This patch originally from LogicPD OMAP35x Release 1.5.0
Original Patch Name: u-boot-1.1.4-omap3430-labrador.patch
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3).
Set flash base accordingly, and decide whether to do or skip board
specific setup steps.
* Patch by Josef Baumgartner, 26 May 2004:
Add missing define in include/asm-m68k/global_data.h
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
