path: root/include/asm-m68k
2007-08-16ColdFire: MCF52x2 Header files updateTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: MCF5329 header file clean upTsiChungLiew
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-08Added NAND supportTsiChungLiew
2007-08-08Added I2C supportTsiChungLiew
2007-08-08Changed CFG_CLK to gd->bus_clk for CFG_TIMER_PRESCALER. Added ↵TsiChungLiew
DECLARE_GLOBAL_DATA_PTR for time.c Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-08Moved sync() from board file to include/asm-m68k/io.hTsiChungLiew
2007-07-16Coding style cleanupStefan Roese
2007-07-10New uart structure and definesTsiChungLiew
Seperated from mcfuart.h Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10New timer structure and definesTsiChungLiew
Seperated from mcftimer.h Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Rename mcfrtc to rtcTsiChungLiew
Since it is already in m68k folder, un-necessary to pad mcf. Replaced immap_5329.h and m5329.h to immap.h Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Seperate old structure defines and new structure definesTsiChungLiew
Removed new uart structure and defines to uart.h Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
New timer structure and defines will move to new timer.h Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Clean upTsiChungLiew
Removed whitespace Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Replaced whitespace with tabs Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Create new header file and move peripherals base address from configs file ↵TsiChungLiew
to new header file. Create new header file to include immap_5xxx.h and m5xxx.h and to share among drivers without update in driver file each processor is added. Moved peripherals base address and defines from configs file to immap.h. Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-06-18Added M5329AFEE and M5329BFEE PlatformsTsiChung Liew
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net, drivers/serial, immap_5329.h, m5329.h, mcfrtc.h, include/configs/M5329EVB.h, lib_m68k/interrupts.c, and rtc/mcfrtc.c Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c, common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h, include/asm-m68k/io.h, include/asm-m68k/mcftimer.h, include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h, include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c, lib_m68k/time.c, net/eth.c and rtc/Makefile Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2007-02-21[PATCH v3] Add sync to ensure flash_write_cmd is fully finishedHaiying Wang
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command is fully finished. The sync() is defined in each CPU's io.h file. For those CPUs which do not need sync for now, a dummy sync() is defined in their io.h as well. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-01-23[ColdFire MCF5271 family] Add CPU detection based on the value of ChipBartlomiej Sieka
Identification Register (CIR).
2006-06-10Minor code cleanup.Wolfgang Denk
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-05-09Update register definitions for MCF5271.Marian Balakowicz
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
2006-01-26Add support for r5200 boardZachary P. Landau
2006-01-26Add support for Freescale M5271 processorZachary P. Landau
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2004-12-16Code cleanup.wdenk
2004-12-16Coldfire MCF5249 support addedstroese
2004-06-09* Patch by Imre Deak, 26 May 2004:wdenk
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3). Set flash base accordingly, and decide whether to do or skip board specific setup steps. * Patch by Josef Baumgartner, 26 May 2004: Add missing define in include/asm-m68k/global_data.h
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-12-08* Patch by Bernhard Kuhn, 28 Nov 2003:wdenk
add support for Coldfire CPU add support for Motorola M5272C3 and M5282EVB boards
