path: root/include/asm-mips
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-20MIPS: qemu_mips: Import asm/unaligned.h from the Linux kernelShinya Kuribayashi
with a few adjustments for U-Boot. This fixes the following build error: make -C lib_generic/ zlib.c:31:27: error: asm/unaligned.h: No such file or directory zlib.c: In function 'inflate_fast': zlib.c:641: warning: implicit declaration of function 'get_unaligned' make[1]: *** [zlib.o] Error 1 make[1]: Leaving directory `/home/skuribay/git/u-boot.git/lib_generic' make: *** [lib_generic/libgeneric.a] Error 2 Reported-by: Himanshu Chauhan <himanshu@symmetricore.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-09-17Correct ffs/fls regression for PowerPC etcSimon Kagstrom
Commits 02f99901ed1c9d828e3ea117f94ce2264bf8389e 52d61227b66d4099b39c8309ab37cb67ee09a405 introduced a regression where platform-specific ffs/fls implementations were defined away. This patch corrects that by using PLATFORM_xxx instead of the name itself. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de>
2009-09-15Move __set/clear_bit from ubifs.h to bitops.hSimon Kagstrom
__set_bit and __clear_bit are defined in ubifs.h as well as in asm/include/bitops.h for some architectures. This patch moves the generic implementation to include/linux/bitops.h and uses that unless it's defined by the architecture. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-05-16MIPS: Make all extern-ed functions in bitops.h staticShinya Kuribayashi
All these functions are expected to be static inline-ed. This patch also fixes the following build warnings on MIPS targets: include/asm/bitops.h: In function 'ext2_find_next_zero_bit': include/asm/bitops.h:862: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static include/asm/bitops.h:885: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static include/asm/bitops.h:887: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-03-20remove bi_enet*addr from global data for all archesMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-02-22MIPS: Fix GCC-4.2 'discards qualifiers from pointer target type' warningsShinya Kuribayashi
Compiling dbau1x00 and gth2 boards with GCC-4.2, you would see new warnings like this: skuribay@ubuntu:u-boot.git$ ./MAKEALL dbau1000 Configuring for dbau1x00 board... au1x00_eth.c: In function 'au1x00_send': au1x00_eth.c:158: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type au1x00_eth.c: In function 'au1x00_recv': au1x00_eth.c:211: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type au1x00_eth.c: In function 'au1x00_init': au1x00_eth.c:252: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type au1x00_eth.c: In function 'au1x00_recv': au1x00_eth.c:211: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type au1x00_eth.c: In function 'au1x00_init': au1x00_eth.c:252: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type au1x00_eth.c: In function 'au1x00_send': au1x00_eth.c:158: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type We're passing a volatile pointer to a function which is expecting a non- volatile pointer. That's potentially dangerous, so gcc warns about it. Confirmed with ELDK 4.2 (GCC 4.2.2) and Sourcey G++ 4.2 (GCC 4.2.3). To fix this, we add a volatile attribute to the argument in question. The virt_to_phys function in Linux kernel also does the same thing. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2009-02-10Add an architecture specific config.h for common definesKumar Gala
We have common defines that we duplicate in various ways. Having an arch specific config.h gives us a common location for those defines. Eventually we should be able to replace this when we have proper Kconfig support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-15Introduce virt_to_phys()Kumar Gala
virt_to_phys() returns the physical address given a virtual. In most cases this will be just the input value as the vast majority of systems run in a 1:1 mode. However in systems that are not running this way it should report the physical address or ~0 if no mapping exists for the given virtual address. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-06Allow console input to be disabledMark Jackson
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE. When CONFIG_DISABLE_CONSOLE is defined, setting GD_FLG_DISABLE_CONSOLE disables all console input and output. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-07[MIPS] Rename Alchemy processor configs into CONFIG_SOC_*Shinya Kuribayashi
CONFIG_SOC_AU1X00 Common Alchemy Au1x00 stuff. All Alchemy processor based machines need to have this config as a system type specifier. CONFIG_SOC_AU1000, CONFIG_SOC_AU1100, CONFIG_SOC_AU1200, CONFIG_SOC_AU1500, CONFIG_SOC_AU1550 Machine type specifiers. Each port should have one of aboves. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-06-05[MIPS] Update <asm/addrspace.h> headerShinya Kuribayashi
- Fix traditional KSEG names - Replace PHYSADDR with CPHYSADDR Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-05-30mips: Add an 'include/asm/errno.h', like all other architecturesJason McMullan
All other u-boot architectures have an include/asm/errno.h, so this change adds it to the mips include/asm-mips headers also. Stolen from Linux 2.6.25. Signed-off-by: Jason McMullan <mcmullan@netapp.com>
2008-05-30[MIPS] <asm/mipsregs.h>: Update coprocessor register access macrosShinya Kuribayashi
2008-05-30[MIPS] <asm/mipsregs.h>: Update register / bit field definitionsShinya Kuribayashi
2008-05-30[MIPS] <asm/mipsregs.h>: CodinygStyle cleanupsShinya Kuribayashi
No functional changes. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-20POST: replace the LOGBUFF_INITIALIZED flag in gd->post_log_word (1 << 31) ↵Yuri Tikhonov
with the GD_FLG_LOGINIT flag in gd->flags. This way we become able to utilize the full post_log_word for POST activities (overwise, POST ECC, which has 0x8000 ID, could be erroneously treated as started in post_output_backlog() even if there was actually no POST ECC run (because of OCM POST failure, for example). Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-13Introduce phys_size_t and move phys_addr_t into asm/types.hKumar Gala
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's that have larger physical addresses like 44x, 85xx, and 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-25[MIPS] Introduce _machine_restartShinya Kuribayashi
Handles machine specific functions by using weak functions. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-25[MIPS] cpu/mips/cache.S: Introduce NESTED/LEAF/END macrosShinya Kuribayashi
This patch replaces the current function definitions with NESTED, LEAF and END macro. They specify some more additional information about the function; an alignment of symbol, type of symbol, stack frame usage, etc. These information explicitly tells the assembler and the debugger about the types of code we want to generate. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-25[MIPS] asm headers' updatesShinya Kuribayashi
Make some asm headers adjusted to the latest Linux kernel. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-02-23Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit ↵Shinya Kuribayashi
targets. ---------------------------------------------------------------- Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)] Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> ---------------------------------------------------------------- Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-12-13Introduce map_physmem() and unmap_physmem()Haavard Skinnemoen
map_physmem() returns a virtual address which can be used to access a given physical address without involving the cache. unmap_physmem() should be called when the virtual address returned by map_physmem() is no longer needed. This patch adds a stub implementation which simply returns the physical address cast to a uchar * for all architectures except AVR32, which converts the physical address to an uncached virtual mapping. unmap_physmem() is a no-op on all architectures, but if any architecture needs to do such mappings through the TLB, this is the hook where those TLB entries can be invalidated. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-01Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2007-10-24Mips: Fix string functions differ prototype declarationJean-Christophe PLAGNIOL-VILLARD
2007-10-21[MIPS] Fix UNCACHED_SDRAMVlad Lungu
PHYSADDR is for physical address, KSEG1ADDR is for uncached. Signed-off-by: Vlad Lungu <vlad@comsys.ro> Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07[MIPS] Remove inline asm string functionsShinya Kuribayashi
Stop using inline string functions on MIPS as other ARCHs do so, since the optimized inline asm versions are not small. This change is triggered by a following MIPS build error: common/libcommon.a(exports.o)(.text+0xdc): In function `jumptable_init': common/exports.c:32: undefined reference to `strcmp' make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07[MIPS] Update asm string headerShinya Kuribayashi
This patches contains several bugfixes and cleanups in the latest upstream: - Don't include linux/config.h - Remove buggy inline version of memscan. - Merge with Linux 2.6.11-rc3. - Fix undefined reference to strcpy in binfmt_misc caused by gcc 3.4. - Goodbye mips64. 31704 lines of code bite the dust. - Replace extern inline with static inline. - Fix return value of strncpy. - Remove a bunch more "$1" clobbers. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-02-21[PATCH v3] Add sync to ensure flash_write_cmd is fully finishedHaiying Wang
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command is fully finished. The sync() is defined in each CPU's io.h file. For those CPUs which do not need sync for now, a dummy sync() is defined in their io.h as well. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2006-06-16Add support for gth2 boardWolfgang Denk
Patch by Thomas Lange, Aug 11 2005
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2005-01-09* Patch by Leif Lindholm, 23 Sep 2004:wdenk
add support for the AMD db1550 board * Patch by Travis Sawyer, 15 Sep 2004: Add CONFIG_SERIAL_MULTI support for ppc4xx, update README.serial_multi
2004-02-07* Patch by liang a lei, 9 Jan 2004:wdenk
Fix Intel 28F128J3 ID in include/flash.h * Patch by Masami Komiya, 09 Jan 2004: add support for TB0229 board (NEC VR4131 MIPS processor) * Patch by Leon Kukovec, 12 Dec 2003: changed extern __inline__ into static __inline__ in include/linux/byteorder/swab.h
2004-01-04* Make BMS2003 use a separate config file to avoid #ifdef mess;wdenk
add I2C support; add support for DS1337 RTC * Add CompactFlash support for BMS2003 board * Add support for status LED on BMS2003 board
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-10-09* Patch by Steven Scholz, 10 Oct 2003LABEL_2003_10_09_2320wdenk
- Add support for Altera FPGA ACEX1K * Patches by Thomas Lange, 09 Oct 2003: - Endian swap ATA identity for all big endian CPUs, not just PPC - MIPS only: New option CONFIG_MEMSIZE_IN_BYTES for passing memsize args to linux - add support for dbau1x00 board (MIPS32)
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-27* Add support for MIPS32 4Kc CPUswdenk
* Add support for INCA-IP Board
