path: root/include/asm-ppc/immap_86xx.h
2008-07-07Feed the watchdog in u-boot for 8610 board.Jason Jin
The watchdog on 8610 board is enabled by setting sw[6] to on. Once enabled, the watchdog can not be disabled by software. So feed the dog in u-boot is necessary for normal operation. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-2985xx/86xx: Rename DDR init address and init extended address registerKumar Gala
Rename init_addr and init_ext_addr to match the docs between 85xx and 86xx. Both now use 'init_addr' and 'init_ext_addr'. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-2086xx: Fix GUR PCI config registers properly.Jon Loeliger
Back in commit 975a083a5ef785c414b35f9c5b8ae25b26b41524 where I tried to "8610HPCD: Fix typos in two PCI setup registers", I botched it due to not realizing that 8610 and 8641 had different Global Utility Register defintions, one of which was like 85xx, and the other wasn't. Correct this problem by introducing two symbols, one for each 86xx SoC, but neither of which is named anything like 85xx. My bad. Lovely Wednesday with git bisect. You know. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-198610HPCD: Fix typos in two PCI setup registers.Jon Loeliger
The two symbols MPC86xx_PORDEVSR_IO_SEL and MPC86xx_PORBMSR_HA were erroneously present as 85xx names and values, leftover from the clone wars. Fix this by removing the 85xx cruft from the 86xx codebase. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-02-13Add CFG_MPC86xx_DDR_ADDR and CFG_MPC86xx_DDR2_ADDR symbolsJon Loeliger
These replace direct structure references for IMMR sections. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-08-10cpu/86xx fixes.Jon Loeliger
Remove rev 1 fixes. Always set PICGCR_MODE. Enable machine check and provide board config option to set and handle SoC error interrupts. Include MSSSR0 in error message. Isolate a RAMBOOT bit of code with #ifdef CFG_RAMBOOT. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-03-22Set Rev 2.x 86xx PIC in mixed mode.Haiying Wang
Prevent false interrupt from hanging Linux as MSR[EE] is set to enable interrupts by changing the PIC out of the default pass through mode into mixed mode. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-20Use generic I2C register block on 85xx and 86xx.Jon Loeliger
Replace private IMMAP I2C structures with generic reg block and allow 86xx to have multiple I2C device busses. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-10Fix whitespace issues.Jon Loeliger
2006-06-27Enable PCIE1 for MPC8641HPCN boardJin Zhengxiong-R64188
2006-05-19Update 86xx address map and LAWBARs.Jon Loeliger
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
