This patch adds the support to read and write mac id from i2c
memory.
For reading:
if (env contains ethaddr)
pick env ethaddr
else
pick ethaddr from i2c memory
For writing:
chip_config ethaddr XX:XX:XX:XX:XX:XX writes the mac id
in i2c memory
Signed-off-by: Vipin <vipin.kumar@st.com>
SPEAr600 SoC support contains basic spear600 support along with the
usage of following drivers
- serial driver(UART)
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr SoCs contain an FSMC controller which can be used to interface
with a range of memories eg. NAND, SRAM, NOR.
Currently, this driver supports interfacing FSMC with NAND memories
SPEAr SoCs contain a serial memory interface controller. This
controller is used to interface with spi based memories.
This patch adds the driver for this IP.
SPEAr SoCs contain a synopsys i2c controller.
SPEAr Architecture support added. It contains the support for
following SPEAr blocks
- Timer
- System controller
- Misc registers
Fetched from http://www.arm.linux.org.uk/developer/machines/download.php
And built with
repo http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
commit 2045124ffd1a5e46d157349016a2c50f19c8c91d
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
later
These are few files directly imported from Linux kernel source.
Those are not modifyed at all ar per strategy.
These files contains source with GPLv2 only
whereas u-boot expects GPLv2 or latter
These files are updated for the same from prior permission from original writes
Acked-by: Nicolas Pitre <nico@marvell.com>
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Because of v7_flush_dcache_all is moved to omap3/cache.S
and s5pc110 needs cache routines, update s5pc1xx cache routines.
l2_cache_enable and l2_caceh_disable are moved from cache.c to cache.S
and invalidate_dcache is modified for SoC specific.
The MSB of DMC1_MEM_CFG can be set to '1' for separate CKE control
for S3C6400. In the configuration of SMDK6400, however, two 16-bit
mDDR (SAMSUNG K4X51163) chips are used in parallel to form 32-bit
memory bus and there is no need to control CKE for each chip
separately. AFAIK, CKE1 is not at all connected. Only CKE0 is
used. Futhermore, it should be '0' always for S3C6410. When tested
with a board which has a S3C6410 and the same memory configuration,
a side effect is observed that u-boot command "reset" doesn't work
leading to system hang. Leaving the bit clear is safe in most cases.
Signed-off-by: Seunghyeon Rhee <seunghyeon@lpmtec.com>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
Added DA8xx GPIO base addresses in gpio_defs.h and pointers
to different BANKs which can be used to program GPIOs.
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
Signed-off-by: Swaminathan S <swami.iyer@ti.com>
And built with
commit c9f937e4a3f4ebf9924ec21d80632e5eb61d949c
Davinci: NAND enable ECC even when not in NAND boot mode
On Davinci platforms, the default NAND device is enabled (for ECC)
in low level boot code when NAND boot mode is used. If booting in
another mode, NAND ECC is not enabled. The driver should make
sure ECC is enabled regardless of boot mode if NAND is configured
in U-Boot.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Davinci: Configurable NAND chip selects
Add a CONFIG_SYS_NAND_CS setting to all davinci configs and
use it to setup the NAND controller in the davinci_nand
mtd driver.
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
And built with
commit 3fcca9ac6cbce35b3e81e247d375534117d5f4cd
This patch adds support for A320 evaluation board from Faraday. This board
uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM.
FA526 is an ARMv4 processor and uses the ARM920T source in this patch.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Defaults are for Infineon DDR timings.
Since none of the supported boards currently do
XIP boot, these seem to be faulty. fix the values
as per the calculations(ACTIMA,B), conf
the sdrc power with pwdnen and wakeupproc bits
Signed-off-by: Nishanth Menon <nm@ti.com>
Micron DDR timings based on:
http://www.sakoman.net/cgi-bin/gitweb.cgi?p=x-load-omap3.git;a=blob;f=include/asm/arch-omap3/mem.h;h=e6fbfe3947f5d0d85fea776e30821d4017316d86;hb=HEAD
Introduce Micron DDR timings and provide
CONFIG_OMAP3_INFINEON_DDR and CONFIG_OMAP3_MICRON_DDR config
options to allow for platform files to setup their timings as
per the type of DDR selected
Reported-by: Steve Sakoman in http://www.nabble.com/forum/Permalink.jtp?root=25779518&post=25959734&page=y
Remove SDP referenced unused defines
Provides initial support for TI OMAP-L1x/DA8xx SoC devices.
See http://www.ti.com
The DA8xx devices are similar to DaVinci devices but have a differing
memory map and updated peripheral versions.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
This patch adds a unified s3c24x0 cpu header file that selects the header
file for the specific s3c24x0 cpu from the SOC and CPU configs defined in
board config file. This removes the current chain of s3c24-type #ifdef's
from the s3c24x0 code.
Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk>
Cleans up the s3c24x0 header files:
s4c24x0.h: removes the use of 'volatile' from the S3C24X0_REG8,
S3C24X0_REG16 and S3C24X0_REG32 register typedef's. Registers are always
accessed using the IO accessor functions which cast the register address
as 'volatile' anyway so it isn't required here.
s3c2400.h and s3c2410.h: insert a blank line between the static inline
functions
This patch moves the s3c64xx header files from include/
to include/asm-arm/arch-s3c64xx
This patch moves the s3c24x0 header files from include/ to
include/asm-arm/arch-s3c24x0/.
checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due
to a non-UTF8 character in David M?ller's name:
ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8
#489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3:
+ * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch
As David's name correctly contains a non-UTF8 character I haven't fixed
these errors.
The 3 warnings were all because of the use of 'volatile' in s3c24x0.h:
WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt
#673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35:
+typedef volatile u8 S3C24X0_REG8;
+typedef volatile u16 S3C24X0_REG16;
+typedef volatile u32 S3C24X0_REG32;
I'll fix these errors in another patch.
Tested by running MAKEALL for ARM8 targets and ensuring there were no new
errors or warnings.
And built with
commit 156171c71a0dc4bce12b4408bb1591f8fe32dc1a
From http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
Commit id 0996391139f43d032335b5360db11da62a2cbb39
Add support to use second and third I2C bus, too.
Bus 0 is still the default, but by calling i2c_set_bus_num(1/2) before doing
I2C accesses, code can switch to bus 1 and 2, too. Don't forget to switch
back afterwards, then.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
The asm-arm/unaligned.h includes linux/unaligned/access_ok.h
This file is unsafe to be used on ARM, since it does an unaligned memory
accesses which fails on ARM.
Lookin at Linux the basic difference seems to be the header
"include/asm-arm/unaligned.h". The Linux version of "unaligned.h"
does *not* include "access_ok.h" at all. It includes "le_byteshift.h"
and "be_byteshift.h" instead.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
include/asm-arm/unaligned.h | 3 -
include/linux/unaligned/be_byteshift.h | 70 +++++++++++++++++++++++++++++++++
include/linux/unaligned/le_byteshift.h | 70 +++++++++++++++++++++++++++++++++
3 files changed, 142 insertions(+), 1 deletion(-)
create mode 100644 include/linux/unaligned/be_byteshift.h
create mode 100644 include/linux/unaligned/le_byteshift.h
fix the following compile warnings
warning: dereferencing type-punned pointer will break strict-aliasing rules
Due to new TI boards being added to U-Boot, the hardware.h
is getting very messy. The warning being fixed is due to
the EMIF addresses being redefined.
The long term solution(after 2009.11) to this is to
have SOC specific header files.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
gpmc_config should not be a variant as it is board specific
hence make it a const parameter
Fixes issues identified by Dirk:
- build issue for zoom2
- warnings for all other OMAP3 platforms using nand/onenand etc
Export enable_gpmc_cs_config into common header to
prevent warning:
warning: implicit declaration of function 'enable_gpmc_cs_config'
This patch adds support for the Samsung s5pc100 and s5pc110
SoCs. The s5pc1xx SoC is an ARM Cortex A8 processor.
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
Some DaVinci SOC's use GPIOs to enable EMAC and DM9000.
This patch adds some definitions for GPIO registers and also adds
structures for GPIO.
A separate header file is being added so that in future we
can have a DaVinci GPIO driver similer to OMAP.
Acked-by: Tom Rix <Tom.Rix@windriver.com>
In the DaVinci specific code, we use both CONFIG_SOC_DM646X and
CONFIG_SOC_DM646x to represent DM646x specific code.
This patch changes occurrences of CONFIG_SOC_DM646x to
CONFIG_SOC_DM646X. This is because for DM644x series of SOCs we use
the flag CONFIG_SOC_DM644X. We want some uniformity.
Fix warning
Dereferencing type-punned pointer will break strict-aliasing rules
CC: Steve Sakoman <sakoman@gmail.com>
DM646x is an SOC from TI which has both an ARM and a DSP.
There are multiple variants of the SOC mainly dealing with different
core speeds.
This patch adds the initial framework for the DM646x SOC.
v7_flush_dcache_all, because it depends on omap ROM code is not
generic. Rename the function to 'invalidate_dcache' and move it
to the omap cpu directory.
Collect the other omap cache routines l2_cache_enable and
l2_cache_disable with invalide_dcache into cache.S. This
means removing the old cache.c file that contained l2_cache_enable
and l2_cache_disable.
The conversion from cache.c to cache.S was done most through
disassembling the uboot binary. The only significant change was
to change the comparision for the return of get_cpu_rev from
cmp r0, #0
beq earlier_than_label
Which was lost information to
cmp r0, #CPU_3XX_ES20
blt earlier_than_label
The paths through the enable routine were verified by
adding an infinite loop and seeing the hang. Then
removing the infinite loop and seeing it continue.
The disable routine is similar enough that it was not
tested with this method.
Run tested by cold booting from nand on beagle and zoom1.
Compile tested on MAKEALL arm.
These architectures don't need relocation fixups, so reduce their
codesize a bit by defining CONFIG_RELOC_FIXUP_WORKS.
Also remove the reloc_off field from their global data structures
as it is no longer needed.
Note that the location of the standalone application jump table pointer
in the global data structure is affected by this change, breaking
execution of standalone applications compiled for previous versions of
U-Boot. We will therefore increment XF_VERSION in the next commit,
which also touches this area.
Commits
02f99901ed1c9d828e3ea117f94ce2264bf8389e
52d61227b66d4099b39c8309ab37cb67ee09a405
introduced a regression where platform-specific ffs/fls implementations
were defined away. This patch corrects that by using PLATFORM_xxx
instead of the name itself.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Needed for (e.g.) ubifs support to work.
Bring over the bitop implementations from the Linux
include/asm-generic/bitops/non-atomic.h to provide
endianness-independence.
__set_bit and __clear_bit are defined in ubifs.h as well as in
asm/include/bitops.h for some architectures. This patch moves
the generic implementation to include/linux/bitops.h and uses
that unless it's defined by the architecture.
This feature can be used to trigger special command "sysrstcmd" using
reset key long press event and environment variable "sysrstdelay" is set
(useful for reset to factory or manufacturing mode execution)
Kirkwood SoC implements a hardware-based SYSRSTn duration counter.
When SYSRSTn is asserted low, a SYSRSTn duration counter is running.
The counter value is stored in the SYSRSTn Length Counter Register
The counter is based on the 25-MHz reference clock (40ns)
It is a 29-bit counter, yielding a maximum counting duration of
2^29/25 MHz (21.4 seconds). When the counter reach its maximum value,
it remains at this value until counter reset is triggered by setting
bit 31 of KW_REG_SYSRST_CNT
Implementation:
Upon long reset assertion (> ${sysrstdelay} in secs) sysrstcmd will be
executed if pre-defined in environment variables.
This feature will be disabled if "sysrstdelay" variable is unset.
for-ex.
setenv sysrst_cmd "echo starting factory reset;
nand erase 0xa0000 0x20000;
echo finish ed sysrst command;"
will erase particular nand sector if triggered by this event
This patch adds support for i.MX27-LITEKIT development board from
LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND
flash, FEC ethernet controller integrated into i.MX27.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Acked-by: Wolfgang Denk <wd@denx.de>
