, attempts to use the mapping will trap. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-09-15Define ffs/fls for all architecturesSimon Kagstrom
UBIFS requires fls(), which is not defined for arm (and some other architectures) and this patch adds it. The implementation is taken from Linux and is generic. ffs() is also defined for those that miss it. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-09-08ppc/85xx,86xx: Handling Unknown SOC versionPoonam Aggrwal
Incase the system is detected with Unknown SVR, let the system boot with a default value and a proper message. Now with dynamic detection of SOC properties from SVR, this is necessary to prevent a crash. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/8xxx: Refactor code to determine if PCI is enabled & agent/hostKumar Gala
Refactor the code into a simple bitmask lookup table that determines if a given PCI controller is enabled and if its in host/root-complex or agent/end-point mode. Each processor in the PQ3/MPC86xx family specified different encodings for the cfg_host_agt[] and cfg_IO_ports[] boot strapping signals. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/85xx: Add a simple function to search the TLBKumar Gala
Allow us to search the TLB array based on an address. This is useful if we want to change an entry but dont know where it happens to be located. For example, the boot page mapping we use on MP or the flash TLB that we change the WIMGE settings for after we've relocated. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-0885xx: Add support for setting IVORs to fixed offset defaultsKumar Gala
In future Book-E implementations IVORs will most likely go away and be replaced with fixed offsets. The IVPR will continue to exist to allow for relocation of the interrupt vectors. This code adds support to setup the IVORs as their fixed offset values per the ISA 2.06 spec when we transition from u-boot to another OS either via 'bootm' or a cpu release. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-08ppc/8xxx: Remove ddr_pd_cntl register since it doesn't existKumar Gala
The ddr_pd_cntl isn't defined in any reference manual and thus we wil remove especially since we set it to 0, which would most likely be its POR value. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28driver/fsl_pci: Add fsl_pci_init_port function to initialize a PCI controllerPoonam Aggrwal
fsl_pci_init_port can be called from board specific PCI initialization routines to setup the PCI (or PCIe) controller. This will reduce code redundancy in most of the 85xx/86xx FSL board ports that setup PCI. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added single core members of FSL P1xx/P2xx processors seriesPoonam Aggrwal
P1011 - Single core variant of P1020 P2010 - Single core variant of P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Added CONFIG_MAX_CPUS for P1020Poonam Aggrwal
2009-08-2885xx: Add L2SRAM Register's macro definitionMingkai Hu
2009-08-2885xx: Added P1020 Processor Support.Poonam Aggrwal
P1020 is another member of QorIQ series of processors which falls in ULE category. It is an e500 based dual core SOC. Being a scaled down version of P2020 it has following differences: - 533MHz - 800MHz core frequency. - 256Kbyte L2 cache - Ethernet controllers with classification capabilities. Also the SOC is pin compatible with P2020 Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold pci_setup_indirect into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls pci_setup_indirect before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-30ppc4xx: Add basic support for AMCC PPC460EX/460GT rev B chipsStefan Roese
This patch is based on a diff created by Phong Vo from AMCC. Signed-off-by: Phong Vo <pvo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Add struct for 4xx GPIO controller registersMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-24ppc4xx: Replace 4xx lowercase SPR referencesMatthias Fuchs
2009-07-24Add "chip_config" command for PPC4xx bootstrap configurationStefan Roese
This patch adds a generic command for programming I2C bootstrap eeproms on PPC4xx. An implementation for Canyonlands board is included. The command name is intentionally chosen not to be PPC4xx specific. This way other CPU's/SoC's can implement a similar command under the same name, perhaps with a different syntax. Usage on Canyonlands: => chip_config Available configurations (I2C address 0x52): 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100 800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100 800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100 1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100 1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100 1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 *** 1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88 => chip_config 600-nor Using configuration: 600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100 done (dump via 'i2c md 52 0.1 10') Reset the board for the changes to take effect Other 4xx boards will be migrated to use this command soon as well. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
