Added new CONFIG_DISABLE_CONSOLE define and GD_FLG_DISABLE_CONSOLE.
When CONFIG_DISABLE_CONSOLE is defined, setting
GD_FLG_DISABLE_CONSOLE disables all console input and output.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Currently, both are defined as an unsigned long, but
should be phys_size_t. This should result in no real change,
since phys_size_t is currently an unsigned long for all the
default configs. Also add print_lnum to cmd_bdinfo to deal
with the potentially wider memsize.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
with the GD_FLG_LOGINIT flag in gd->flags.
This way we become able to utilize the full post_log_word for POST
activities (overwise, POST ECC, which has 0x8000 ID, could be
erroneously treated as started in post_output_backlog() even if there
was actually no POST ECC run (because of OCM POST failure, for
example).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Don't run futher tests in case of a test fails that is marked as
POST_STOP.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
as POST_CRITICAL fails then the alternative, post_critical, boot-command is used. If this command is not defined then U-Boot enters into interactive mode.
Signed-off-by: Dmitry Rakhchev <rda@emcraft.com>
other platforms (see c75eba3b4140187cd0d9bd8049f5df4c49b6889b)
* lots of bugfixes in the assembler code
* reverted hardware.h back to original
* enabled hardware DRAM calibration
* GCC-4 fix: modified GLOBAL_DATA_POINTER macro
for more information
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100
boards, version 153 for Rev. 200 boards).
* Patch by Vladimir Gurevich, 12 Mar 2003:
Fix relocation problem of statically initialized string pointers
in common/cmd_pci.c
* Patch by Kai-Uwe Blöm, 12 Mar 2003:
Cleanup & bug fixes for JFFS2 code:
- the memory mangement was broken. It caused havoc on malloc by
writing beyond the block boundaries.
- the length calculation for files was wrong, sometimes resulting
in short file reads.
- data copying now optionally takes fragment version numbers into
account, to avoid copying from older data.
See doc/README.JFFS2 for details.
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
* Start adding MIPS support files
