This helps to clean up the include/ directory so that it only contains
non-architecture-specific headers and also matches Linux's directory
layout which many U-Boot developers are already familiar with.
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's
that have larger physical addresses like 44x, 85xx, and 86xx.
targets.
The previous patch was lacking of i386, microblaze, nios and nios2. This
patch tries to fix them.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
