This helps to clean up the include/ directory so that it only contains
non-architecture-specific headers and also matches Linux's directory
layout which many U-Boot developers are already familiar with.
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE.
When CONFIG_DISABLE_CONSOLE is defined, setting
GD_FLG_DISABLE_CONSOLE disables all console input and output.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Currently, both are defined as an unsigned long, but
should be phys_size_t. This should result in no real change,
since phys_size_t is currently an unsigned long for all the
default configs. Also add print_lnum to cmd_bdinfo to deal
with the potentially wider memsize.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
with the GD_FLG_LOGINIT flag in gd->flags.
This way we become able to utilize the full post_log_word for POST
activities (overwise, POST ECC, which has 0x8000 ID, could be
erroneously treated as started in post_output_backlog() even if there
was actually no POST ECC run (because of OCM POST failure, for
example).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Don't run futher tests in case of a test fails that is marked as
POST_STOP.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Signed-off-by: Luigi Comio Mantellini <luigi.mantellini@idf-hit.com>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
On OMAP1610 platforms check if booting from RAM(CS0) or flash(CS3).
Set flash base accordingly, and decide whether to do or skip board
specific setup steps.
* Patch by Josef Baumgartner, 26 May 2004:
Add missing define in include/asm-m68k/global_data.h
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
add support for Coldfire CPU
add support for Motorola M5272C3 and M5282EVB boards
