This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's
that have larger physical addresses like 44x, 85xx, and 86xx.
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
targets.
The previous patch was lacking of i386, microblaze, nios and nios2. This
patch tries to fix them.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
map_physmem() returns a virtual address which can be used to access a
given physical address without involving the cache. unmap_physmem()
should be called when the virtual address returned by map_physmem() is
no longer needed.
This patch adds a stub implementation which simply returns the
physical address cast to a uchar * for all architectures except AVR32,
which converts the physical address to an uncached virtual mapping.
unmap_physmem() is a no-op on all architectures, but if any
architecture needs to do such mappings through the TLB, this is the
hook where those TLB entries can be invalidated.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
This adds implementations of __raw_read[bwl] and __raw_write[bwl] to
m68k, ppc, nios and nios2. The m68k and ppc implementations were taken
from Linux.
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command
is fully finished. The sync() is defined in each CPU's io.h file. For
those CPUs which do not need sync for now, a dummy sync() is defined in
their io.h as well.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Patch by Shlomo Kut, 13 Dec 2004
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
* Minor code cleanup
for more information
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
