path: root/include/asm-mips/string.h
2007-10-24Mips: Fix string functions differ prototype declarationJean-Christophe PLAGNIOL-VILLARD
2007-09-07[MIPS] Remove inline asm string functionsShinya Kuribayashi
Stop using inline string functions on MIPS as other ARCHs do so, since the optimized inline asm versions are not small. This change is triggered by a following MIPS build error: common/libcommon.a(exports.o)(.text+0xdc): In function `jumptable_init': common/exports.c:32: undefined reference to `strcmp' make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-09-07[MIPS] Update asm string headerShinya Kuribayashi
This patches contains several bugfixes and cleanups in the latest upstream: - Don't include linux/config.h - Remove buggy inline version of memscan. - Merge with Linux 2.6.11-rc3. - Fix undefined reference to strcpy in binfmt_misc caused by gcc 3.4. - Goodbye mips64. 31704 lines of code bite the dust. - Replace extern inline with static inline. - Fix return value of strncpy. - Remove a bunch more "$1" clobbers. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
