path: root/include/asm-generic
2015-11-05include: Add generic bitops headersFabio Estevam
Use the generic bitops header files from the kernel. Imported from kernel 4.2.3. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-11-04dm: spl: Support device tree when BSS is in a different sectionSimon Glass
At present in SPL we place the device tree immediately after BSS. This avoids needing to copy it out of the way before BSS can be used. However on some boards BSS is not placed with the image - e.g. it can be in RAM if available. Add an option to tell U-Boot that the device tree should be placed at the end of the image binary (_image_binary_end) instead of at the end of BSS. Note: A common reason to place BSS in RAM is to support the FAT filesystem. We should update the code so that it does not use so much BSS. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-10-23dm: implement a Timer uclassThomas Chou
Implement a Timer uclass to work with lib/time.c. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21linux/bitops.h: GENMASK copy from linuxJagan Teki
GENMASK is used to create a contiguous bitmask([hi:lo]). This patch is a copy from Linux, with below commit details "bitops: Fix shift overflow in GENMASK macros" (sha1: 00b4d9a14125f1e51874def2b9de6092e007412d) Cc: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Signed-off-by: Jagan Teki <jteki@openedev.com>
2015-08-17Revert "Align global_data to a 16-byte boundary"Simon Glass
This causes widespread breakage due to the operation of the low-level code in crt0.S and cro0_64.S for ARM at least. The fix is not complicated but it seems safer to revert this for now. This reverts commit 2afddae07523f23f77acd066ad1719f53d289f98. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-14Align global_data to a 16-byte boundarySimon Glass
Some archs like to have larger alignment for their global data. Use 16 bytes which suits all current archs. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-14common: Display >=4GiB memory bank sizeBin Meng
bd->bi_dram[] has both start address and size defined as 32-bit, which is not the case on some platforms where >=4GiB memory bank is used. Change them to support such memory banks. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Add a way to skip relocationSimon Glass
When running U-Boot as an EFI application we cannot relocate since we do not have relocation information. U-Boot has already been relocated to a suitable address. Add a global_data flag to control skipping relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Reserve the top 16 flag bits for architecture-specific useSimon Glass
Add a convention that the generic global_data only occupy the bottom 16 bits of the flags word, so that there is less chance of a conflict. At present the x86 flags conflict. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-21dm: spl: Allow device tree/driver model in board_init_f()Simon Glass
Add an spl_init() function that does basic init such that board_init_f() can use simple malloc(), device tree and driver model. Each one is set up only if enabled for SPL. Note: We really should refactor SPL such that there is a single board_init_f() and rename the existing weak board_init_f() functions provided by boards, calling them from the single board_init_f(). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_request() to manually request a GPIOSimon Glass
This function can be used for testing to manually request a GPIO for use, without resorting to the legacy GPIO API. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: gpio: Add dm_gpio_lookup_name() to look up a GPIO nameSimon Glass
Provide a driver-model function to look up a GPIO name. Make the standard function use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-14dm: x86: baytrail: Correct PCI region 3 when driver model is usedSimon Glass
Commit afbbd413a fixed this for non-driver-model. Make sure that the driver model code handles this also. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-06-04gpio: fix typos in GPIO headerMasahiro Yamada
2015-05-14dm: gpio: Fix comment typo in GPIOD_IS_INSimon Glass
This should say 'in', not 'out'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-13dm: gpio: Add error handling and a function to claim vector GPIOsSimon Glass
gpio_get_values_as_int() should return an error if something goes wrong. Also provide gpio_claim_vector(), a function to request the GPIOs and set them to input mode. Otherwise callers have to do this themselves. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-05m68k: Add generic board support for MCF547X/8X and MCF5445XAlison Wang
This patch adds generic board support for MCF547X/8X and MCF5445X. It is based on the patch about common generic board support for M68K architecture sent by Angelo. Signed-off-by: Alison Wang <alison.wang@freescale.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-02-17avr32: add generic board supportAndreas Bießmann
2015-02-04Merge branch 'master' of git://git.denx.de/u-boot-ubiTom Rini
2015-01-29Export redesignMartin Dorwig
this is an atempt to make the export of functions typesafe. I replaced the jumptable void ** by a struct (jt_funcs) with function pointers. The EXPORT_FUNC macro now has 3 fixed parameters and one variadic parameter The first is the name of the exported function, the rest of the parameters are used to format a functionpointer in the jumptable, the EXPORT_FUNC macros are expanded three times, 1. to declare the members of the struct 2. to initialize the structmember pointers 3. to call the functions in stubs.c Signed-off-by: Martin Dorwig <dorwig@tetronik.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (resending to the list since my tweaks are not quite trivial)
2015-01-29dm: gpio: Mark the old GPIO API deprecatedSimon Glass
Add a deprecation notice to each function so that it is more obvious that we are moving GPIOs to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add better functions to request GPIOsSimon Glass
At present U-Boot sort-of supports the standard way of reading GPIOs from device tree nodes, but the support is incomplete, a bit clunky and only works for GPIO bindings where #gpio-cells is 2. Add new functions to request GPIOs, taking full account of the device tree binding. These permit requesting a GPIO with a simple call like: gpio_request_by_name(dev, "cd-gpios", 0, &desc, GPIOD_IS_IN); This will request the GPIO, looking at the device's node which might be this, for example: cd-gpios = <&gpio TEGRA_GPIO(B, 3) GPIO_ACTIVE_LOW>; The GPIO will be set to input mode in this case and polarity will be honoured by the GPIO calls. It is also possible to request and free a list of GPIOs. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add a driver GPIO translation methodSimon Glass
Only the GPIO driver knows about the full GPIO device tree binding used by a device. Add a method to allow the driver to provide this information to the uclass, including the GPIO offset within the device and flags such as the polarity. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29dm: gpio: Add a native driver model APISimon Glass
So far driver model's GPIO uclass just implements the existing GPIO API. This has some limitations: - it requires manual device tree munging to support GPIOs in device tree (fdtdec_get_gpio() and friends) - it does not understand polarity - it is somewhat slower since we must scan for the GPIO device each time - Global GPIO numbering can change if other GPIO drivers are probed - it requires extra steps to set the GPIO direction and value The new functions have a dm_ prefix where necessary to avoid name conflicts but we can remove that when it is no-longer needed. The new struct gpio_desc holds all required information about the GPIO. For now this is intended to be stored by the client requesting the GPIO, but in future it might be brought into the uclass in some way. With these changes the old GPIO API still works, and uses the driver model API underneath. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-28ubifs: Import atomic_long operations from LinuxAnton Habegger
This commit is a preperation for a subsequent UBIFS commit which needs atomic_long operations. Therefor "include/asm-generic/atomic-long.h" is imported from 1860e37 Linux 3.15 Signed-off-by: Anton Habegger <anton.habegger@gmail.com>
2015-01-12pci: Make pci apis usable before relocationBin Meng
Introduce a gd->hose to save the pci hose in the early phase so that apis in drivers/pci/pci.c can be used before relocation. Architecture codes need assign a valid gd->hose in the early phase. Some variables are declared as static so change them to be either stack variable or global data member so that they can be used before relocation, except the 'indent' used by CONFIG_PCI_SCAN_SHOW which just affects some print format. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21dm: Split the simple malloc() implementation into its own fileSimon Glass
The simple malloc() implementation is used when memory is tight. It provides a simple buffer with an incrementing pointer. At present the implementation is inside dlmalloc. Move it into its own file so that it is easier to find. Rather than using relocation as a signal that the full malloc() is available, add a special GD_FLG_FULL_MALLOC_INIT flag. This signals that the simple malloc() should no longer be used. In some cases, such as SPL, even the code space used by the full malloc() is wasteful. Add a CONFIG_SYS_MALLOC_SIMPLE option to provide only the simple malloc. In this case the full malloc is not available at all. It saves about 1KB of code space and about 0.5KB of data on Thumb 2. Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: gpio: Add a function to read an ID from a list of GPIOsSimon Glass
For board IDs a common approach is to set aside several GPIOs for use in determining the board ID. This can provide information about board features and the revision. Add a function that turns a list of GPIOs into an integer by assigning each GPIO to a single bit. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: serial: Move current serial port pointer to global_dataSimon Glass
In general we can't store things in the data section until we have inited SDRAM. Some platforms allow this (e.g. those with SPL) but some don't. Move the pointer to global_data so that it will work on all platforms. Without this fix the serial port will not work prior to relocation with driver model on some platforms. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-27ppc: Zap Hymod boardMarek Vasut
Remove this board as this is the only one last user of eeprom_probe(), which is pretty non-standard stuff. This patch also removes all the PHP, SQL and CSS stuff from U-Boot, which probably makes U-Boot a bit less IoT ;-) Signed-off-by: Marek Vasut <marex@denx.de> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Heiko Schocher <hs@denx.de>
2014-10-26Merge git://git.denx.de/u-boot-dmTom Rini
Fix a trivial conflict over adding <dm.h> Conflicts: arch/arm/cpu/armv7/omap3/board.c Signed-off-by: Tom Rini <trini@ti.com>
2014-10-25gpio: add protype for name_to_gpioJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-23dm: gpio: Remove unused get_state() uclass methodSimon Glass
This is no longer used so drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Add gpio_requestf() helper for printf() stringsSimon Glass
Add a helper which permits a printf()-style format string for the requester string. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: Move the function for getting GPIO status into the uclassSimon Glass
This function can be more easily tested if it is in the uclass. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Add gpio_get_function() and friendsSimon Glass
Add helpers to the uclass to allow finding out the pin function. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-23dm: gpio: Implement GPIO reservation in the uclassSimon Glass
We have several GPIO drivers now and all are doing similar things to record which GPIOs are reserved. Move this logic into the uclass to make the drivers similar. We retain the request()/free() methods since currently one driver does use these for setting up the pin. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22gpio: header file comment spelling fixesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-08-31dm: gpio: Enhance gpio command to show only active GPIOsSimon Glass
The GPIO list is very long in many cases and most of them are not used. By default, show only the GPIOs that are in use, and provide a flag to show all of them. This makes the 'gpio status' command much more pleasant. In order to do this, driver model now exposes a method for obtaining the 'function' of a GPIO, which describes whether it is an input or output, for example. Implementation of this method is optional. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a flag indicating when the serial console is readySimon Glass
For sandbox we have a fallback console which is used very early in U-Boot, before serial drivers are available. Rather than try to guess when to switch to the real console, add a flag so we can be sure. This makes sure that sandbox can always output a panic() message, for example, and avoids silent failure (which is very annoying in sandbox). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23dm: Support driver model prior to relocationSimon Glass
Initialise devices marked 'pre-reloc' and make them available prior to relocation. Note that this requires pre-reloc malloc() to be available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-07-23Add a simple malloc() implementation for pre-relocationSimon Glass
If we are to have driver model before relocation we need to support some way of calling memory allocation routines. The standard malloc() is pretty complicated: 1. It uses some BSS memory for its state, and BSS is not available before relocation 2. It supports algorithms for reducing memory fragmentation and improving performace of free(). Before relocation we could happily just not support free(). 3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since this has been loaded anyway this is not really a problem. The simplest way to support pre-relocation malloc() is to reserve an area of memory and allocate it in increasing blocks as needed. This implementation does this. To enable it, you need to define the size of the malloc() pool as described in the README. It will be located above the pre-relocation stack on supported architectures. Note that this implementation is only useful on machines which have some memory available before dram_init() is called - this includes those that do no DRAM init (like tegra) and those that do it in SPL (quite a few boards). Enabling driver model preior to relocation for the rest of the boards is left for a later exercise. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-04-29driver/mxc_i2c: Move static data structure to global_dataYork Sun
This driver needs a data structure in SRAM before SDRAM is available. This is not alway the case using .data section. Moving this data structure to global_data guarantees it is writable. Signed-off-by: York Sun <yorksun@freescale.com> CC: Troy Kisky <troy.kisky@boundarydevices.com>
2014-04-18powerpc: remove NX823 board supportMasahiro Yamada
Enough time has passed since this board was moved to Orphan. Remove. - Remove board/nx823/* - Remove include/configs/NX823.h - Clean-up ifdef(CONFIG_NX823) - Move the entry from boards.cfg to doc/README.scrapyard Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-03-04dm: Add GPIO support and testsSimon Glass
Add driver model support for GPIOs. Since existing GPIO drivers do not use driver model, this feature must be enabled by CONFIG_DM_GPIO. After all GPO drivers are converted over we can perhaps remove this config. Tests are provided for the sandbox implementation, and are a sufficient sanity check for basic operation. The GPIO uclass understands the concept of named banks of GPIOs, with each GPIO device providing a single bank. Within each bank the GPIOs are numbered using an offset from 0 to n-1. For example a bank named 'b' with 20 offsets will provide GPIOs named b0 to b19. Anonymous GPIO banks are also supported, and are just numbered without any prefix. Each time a GPIO driver is added to the uclass, the GPIOs are renumbered accordinging, so there is always a global GPIO numbering order. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
