path: root/include/asm-generic
2017-07-27spl: make SPL and normal u-boot stage use independent SYS_MALLOC_F_LENAndy Yan
Some platforms have very limited SRAM to run SPL code, so there may not be the same amount space for a malloc pool before relocation in the SPL stage as the normal U-Boot stage. Make SPL and (the full) U-Boot stage use independent SYS_MALLOC_F_LEN, so the size of pre-relocation malloc pool can be configured memory space independently. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up commit-message:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-08powerpc: Partialy restore core of mpc8xxChristophe Leroy
CS Systemes d'Information (CSSI) manufactures 8xx boards for critical communication systems. Those boards have been running U-Boot since 2010 and will have to be maintained until at least 2027. commit 5b8e76c35ec312a3f73126bd1a2d2c0965b98a9f ("powerpc, 8xx: remove support for 8xx") orphaned those boards by removing support for the mpc8xx CPU. This commit partially restores support for the 8xx, with the following limitations: - Restores support for MPC866 and MPC885 only - Does not restore IDE, PCMCIA, I2C, USB - Does not restore examples - Does not restore POST - Does not restore Ethernet on SCC - Does not restore console on SCC - Does not restore bedbug and kgdb support As the 866 and 885 do not support the following features, they are not restored either: - VIDEO / LCD - RTC clock The CPM uCODE patch is not restored either, because: - 866 and 885 already have support for I2C and SPI relocation without a uCODE patch - relocation of SMC, I2C or SPI is only needed for using SCCs for Ethernet or QMC The dynamic setup/calculation of clocks is removed, we expect the target being use with the clock and PLPRCR register defined in the configuration. All the clock settings for 8xx prior to 866 is removed as well as we now only support 866 and 885. This code is mature and addresses mature boards. Therefore all code enclosed in '#if 0/#endif' and '#if XX_DEBUG/#endif' is unneeded. The following files are not restored by this patch: - arch/powerpc/cpu/mpc8xx/bedbug_860.c - arch/powerpc/cpu/mpc8xx/fec.h - arch/powerpc/cpu/mpc8xx/kgdb.S - arch/powerpc/cpu/mpc8xx/plprcr_write.S - arch/powerpc/cpu/mpc8xx/scc.c - arch/powerpc/cpu/mpc8xx/upatch.c - arch/powerpc/cpu/mpc8xx/video.c - arch/powerpc/include/asm/status_led.h - arch/powerpc/lib/ide.c - arch/powerpc/lib/ide.h - doc/README.MPC866 - drivers/pcmcia/mpc8xx_pcmcia.c - drivers/rtc/mpc8xx.c - drivers/usb/gadget/mpc8xx_udc.c - drivers/video/mpc8xx_lcd.c - examples/standalone/test_burst.c - examples/standalone/test_burst.h - examples/standalone/test_burst_lib.S - examples/standalone/timer.c - include/mpc823_lcd.h - include/usb/mpc8xx_udc.h - post/cpu/mpc8xx/Makefile - post/cpu/mpc8xx/cache.c - post/cpu/mpc8xx/cache_8xx.S - post/cpu/mpc8xx/ether.c - post/cpu/mpc8xx/spr.c - post/cpu/mpc8xx/uart.c - post/cpu/mpc8xx/usb.c - post/cpu/mpc8xx/watchdog.c Some of the restored files are not located in a proper location. In order to keep traceability of the changes, they will be moved to their correct location and moved to Kconfig in a followup patch. This patch also declares CSSI as point of contact for the update of the 8xx platform, as those boards are the only ones still being maintained on the 8xx area. A later patch will add those boards to the tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 5xx: remove support for 5xxHeiko Schocher
There was for long time no activity in the 5xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 5xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8260: remove support for mpc8260Heiko Schocher
There was for long time no activity in the 8260 area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8260, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-05bootstage: Support relocating boostage dataSimon Glass
Some boards cannot access pre-relocation data after relocation. Reserve space for this and copy it during preparation for relocation. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-05bootstage: Convert to use malloc()Simon Glass
At present bootstage uses the data section of the image to store its information. There are a few problems with this: - It does not work on all boards (e.g. those which run from flash before relocation) - Allocated strings still point back to the pre-relocation data after relocation Now that U-Boot has a pre-relocation malloc() we can use this instead, with a pointer to the data in global_data. Update bootstage to do this and set up an init routine to allocate the memory. Now that we have a real init function, we can drop the fake 'reset' record and add a normal one instead. Note that part of the problem with allocated strings remains. They are reallocated but this will only work where pre-relocation memory is accessible after relocation. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: gpio: Add live tree supportSimon Glass
Add support for requesting GPIOs with a live device tree. This involves adjusting the function signature for the legacy function gpio_request_by_name_nodev(), so fix up all callers. Signed-off-by: Simon Glass <sjg@chromium.org> Fixes to stm32f746-disco.c: Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-01dm: gpio: Drop blank line in gpio_xlate_offs_flags() commentSimon Glass
This is not needed. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: gpio: Refactor to prepare for live tree supportSimon Glass
Move the main part of the GPIO request function into a separate function so that it can be used by the live tree function when added. Update the xlate method to use a node reference. Update all GPIO drivers to handle the modified xlate() method. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-06-01dm: core: Add livetree definitionsSimon Glass
Add a Kconfig option to enable a live device tree, built at run time from the flat tree. Also add structure definitions and a root node. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-12asm-generic: global_data: change timebase_l/h to unsigned intPeng Fan
Change type of timebase_l/h to unsigned int. >From lib/time.c: ((uint64_t)gd->timebase_h << 32) | gd->timebase_l; This piece code is based on that timebase_h and timebase_l are 32bits width, so change the type to unsigned int. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Eddie Cai <eddie.cai.linux@gmail.com> Cc: Jagan Teki <jteki@openedev.com> Cc: York Sun <york.sun@nxp.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-16spl: Add spl_early_init()Eddie Cai
At present malloc_base/_limit/_ptr are not initialised in spl_init() when we call spl_init() in board_init_f(). This is due to a recent change aimed at avoiding overwriting the malloc area set up on some boards by spl_relocate_stack_gd(). However if CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN is not defined, we now skip setting up the memory area in spl_init() which is obviously wrong. To fix this, add a new function spl_early_init() which can be called in board_init_f(). Fixes: b3d2861e (spl: Remove overwrite of relocated malloc limit) Signed-off-by: Eddie Cai <eddie.cai.linux@gmail.com> Rewrote spl_{,early_}init() to avoid duplicate code: Rewrite/expand commit message: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Eddie Cai <eddie.cai.linux@gmail.com>
2016-11-14efi: Add support for a hello world test programSimon Glass
It is useful to have a basic sanity check for EFI loader support. Add a 'bootefi hello' command which loads HelloWord.efi and runs it under U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> [agraf: Fix documentation, add unfulfilled kconfig dep] Signed-off-by: Alexander Graf <agraf@suse.de>
2016-10-23Convert CONSOLE_PRE_CONSOLE_BUFFER options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-10-11Add _image_binary_end section declarationSimon Glass
This is used in some link scripts, so add a declaration for it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-23Move error macros from <asm-generic/errno.h> to <linux/errno.h>Masahiro Yamada
There are no files that include <asm-generic/errno.h> any more. Move error macro defines to include/linux/errno.h and remove include/asm-generic/errno.h. Going forward, please include <linux/errno.h> when you need error macros. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-07global_data.h: Standardize tabs and alignment for commentsRobert P. J. Day
Line up comments for readibility. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2016-07-15armv8: Move secure_ram variable out of generic global dataYork Sun
Secure_ram variable was put in generic global data. But only ARMv8 uses this variable. Move it to ARM specific data structure. Signed-off-by: York Sun <york.sun@nxp.com>
2016-06-06Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-06-06env: Setup GD_FLG_ENV_DEFAULT flag when default environment are usedMichal Simek
Setup flag when default environment are used to be able to rewrite default distro boot variables based on SoC boot mode. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-06-03dm: gpio: Add methods for open drain settingmario.six@gdsys.cc
Certain GPIO devices have the capability to switch their GPIOs into open-drain mode, that is, instead of actively driving the output (Push-pull output), the pin is connected to the collector (for a NPN transistor) or the drain (for a MOSFET) of a transistor, respectively. The pin then either forms an open circuit or a connection to ground, depending on the state of the transistor. This patch adds functions to the GPIO uclass to switch GPIOs to open-drain mode on devices that support it. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-17dm: gpio: add a default gpio xlate routineEric Nelson
Many drivers use a common form of offset + flags for device tree nodes. e.g.: <&gpio1 2 GPIO_ACTIVE_LOW> This patch adds a common implementation of this type of parsing and calls it when a gpio driver doesn't supply its' own xlate routine. This will allow removal of the driver-specific versions in a handful of drivers and simplify the addition of new drivers. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-17gpio: Use const where possibleSimon Glass
Some functions do not change the struct gpio_desc parameter. Update these to use const so this is clear. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17gpio: Add a function to obtain a GPIO vector valueSimon Glass
We can use GPIOs as binary digits for reading 'strapping' values. Each GPIO is assigned a single bit and can be set high or low on the circuit board. We already have a legacy function for reading these values. Add one that supports driver model. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-08Remove unused CONFIG_MODEM_SUPPORT option and associated dead code.David Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-01-20dm: common: Add memory reservation for the video uclassSimon Glass
Before relocation we need to reserve memory for the video driver frame buffers so that they can use this memory when they start up (after relocation). Add a call to the uclass to permit this. The current top and bottom of the region is stored in global_data so that it can be checked post-relocation to ensure enough memory is available. No video device should be probed before relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-12-15Reserve secure memoryYork Sun
Secure memory is at the end of memory, separated and reserved from OS, tracked by gd->secure_ram. Secure memory can host MMU tables, security monitor, etc. This is different from PRAM used to reserve private memory. PRAM offers memory at the top of u-boot memory, not necessarily the real end of memory for systems with very large DDR. Using the end of memory simplifies MMU setup and avoid memory fragmentation. "bdinfo" command shows gd->secure_ram value if this memory is marked as secured. Signed-off-by: York Sun <yorksun@freescale.com>
2015-11-19console: Add a console bufferSimon Glass
It is useful to be able to record console output and provide console input via a buffer. This provides sandbox with the ability to run a command and check its output. If the console is set to silent then no visible output is generated. This also provides a means to fix the problem where tests produce unwanted output, such as errors or warnings. This can be confusing. We can instead set the console to silent and record this output. It can be checked later in the test if required. It is possible that this may prove useful for non-test situations. For example the console output may be suppressed for normal operations, but recorded and stored for access by the OS. That feature is not implemented at present. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-05include: Add generic bitops headersFabio Estevam
Use the generic bitops header files from the kernel. Imported from kernel 4.2.3. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-04dm: spl: Support device tree when BSS is in a different sectionSimon Glass
At present in SPL we place the device tree immediately after BSS. This avoids needing to copy it out of the way before BSS can be used. However on some boards BSS is not placed with the image - e.g. it can be in RAM if available. Add an option to tell U-Boot that the device tree should be placed at the end of the image binary (_image_binary_end) instead of at the end of BSS. Note: A common reason to place BSS in RAM is to support the FAT filesystem. We should update the code so that it does not use so much BSS. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-23dm: implement a Timer uclassThomas Chou
Implement a Timer uclass to work with lib/time.c. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21linux/bitops.h: GENMASK copy from linuxJagan Teki
GENMASK is used to create a contiguous bitmask([hi:lo]). This patch is a copy from Linux, with below commit details "bitops: Fix shift overflow in GENMASK macros" (sha1: 00b4d9a14125f1e51874def2b9de6092e007412d) Cc: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-08-17Revert "Align global_data to a 16-byte boundary"Simon Glass
This causes widespread breakage due to the operation of the low-level code in crt0.S and cro0_64.S for ARM at least. The fix is not complicated but it seems safer to revert this for now. This reverts commit 2afddae07523f23f77acd066ad1719f53d289f98. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-14Align global_data to a 16-byte boundarySimon Glass
Some archs like to have larger alignment for their global data. Use 16 bytes which suits all current archs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14common: Display >=4GiB memory bank sizeBin Meng
bd->bi_dram[] has both start address and size defined as 32-bit, which is not the case on some platforms where >=4GiB memory bank is used. Change them to support such memory banks. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Add a way to skip relocationSimon Glass
When running U-Boot as an EFI application we cannot relocate since we do not have relocation information. U-Boot has already been relocated to a suitable address. Add a global_data flag to control skipping relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Reserve the top 16 flag bits for architecture-specific useSimon Glass
Add a convention that the generic global_data only occupy the bottom 16 bits of the flags word, so that there is less chance of a conflict. At present the x86 flags conflict. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-21dm: spl: Allow device tree/driver model in board_init_f()Simon Glass
Add an spl_init() function that does basic init such that board_init_f() can use simple malloc(), device tree and driver model. Each one is set up only if enabled for SPL. Note: We really should refactor SPL such that there is a single board_init_f() and rename the existing weak board_init_f() functions provided by boards, calling them from the single board_init_f(). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_request() to manually request a GPIOSimon Glass
This function can be used for testing to manually request a GPIO for use, without resorting to the legacy GPIO API. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_lookup_name() to look up a GPIO nameSimon Glass
Provide a driver-model function to look up a GPIO name. Make the standard function use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-14dm: x86: baytrail: Correct PCI region 3 when driver model is usedSimon Glass
Commit afbbd413a fixed this for non-driver-model. Make sure that the driver model code handles this also. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-04gpio: fix typos in GPIO headerMasahiro Yamada
2015-05-14dm: gpio: Fix comment typo in GPIOD_IS_INSimon Glass
This should say 'in', not 'out'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-13dm: gpio: Add error handling and a function to claim vector GPIOsSimon Glass
gpio_get_values_as_int() should return an error if something goes wrong. Also provide gpio_claim_vector(), a function to request the GPIOs and set them to input mode. Otherwise callers have to do this themselves. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
