path: root/include/asm-i386
2009-03-20Implement SC520 timersGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rewrite i386 interrupt handlingGraeme Russ
Rewrite interrupt handling functionality for the i386 port. Separated functionality into separate CPU and Architecture components. It appears as if the i386 interrupt handler functionality was intended to allow multiple handlers to be installed for a given interrupt. Unfortunately, this functionality was not fully implemented and also had the problem that irq_free_handler() does not allow the passing of the handler function pointer and therefore could never be used to free specific handlers that had been installed for a given IRQ. There were also various issues with array bounds not being fully tested. I had two objectives in mind for the new implementation: 1) Keep the implementation as similar as possible to existing implementations. To that end, I have used the leon2/3 implementations as the reference 2) Seperate CPU and Architecture specific elements. All specific i386 interrupt functionality is now in cpu/i386/ with the high level API and architecture specific code in lib_i386. Functionality specific to the PC/AT architecture (i.e. cascaded i8259 PICs) has been further split out into an individual file to allow for the implementation of the PIC architecture of the SC520 CPU (supports more IRQs) Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Move ali512x.hGraeme Russ
Moved ali512x.h from include/asm-i386/ic/ to /include Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20remove bi_enet*addr from global data for all archesMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-02-10Add an architecture specific config.h for common definesKumar Gala
We have common defines that we duplicate in various ways. Having an arch specific config.h gives us a common location for those defines. Eventually we should be able to replace this when we have proper Kconfig support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-24Moved definition of set_vector() to new header fileGraeme Russ
This allows for future tidy ups and functionality that will require set_vector () Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-12-15Introduce virt_to_phys()Kumar Gala
virt_to_phys() returns the physical address given a virtual. In most cases this will be just the input value as the vast majority of systems run in a 1:1 mode. However in systems that are not running this way it should report the physical address or ~0 if no mapping exists for the given virtual address. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-12-10Moved sc520 PCI definitions to stand-alone fileGraeme Russ
Signed Off By: Graeme Russ <graeme.russ@gmail.com>
2008-09-09Update i386 code (sc520_cdp)Graeme Russ
Attempt to bring i386 / sc520 inline with master Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-09-06Allow console input to be disabledMark Jackson
Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE. When CONFIG_DISABLE_CONSOLE is defined, setting GD_FLG_DISABLE_CONSOLE disables all console input and output. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-20POST: replace the LOGBUFF_INITIALIZED flag in gd->post_log_word (1 << 31) ↵Yuri Tikhonov
with the GD_FLG_LOGINIT flag in gd->flags. This way we become able to utilize the full post_log_word for POST activities (overwise, POST ECC, which has 0x8000 ID, could be erroneously treated as started in post_output_backlog() even if there was actually no POST ECC run (because of OCM POST failure, for example). Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-13Introduce phys_size_t and move phys_addr_t into asm/types.hKumar Gala
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's that have larger physical addresses like 44x, 85xx, and 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-12Merge branch 'master' of git://www.denx.de/git/u-boot into new-imageMarian Balakowicz
2008-03-02Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit ↵Shinya Kuribayashi
targets. The previous patch was lacking of i386, microblaze, nios and nios2. This patch tries to fix them. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-07[new uImage] Remove I386 uImage fake_header() routineMarian Balakowicz
I386 targets are not using a uImage format, instead fake header is added to ram image before it is further processed by bootm. Remove this fixup and force proper uImage use for I386. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-12-13Introduce map_physmem() and unmap_physmem()Haavard Skinnemoen
map_physmem() returns a virtual address which can be used to access a given physical address without involving the cache. unmap_physmem() should be called when the virtual address returned by map_physmem() is no longer needed. This patch adds a stub implementation which simply returns the physical address cast to a uchar * for all architectures except AVR32, which converts the physical address to an uncached virtual mapping. unmap_physmem() is a no-op on all architectures, but if any architecture needs to do such mappings through the TLB, this is the hook where those TLB entries can be invalidated. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-02-21[PATCH v3] Add sync to ensure flash_write_cmd is fully finishedHaiying Wang
Some CPUs like PPC, BLACKFIN need sync() to ensure cfi flash write command is fully finished. The sync() is defined in each CPU's io.h file. For those CPUs which do not need sync for now, a dummy sync() is defined in their io.h as well. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2005-11-25Remove unnnecessary #include <linux/types.h> from include/asm-*/u-boot.hWolfgang Denk
2003-10-10Added config option CONFIG_SILENT_CONSOLE. See doc/README.silentLABEL_2003_10_10_1200wdenk
for more information
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-11-19* Patch by Daniel Engström, 18 Nov 2002:wdenk
Fixes for x86 port (mostly strings issues) * Patch by Ken Chou, 18 Nov 2002: Fix for natsemi NIC cards (DP83815) * Patch by Pierre Aubert, 19 Nov 2002: fix a bug for the MII configuration, and some warnings
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
