This helps to clean up the include/ directory so that it only contains
non-architecture-specific headers and also matches Linux's directory
layout which many U-Boot developers are already familiar with.
The compile error was caused by a recent patch. Affected platforms -
M5253DEMO.h, M5253EVBE.h, and M54455EVB.h. Adding the _IO_BASE
automatically defined to 0 in asm-m68k/io.h if it isn't set in
platform configuration file.
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
virt_to_phys() returns the physical address given a virtual. In most
cases this will be just the input value as the vast majority of
systems run in a 1:1 mode.
However in systems that are not running this way it should report the
physical address or ~0 if no mapping exists for the given virtual
address.
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's
that have larger physical addresses like 44x, 85xx, and 86xx.
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
map_physmem() returns a virtual address which can be used to access a
given physical address without involving the cache. unmap_physmem()
should be called when the virtual address returned by map_physmem() is
no longer needed.
This patch adds a stub implementation which simply returns the
physical address cast to a uchar * for all architectures except AVR32,
which converts the physical address to an uncached virtual mapping.
unmap_physmem() is a no-op on all architectures, but if any
architecture needs to do such mappings through the TLB, this is the
hook where those TLB entries can be invalidated.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
This adds implementations of __raw_read[bwl] and __raw_write[bwl] to
m68k, ppc, nios and nios2. The m68k and ppc implementations were taken
from Linux.
Removed whitespace
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net,
drivers/serial, immap_5329.h, m5329.h, mcfrtc.h,
include/configs/M5329EVB.h, lib_m68k/interrupts.c, and
rtc/mcfrtc.c
Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c,
common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h,
include/asm-m68k/io.h, include/asm-m68k/mcftimer.h,
include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h,
include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c,
lib_m68k/time.c, net/eth.c and rtc/Makefile
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command
is fully finished. The sync() is defined in each CPU's io.h file. For
those CPUs which do not need sync for now, a dummy sync() is defined in
their io.h as well.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
