path: root/include/asm-ppc/global_data.h
2007-04-23mpc83xx: Add 831x support to global_data.hScott Wood
2007-04-18Merge with /home/wd/git/u-boot/custodian/u-boot-74xx-7xxWolfgang Denk
2007-03-02mpc83xx: Replace CONFIG_MPC8349 and use CONFIG_MPC834X insteadKumar Gala
The code that is ifdef'd with CONFIG_MPC8349 is actually applicable to all MPC834X class processors. Change the protections from CONFIG_MPC8349 to CONFIG_MPC834X so they are more generic. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-12-01Fix the confilcts when merging 'master' into hpc2.roy zang
The conflicts due to a new mpc7448 p3m7448 board is in the main tree. Merge branch 'master' into hpc2 Conflicts: MAKEALL cpu/74xx_7xx/cpu.c cpu/74xx_7xx/cpu_init.c cpu/74xx_7xx/speed.c
2006-11-03mpc83xx: add QE ethernet supportDave Liu
this patch adds support for the QUICC Engine based UCC gigabit ethernet device.
2006-11-03mpc83xx: Add MPC8360EMDS basic board supportDave Liu
Add support for the Freescale MPC8360EMDS board. Includes DDR, DUART, Local Bus, PCI.
2006-11-02General code modification for mpc7448hpc2 board support.roy zang
1. Add 7447A and 7448 processor support. 2. Add the following flags. CFG_CONFIG_BUS_CLK : If the 74xx bus frequency can be configured dynamically (such as by switch on board), this flag should be set. CFG_EXCEPTION_AFTER_RELOCATE: If an exception occurs after the u-boot relocates to RAM, this flag should be set. CFG_SERIAL_HANG_IN_EXCEPTION: If the print out function will cause the system hang in exception, this flag should be set. There is a design issue for tsi108/109 pci configure read. When pci scan the slots, if there is no pci card, the tsi108/9 will cause a machine check exception for mpc7448 processor. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-04-03* Patch by Yusdi Santoso, 22 Oct 2004:wdenk
- Add support for HIDDEN_DRAGON board - fix endianess problem in driver/rtl1839.c * Patch by Allen Curtis, 21 Oct 2004: support multiple serial ports
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-09-02* Add support for PPChameleon Eval Boardwdenk
* Add support for P3G4 board * Fix problem with MGT5100 FEC driver: add "early" MAC address initialization
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-16* Add support for IceCube board (with MGT5100 and MPC5200 CPUs)U-Boot-0_4_4wdenk
2003-07-15Avoid unnecessary call to post_word_load();wdenk
make logbuf compile without POST
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-06-20* Patch by Devin Crumb, 02 Apr 2003:wdenk
Fix clock divider rounding problem in drivers/serial.c * Patch by Ken Chou, 19 June 2003: Added support for A3000 SBC board (Artis Microsystems Inc.)
2003-04-27* LWMON extensions:wdenk
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU
2002-12-08* Improve log buffer code; use "loglevel" to decide which messageswdenk
to log on the console, too (like in Linux); get rid of "logstart"
2002-10-21Initial revisionwdenk
