path: root/include/asm-arm/setup.h
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
