path: root/include/asm-i386/zimage.h
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-02-07[new uImage] Remove I386 uImage fake_header() routineMarian Balakowicz
I386 targets are not using a uImage format, instead fake header is added to ram image before it is further processed by bootm. Remove this fixup and force proper uImage use for I386. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
