Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command
is fully finished. The sync() is defined in each CPU's io.h file. For
those CPUs which do not need sync for now, a dummy sync() is defined in
their io.h as well.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Identification Register (CIR).
relocate ichache_State to ram
u-boot can run from internal flash
Add EB+MCF-EV123 board support.
Add m68k Boards to MAKEALL
Patch from Jens Scharsig, 08 Aug 2005
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3).
Set flash base accordingly, and decide whether to do or skip board
specific setup steps.
* Patch by Josef Baumgartner, 26 May 2004:
Add missing define in include/asm-m68k/global_data.h
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
