path: root/include/asm-ppc/immap_83xx.h
2009-02-1683xx: Add eSDHC support on 8379 EMDS boardAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-21mpc83xx: Add support for MPC83xx PCI-E controllersAnton Vorontsov
This patch adds support for MPC83xx PCI-E controllers in Root Complex mode. The patch is based on Tony Li and Dave Liu work[1]. Though unlike the original patch, by default we don't register PCI-E buses for use in U-Boot, we only configure the controllers for future use in other OSes (Linux). This is done because we don't have enough of spare BATs to map all the PCI-E regions. To actually use PCI-E in U-Boot, users should explicitly define CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES symbol in the board file. And only then U-Boot will able to access PCI-E, but at the cost of disabled address translation. [1] http://lists.denx.de/pipermail/u-boot/2008-January/027630.html Signed-off-by: Tony Li <tony.li@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-10-29Make Freescale local bus registers available for both 83xx and 85xx.Haiying Wang
- Rename lbus83xx_t to fsl_lbus_t and move it to asm/fsl_lbc.h so that it can be shared by both 83xx and 85xx - Remove lbus83xx_t and replace it with fsl_lbus_t in all 83xx boards files which use lbus83xx_t. - Move FMR, FIR, FCR, FPAR, LTESR from mpc83xx.h to asm/fsl_lbc.h so that 85xx can share them. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-25MPC83XX: Add miscellaneous registers and #defines to support MPC83xx family ↵Nick Spence
devices This patch adds elements to the 83xx sysconf structure and #define values that are used by mpc83xx family devices. Signed-off-by: Nick Spence <nick.spence@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-18mpc83xx: Correct the struct spi8xxx in mpc8xxx_spi.hDave Liu
The commit 04a9e1180ac76a7bacc15a6fcd95ad839d65bddb cause the 83xx immap broken, so the DMA and PCI will be failed. The patch fix the struct spi8xxx and rm struct spi83xx. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-17Add support for a Freescale non-CPM SPI controllerBen Warren
This patch adds support for the SPI controller found on Freescale PowerPC processors such as the MCP834x family. Additionally, a new config option, CONFIG_HARD_SPI, is added for general purpose SPI controller use. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-08mpc83xx: Add the support of MPC8315E SoCDave Liu
The MPC8315E SoC including e300c3 core and new IP blocks, such as TDM, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-01-08mpc83xx: Add the support of MPC837x SoCDave Liu
The MPC837x SoC including e300c4 core and new IP blocks, such as SDHC, PCI Express and SATA controller. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-04-23mpc83xx: Add register definitions for MPC831x.Scott Wood
2007-03-02mpc83xx: Replace CONFIG_MPC8349 and use CONFIG_MPC834X insteadKumar Gala
The code that is ifdef'd with CONFIG_MPC8349 is actually applicable to all MPC834X class processors. Change the protections from CONFIG_MPC8349 to CONFIG_MPC834X so they are more generic. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-03-02mpc83xx: Add support for the MPC832XEMDS boardDave Liu
This patch supports DUART, ETH3/4 and PCI etc. Signed-off-by: Dave Liu <daveliu@freescale.com>
2007-03-02mpc83xx: streamline the 83xx immr head fileDave Liu
For better format and style, I streamlined the 83xx head files, including immap_83xx.h and mpc83xx.h. In the old head files, 1) duplicated macro definition appear in the both files; 2) the structure of QE immr is duplicated in the immap_83xx.h and immap_qe.h; 3) The macro definition put inside the each structure. So, I cleaned up the structure of QE immr from immap_83xx.h, deleted the duplicated stuff and moved the macro definition to mpc83xx.h, Just like MPC8260. CHANGELOG *streamline the 83xx immr head file Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-11-30Code cleanup.Wolfgang Denk
2006-11-03mpc83xx: Update 83xx to use fsl_i2c.cTimur Tabi
Update the 83xx tree to use I2C support in drivers/fsl_i2c.c. Delete cpu/mpc83xx/i2c.c, include/asm-ppc/i2c.h, and all references to those files. Added multiple I2C bus support to fsl_i2c.c. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Add 8360 specifics to 83xx immapDave Liu
Mainly add QE device dependencies, with appropriate 8360 protection. Lindent also run.
2006-11-03mpc83xx: Add support for the MPC8349E-mITXTimur Tabi
PREREQUISITE PATCHES: * This patch can only be applied after the following patches have been applied: 1) DNX#2006090742000024 "Add support for multiple I2C buses" 2) DNX#2006090742000033 "Multi-bus I2C implementation of MPC834x" 3) DNX#2006091242000041 "Additional MPC8349 support for multibus i2c" 4) DNX#2006091242000078 "Add support for variable flash memory sizes on 83xx systems" 5) DNX#2006091242000069 "Add support for Errata DDR6 on MPC 834x systems" CHANGELOG: * Add support for the Freescale MPC8349E-mITX reference design platform. The second TSEC (Vitesse 7385 switch) is not supported at this time. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Changed to unified mpx83xx names and added common 83xx changesDave Liu
Incorporated the common unified variable names and the changes in preparation for releasing mpc8360 patches. Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-03-16Fix DDR ECC bit definitions for MPC83xx.Marian Balakowicz
2006-03-14Add DMA support for MPC83xx.Marian Balakowicz
2006-03-14Add bit definitions for MPC83xx DDR controller registers.Marian Balakowicz
2006-01-23Fixed defines for MPC83xx SICRL register to match current specsKumar Gala
Patch by Kumar Gala, 23 Jan 2006
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-11Added support for TQM834x boards.Marian Balakowicz
2005-08-01Fix style issues primarily in 85xx and 83xx boards.Jon Loeliger
- C++ comments - Trailing white space - Indentation not by TAB - Excessive amount of empty lines - Trailing empty lines
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
