path: root/include/asm-generic
2014-01-24include: delete unused header filesMasahiro Yamada
2013-11-04Introduce common timer functionsRob Herring
Many platforms duplicate pretty much the same timer code yet they all have a 32-bit freerunning counter register. Create a common implementation that minimally requires 2 or 3 defines to add timer support: CONFIG_SYS_TIMER_RATE - Clock rate of the timer counter CONFIG_SYS_TIMER_COUNTER - Address of 32-bit counter CONFIG_SYS_TIMER_COUNTS_DOWN - Define if counter counts down All functions are weak or ifdef'ed so they can still be overriden by any platform. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c: add i2c_core and prepare for new multibus supportHeiko Schocher
This Patch introduce the new i2c_core file, which holds the I2C core functions, for the rework of the multibus/ multiadapter support. Also adds changes in i2c.h for the new I2C multibus/multiadapter support. This new support can be activated with the CONFIG_SYS_I2C define. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-26Add trace support to generic boardSimon Glass
Add hooks for tracing to generic board, including: - allow early tracing to start early as possible in U-Boot - reserve memory for trace buffer - copy early trace buffer to main trace buffer after relocation - setup full tracing support after relocation Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-07generic_board: reduce the redundancy of gd_t struct membersMasahiro Yamada
This commit refactors common/board_f.c and common/board_r.c in order to delete the dest_addr and dest_addr_sp from gd_t struct. As mentioned as follows in include/asm-generic/global_data.h, /* TODO: is this the same as relocaddr, or something else? */ unsigned long dest_addr; /* Post-relocation address of U-Boot */ dest_addr is the same as relocaddr. Likewise, dest_addr_sp is the same as start_addr_sp. It seemed dest_addr/dest_addr_sp was used only as a scratch variable to calculate relocaddr/start_addr_sp, respectively. With a little refactoring, we can delete dest_addr and dest_addr_sp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org>
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-05-01sandbox: Switch over to generic boardSimon Glass
Add generic board support for sandbox. and remove the old board init code. Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-15Use 'unsigned int' for global_data's baudrateSimon Glass
We decided to used unsigned int here, rather than unsigned long. But for the generic global_data it is still unsigned long. So change it over. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic pre-relocation board_f.cSimon Glass
This file handles common pre-relocation init for boards which use the generic framework. It starts up the console, DRAM, performs relocation and then jumps to post-relocation init. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Introduce generic u-boot.h fileSimon Glass
This file holds the board info structure. We need this to be generic for the unified board series, so create a structure which contains the basic fields required by the main architectures. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04Add generic global_dataSimon Glass
Add a generic global_data structure which all archs will eventually use. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11gpio: remove duplicate function signatureNikita Kiryanov
gpio_request() appears twice in asm-generic/gpio.h Remove one of the definitions. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2012-09-21Add gpio_request() to asm-generic headerSimon Glass
This function should also be part of the GPIO API, so add it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-01-09gpio: Modify common gpio.h to more closely match LinuxJoe Hershberger
Change "int gp" to "unsigned gpio" Add request and free entry-points Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-10-17Add generic gpio.h in asm-genericSimon Glass
Since we want want to have a standard GPIO interface, this adds a definition for this into include/asm-generic/gpio.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2010-05-06x86: Fix support for booting bzImageGraeme Russ
Add support for newer (up to 2.6.33) kernels Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2010-03-14asm-generic/unaligned.h: dynamic default unaligned accessesMike Frysinger
This is based on the asm-arm/unaligned.h, but made generic so all arches that cannot do unaligned accesses can utilize it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17asm-generic/signal.h: import from linuxRobin Getz
We need signal.h for Blackfin/KGDB, so import the asm-generic/signal.h for people to leverage. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
