path: root/include/asm-arm
2008-08-31davinci: fix remaining dm644x_ethJean-Christophe PLAGNIOL-VILLARD
2008-08-31ARM: Add arm1176 core with S3C6400 SoCGuennadi Liakhovetski
Based on the original S3C64XX port by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-12at91: move arch-at91sam9 to arch-at91Jean-Christophe PLAGNIOL-VILLARD
2008-08-11i.MX31: Fix mx31_gpio_mux() function and MUX_-macros.Magnus Lilja
Correct the mx31_gpio_mux() function to allow changing all i.MX31 IOMUX contacts instead of only the first 256 ones as is the case prior to this patch. Add missing MUX_* macros and update board files to use the new macros. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-08-11i.MX31: Fix IOMUX related typosMagnus Lilja
Correct the names of some IOMUX macros. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-07-31at91rm9200dk, csb637: fix NAND related build problemsWolfgang Denk
Tried fixing NAND support for the at91rm9200dk board; untested. Disabled NAND support in the csb637 board config file. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-01Make setenv() return statusSteven A. Falco
Currently, the setenv function does not return an error code. This patch allows to test for errors. Signed-off-by: Steve Falco <sfalco@harris.com>
2008-06-28ARM: Add support for Lyrtech SFF-SDR board (ARM926EJS)Hugo Villeneuve
This patch adds support for the Lyrtech SFF-SDR board, based on the TI DaVinci architecture (ARM926EJS). Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Signed-off-by: Philip Balister <philip@balister.org> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-28MMC: Consolidate MMC/SD command definitionsHaavard Skinnemoen
This moves the MMC and SD Card command definitions from include/asm/arch/mmc.h into include/mmc.h. These definitions are given by the MMC and SD Card standards, not by any particular architecture. There's a lot more room for consolidation in the MMC drivers which I'm hoping to get done eventually, but this patch is a start. Compile-tested for all avr32 boards as well as lpc2292sodimm and lubbock. This should cover all three mmc drivers in the tree. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-03Move definition of container_of() to common.hHaavard Skinnemoen
AVR32 and AT91SAM9 both have their own identical definitions of container_of() taken from the Linux kernel. Move it to common.h so that all architectures can use it. container_of() is already used by some drivers, and will be used extensively by the new and improved SPI API. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-24Merging Stelian Pop AT91 patchesJean-Christophe PLAGNIOL-VILLARD
Merge branch 'testing-V2' Conflicts: board/atmel/at91cap9adk/Makefile Fixing copyright board/atmel/at91sam9260ek/Makefile Fixing copyright board/atmel/at91sam9260ek/u-boot.lds Delete no more needed ld script Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-21Merge branch 'lwmon5' of /home/wd/git/u-boot/projectsWolfgang Denk
2008-05-20POST: replace the LOGBUFF_INITIALIZED flag in gd->post_log_word (1 << 31) ↵Yuri Tikhonov
with the GD_FLG_LOGINIT flag in gd->flags. This way we become able to utilize the full post_log_word for POST activities (overwise, POST ECC, which has 0x8000 ID, could be erroneously treated as started in post_output_backlog() even if there was actually no POST ECC run (because of OCM POST failure, for example). Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-20POST: add POST_STOP flagYuri Tikhonov
Don't run futher tests in case of a test fails that is marked as POST_STOP. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-05-10Support AT91CAP9 revC CPUsStelian Pop
The AT91CAP9 revC CPU has a few differences over the previous, revB CPU which was distributed in small quantities only (revA was an internal Atmel product only). The revC silicon needs a special initialisation sequence to switch from the internal (imprecise) RC oscillator to the external 32k clock. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Add ATMEL LCD driverStelian Pop
This patch adds support for the ATMEL LCDC driver which is used on some AT91 and AVR platforms. Is has been tested with the AT91CAP9ADK, AT91SAM9261EK, AT91SAM9263EK and AT91SAM9RLEK boards. Adaptation for AVR32 should probably be easy. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9RLEK supportStelian Pop
This patch adds support for the AT91SAM9RL chip and the AT91SAM9RLEK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9263EK supportStelian Pop
This patch adds support for the AT91SAM9263 chip and the AT91SAM9263EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10AT91SAM9261EK supportStelian Pop
This patch adds support for the AT91SAM9261 chip and the AT91SAM9261EK board. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Update origin and copyright information in arch-at91sam9 header filesStelian Pop
When doing the AT91CAP9/AT91SAM9 port, a number of header files were copied from the Linux kernel sources. This patch explicitly specifies this origin for all the copied headers, and for those missing copyright information, adds it. Additionaly, the header file 'at91sam926x_mc.h' has been superceeded in the latest kernel sources by 'at91sam9_smc.h'. The copyright information has been confirmed by the AT91 Linux kernel maintainer, Andrew Victor <avictor.za@gmail.com>. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-10Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net>
2008-05-10mx31ads: fix 32kHz clock handlingGuennadi Liakhovetski
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value. Also fix a typo when verifying a jumper configuration. While at it, make two needlessly global functions static. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-05-08Fix @ -> <at> substitutionStelian Pop
When applying the AT91CAP9 patches upstream, something transformed the '@' character into the ' <at> ' sequence. The patch below restores the original form in all the places where it has been modified (the AT91CAP9 files, the AT91SAM9260 files which were copied from AT91CAP9, and a couple of other files where the ' <at> ' sequence was present). Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-05-04Fix misspelled commentMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-18Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-18New i.MX31 SPI driverGuennadi Liakhovetski
This is an SPI driver for i.MX and MXC based SoCs from Freescale. So far only implemented and tested on i.MX31, can with a modified register layout and definitions be used for i.MX27, I think, MXC CPUs have similar SPI controllers too. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Introduce phys_size_t and move phys_addr_t into asm/types.hKumar Gala
Also add CONFIG_PHYS_64BIT on powerpc to deal with 32-bit ppc's that have larger physical addresses like 44x, 85xx, and 86xx. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-13core support for Freescale mx31Sascha Hauer
This patch adds the core support for Freescale mx31 Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Separate omap24xx specific code from arm1136Sascha Hauer
Move omap24xx code to cpu/arm1136/omap24xx, rename include/asm-arm/arch-arm1136 to cpu/arm1136/omap24xx. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Finish header files reworkingStelian Pop
Replace AT91CAP9.h file with several splitted header files coming from the Linux kernel. This is part 2 of the replacement: more header imports and edits. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Import several header files from LinuxStelian Pop
Replace AT91CAP9.h file with several splitted header files coming from the Linux kernel. This is part 1 of the replacement: pristine header files import. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Move at91cap9 specific files to at91sam9 directoryStelian Pop
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a common infrastructure can be used. Let this infrastructure be named after the AT91SAM9 family, and move the existing AT91CAP9 files to the new place. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
2008-03-30core support for Freescale mx31Sascha Hauer
2008-03-30Separate omap24xx specific code from arm1136Sascha Hauer
2008-03-30Removes all board specific code from the arch. part for DM644x (DaVinci) boardsPieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-18The patch introduces the CRITICAL feature of POST tests. If the test marked ↵Yuri Tikhonov
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode. Signed-off-by: Dmitry Rakhchev <rda@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-03-02arm-imx: Fix register definitionsJean-Christophe PLAGNIOL-VILLARD
Sync register definitions with linux Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-02-23Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit ↵Shinya Kuribayashi
targets. ---------------------------------------------------------------- Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)] Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> ---------------------------------------------------------------- Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-02-14AT91CAP9 support : include/ filesStelian Pop
2008-02-03MMC for PXA 27X (resubmit)stefano babic
MMC support for X_Scale PXA is broken and does not work. Mainly, the mmc_init() function cannot recognize current SD/MMC cards. There were already some patches around the world but none of them was merged into the official u-boot tree. This patch makes order fixing this issue. Resubmit after code cleanup. Applied and tested on PXA 270 (TrizepsIV module). Signed-off-by: Stefano Babic <sbabic@denx.de>
2008-02-03Fix gcc issues in pxa-regs.hstefano babic
Fix gcc4 issue. With some toolchain, a previous patch that fixes gcc4 issues generates wrong code. (Problem was reported with gcc-4.0.2-glibc-2.3.6/arm-softfloat-linux-gnu). This patch fixes the problem and solves the gcc-4 issues as the linux kernel does. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Dmitry Ivanov <ivadmitry@gmail.com>
2008-01-18Add AcTux board supportMichael Schwingen
Hi, The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the files that contain changes for multiple boards, the board-specific files follow as separate patches. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-13ARM: update mach-types.h from 2.6.24-rc7 Linux kernel treeWolfgang Denk
