path: root/include/asm-ppc/u-boot.h
2006-09-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
Conflicts: board/stxxtc/Makefile
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2005-08-16Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.cStefan Roese
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-02Merge with rsync://git-user@source.denx.net/git/u-boot.gitJon Loeliger
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-10Patches by Jon Loeliger, 24 Aug 2004:wdenk
- Add support for the MPC8541 and MPC8555 CDS boards - Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
2004-06-09Patches by Jon Loeliger, 11 May 2004:wdenk
(partially, as they contained a lot of crap)
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2004-02-23* CVS add missing fileswdenk
* Cleanup compiler warnings * Fix problem with side effects in macros in include/usb.h * Patch by David Benson, 13 Nov 2003: bug 841358 - fix TFTP download size limit * Fixing bug 850768: improper flush_cache() in load_serial() * Fixing bug 834943: MPC8540 - missing volatile declarations * Patch by Stephen Williams, 09 Feb 2004: Add support for Xilinx SystemACE chip: - New files common/cmd_ace.c and include/systemace.h - Hook systemace support into cmd_fat and the partition manager * Patch by Travis Sawyer, 09 Feb 2004: Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
2004-02-22* Patch by Travis Sawyer, 09 Feb 2004:wdenk
o 440GX: - Fix PCI Indirect access for type 1 config cycles with ppc440. - Add phymode for 440 enet - fix pci pre init o XPedite1K: - Change board_pre_init to board_early_init_f - Add user flash to bus controller setup - Fix pci pre init - Fix is_pci_host to check GPIO for monarch bit - Force xpedite1k to pci conventional mode (via #define option) * Patch by Brad Kemp, 4 Feb 2004: - handle the machine check that is generated during the PCI scans on 82xx processors. - define the registers used in the IMMR by the PCI subsystem. * Patch by Pierre Aubert, 03 Feb 2004: cpu/mpc5xxx/start.S: copy MBAR into SPR311 * Patch by Jeff Angielski, 03 Feb 2004: Fix copy & paste error in cpu/mpc8260/pci.c * Patch by Reinhard Meyer, 24 Jan 2004: Fix typo in cpu/mpc5xxx/pci_mpc5200.c
2004-02-06Patch by Travis Sawyer, 30 Dec 2003:wdenk
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices, select MDI port based on enabled EMAC device. Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX base PrPMC board.
2003-11-17* Use "-fPIC" instead of "-mrelocatable" to prevent problems withwdenk
recent tools * Add checksum verification to 'imls' command * Add bd_info fields needed for 4xx Linux I2C driver * Patch by Martin Krause, 4 Nov. 2003: Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap) * Print used network interface when CONFIG_NET_MULTI is set
2003-09-02* Add support for PPChameleon Eval Boardwdenk
* Add support for P3G4 board * Fix problem with MGT5100 FEC driver: add "early" MAC address initialization
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-05-23PPC405EP support added.stroese
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-28Patches by Dave Ellis, 18 Mar 2003 for SXNI855T board:wdenk
- fix SRAM and SDRAM memory sizing - add status LED support - add MAC address for second (SCC1) ethernet port Update default environment for TQM8260 board
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
