The simple malloc() implementation is used when memory is tight. It provides
a simple buffer with an incrementing pointer.
At present the implementation is inside dlmalloc. Move it into its own file
so that it is easier to find.
Rather than using relocation as a signal that the full malloc() is
available, add a special GD_FLG_FULL_MALLOC_INIT flag. This signals that the
simple malloc() should no longer be used.
In some cases, such as SPL, even the code space used by the full malloc() is
wasteful. Add a CONFIG_SYS_MALLOC_SIMPLE option to provide only the simple
malloc. In this case the full malloc is not available at all. It saves about
1KB of code space and about 0.5KB of data on Thumb 2.
Acked-by: Tom Rini <trini@ti.com>
Remove this board as this is the only one last user of eeprom_probe(),
which is pretty non-standard stuff.
This patch also removes all the PHP, SQL and CSS stuff from U-Boot,
which probably makes U-Boot a bit less IoT ;-)
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Tom Rini <trini@ti.com>
Fix a trivial conflict over adding <dm.h>
arch/arm/cpu/armv7/omap3/board.c
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
This is no longer used so drop it.
Add a helper which permits a printf()-style format string for the requester
string.
This function can be more easily tested if it is in the uclass.
Add helpers to the uclass to allow finding out the pin function.
We have several GPIO drivers now and all are doing similar things to record
which GPIOs are reserved.
Move this logic into the uclass to make the drivers similar.
We retain the request()/free() methods since currently one driver does use
these for setting up the pin.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The GPIO list is very long in many cases and most of them are not used.
By default, show only the GPIOs that are in use, and provide a flag to show
all of them. This makes the 'gpio status' command much more pleasant.
In order to do this, driver model now exposes a method for obtaining the
'function' of a GPIO, which describes whether it is an input or output, for
example. Implementation of this method is optional.
For sandbox we have a fallback console which is used very early in
U-Boot, before serial drivers are available. Rather than try to guess
when to switch to the real console, add a flag so we can be sure. This
makes sure that sandbox can always output a panic() message, for example,
and avoids silent failure (which is very annoying in sandbox).
Initialise devices marked 'pre-reloc' and make them available prior to
relocation. Note that this requires pre-reloc malloc() to be available.
If we are to have driver model before relocation we need to support some
way of calling memory allocation routines.
The standard malloc() is pretty complicated:
1. It uses some BSS memory for its state, and BSS is not available before
relocation
2. It supports algorithms for reducing memory fragmentation and improving
performace of free(). Before relocation we could happily just not support
free().
3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since
this has been loaded anyway this is not really a problem.
The simplest way to support pre-relocation malloc() is to reserve an area
of memory and allocate it in increasing blocks as needed. This
implementation does this.
To enable it, you need to define the size of the malloc() pool as described
in the README. It will be located above the pre-relocation stack on
supported architectures.
Note that this implementation is only useful on machines which have some
memory available before dram_init() is called - this includes those that
do no DRAM init (like tegra) and those that do it in SPL (quite a few
boards). Enabling driver model preior to relocation for the rest of the
boards is left for a later exercise.
using UBI and DM together leads in compiler error, as
both define a "struct device", so rename "struct device"
in include/dm/device.h to "struct udevice", as we use
linux code (MTD/UBI/UBIFS some USB code,...) and cannot
change the linux "struct device"
gd->bd->bi_baudrate is a copy of gd->baudrate.
Since baudrate is a common feature for all architectures,
keep gd->baudrate only.
It is true that bi_baudrate was passed to the kernel in that structure
but it was a long time ago.
Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
This driver needs a data structure in SRAM before SDRAM is available.
This is not alway the case using .data section. Moving this data
structure to global_data guarantees it is writable.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
Enough time has passed since this board was moved to Orphan. Remove.
- Remove board/nx823/*
- Remove include/configs/NX823.h
- Clean-up ifdef(CONFIG_NX823)
- Move the entry from boards.cfg to doc/README.scrapyard
Before this commit, CONFIG_MPC8260 and CONFIG_8260
were used mixed-up.
All boards with mpc8260 cpu defined both of them:
- CONFIG_MPC8260 was defined in board config headers
and include/common.h
- CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk
We do not need to have both of them.
This commit keeps only CONFIG_MPC8260.
This commit does:
- Delete CONFIG_8260 and CONFIG_MPC8260 definition
in config headers and include/common.h
- Rename CONFIG_8260 to CONFIG_MPC8260
in arch/powerpc/cpu/mpc8260/config.mk.
- Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260
Add driver model support for GPIOs. Since existing GPIO drivers do not use
driver model, this feature must be enabled by CONFIG_DM_GPIO. After all
GPO drivers are converted over we can perhaps remove this config.
Tests are provided for the sandbox implementation, and are a sufficient
sanity check for basic operation.
The GPIO uclass understands the concept of named banks of GPIOs, with each
GPIO device providing a single bank. Within each bank the GPIOs are numbered
using an offset from 0 to n-1. For example a bank named 'b' with 20
offsets will provide GPIOs named b0 to b19.
Anonymous GPIO banks are also supported, and are just numbered without any
prefix.
Each time a GPIO driver is added to the uclass, the GPIOs are renumbered
accordinging, so there is always a global GPIO numbering order.
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com>
Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
Add driver model functionality for generic board.
This includes data structures and base code for registering devices and
uclasses (groups of devices with the same purpose, e.g. all I2C ports will
be in the same uclass).
The feature is enabled with CONFIG_DM.
Remove the last uses of symbol offsets in ARM U-Boot.
Remove some needless uses of _TEXT_BASE.
Remove all _TEXT_BASE definitions.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Many platforms duplicate pretty much the same timer code yet they all have
a 32-bit freerunning counter register. Create a common implementation that
minimally requires 2 or 3 defines to add timer support:
CONFIG_SYS_TIMER_RATE - Clock rate of the timer counter
CONFIG_SYS_TIMER_COUNTER - Address of 32-bit counter
CONFIG_SYS_TIMER_COUNTS_DOWN - Define if counter counts down
All functions are weak or ifdef'ed so they can still be overriden by any
platform.
This patch removes support for the APM 405CR CPU.
This CPU is EOL and no board uses this chip.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
This Patch introduce the new i2c_core file, which holds
the I2C core functions, for the rework of the multibus/
multiadapter support.
Also adds changes in i2c.h for the new I2C multibus/multiadapter
support. This new support can be activated with the
CONFIG_SYS_I2C define.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Add hooks for tracing to generic board, including:
- allow early tracing to start early as possible in U-Boot
- reserve memory for trace buffer
- copy early trace buffer to main trace buffer after relocation
- setup full tracing support after relocation
Discard all .dynsym sections from linker scripts
Remove all __dynsym_start definitions from linker scripts
Remove all __dynsym_start references from the codebase
Note: this touches include/asm-generic/sections.h, which
is not ARM-specific, but actual uses of __dynsym_start
are only in ARM, so this patch can safely go through
the ARM repository.
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
This commit refactors common/board_f.c and common/board_r.c
in order to delete the dest_addr and dest_addr_sp from
gd_t struct.
As mentioned as follows in include/asm-generic/global_data.h,
/* TODO: is this the same as relocaddr, or something else? */
unsigned long dest_addr; /* Post-relocation address of U-Boot */
dest_addr is the same as relocaddr.
Likewise, dest_addr_sp is the same as start_addr_sp.
It seemed dest_addr/dest_addr_sp was used only as a scratch variable
to calculate relocaddr/start_addr_sp, respectively.
With a little refactoring, we can delete dest_addr and dest_addr_sp.
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
Add generic board support for sandbox. and remove the old board init code.
Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported.
Reviewed-by: Tom Rini <trini@ti.com>
We decided to used unsigned int here, rather than unsigned long. But
for the generic global_data it is still unsigned long. So change it
over.
This file handles common pre-relocation init for boards which use
the generic framework.
It starts up the console, DRAM, performs relocation and then jumps
to post-relocation init.
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
We create a separate header file for link symbols defined by the link
scripts. It is helpful to have these all in one place and try to
make them common across architectures. Since Linux already has a similar
file, we bring this in even though many of the symbols there are not
relevant to us.
Each architecture has its own asm/sections.h where symbols specifc to
that architecture can be added. For now everything except AVR32 just
includes the generic header.
One change is needed in arch/avr32/lib/board.c to make this conversion
work.
Reviewed-by: Tom Rini <trini@ti.com> (version 5)
This file holds the board info structure. We need this to be generic
for the unified board series, so create a structure which contains
the basic fields required by the main architectures.
Add a generic global_data structure which all archs will eventually
use.
gpio_request() appears twice in asm-generic/gpio.h
Remove one of the definitions.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
This function should also be part of the GPIO API, so add it.
All the global flag defines are the same across all arches. So unify them
in one place, and add a simple way for arches to extend for their needs.
Change "int gp" to "unsigned gpio"
Add request and free entry-points
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Since we want want to have a standard GPIO interface, this adds a definition
for this into include/asm-generic/gpio.h.
Add support for newer (up to 2.6.33) kernels
Add zboot command which takes the address of a bzImage as its first
argument and (optionally) the size of the bzImage as the second argument
(the second argument is needed for older kernels which do not include
the bzImage size in the header)
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This is based on the asm-arm/unaligned.h, but made generic so all arches
that cannot do unaligned accesses can utilize it.
We need signal.h for Blackfin/KGDB, so import the asm-generic/signal.h
for people to leverage.
Signed-off-by: Robin Getz <robin.getz@analog.com>
This patch use blackfin errno.h implementation which
correspond Linux kernel one.
MIPS implemetation is different that's why I keep it.
I removed ppc_error_no.h from Marvell boards which
was the same too.
I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians.
