path: root/include/asm-arm/arch-pxa
2006-03-24delta board: DA9030 initialization and i2c support. Some minor changes toMarkus Klotzbuecher
make the pxa i2c driver work with the monahans cpu.
2006-03-20Cleanup of the monahans cpu and delta board port.Markus Klotzbuecher
2006-03-06Merge with /home/wd/git/u-boot/masterWolfgang Denk
Code cleanup.
2006-03-06Cleanup of NAND support of delta board using the Monahans Data FlashMarkus Klotzbücher
Controller.
2006-03-01Further NAND stuff implemented. Basic read commands seem to work.Markus Klotzbücher
2006-02-28First steps implementing NAND support. Not working, fails to read ID.Markus Klotzbücher
2006-02-22SDRAM seems to be working on delta board, though u-boot doesn't start yet.Markus Klotzbücher
2006-02-20New board directory and config for the benq delta board (copied fromMarkus Klotzbücher
zylonite). Minor pxa-regs.h update.
2006-02-20Merged and added more pxa-regs.h stuff, especially the GPIO ControlMarkus Klotzbücher
Register Definitions.
2006-02-19Merged sufficient changes to pxa-regs.h in order to make u-boot compile.Markus Klotzbücher
It doesn't run yet.
2006-02-10Reverting pxa-regs.h back to original, because the intel Monahans oneMarkus Klotzbücher
breaks backward compatibility and I don't trust it. Instead, i'll verify and merge the parts I need while porting.
2006-02-08Changes:Markus Klotzbücher
* lots of bugfixes in the assembler code * reverted hardware.h back to original * enabled hardware DRAM calibration * GCC-4 fix: modified GLOBAL_DATA_POINTER macro
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2005-04-06* Patches by Robert Whaley, 29 Nov 2004:wdenk
- update the pxa-regs.h file for PXA27x chips - add PXA27x based ADSVIX board - add support for MMC on PXA27x processors * Patch by Andrew E. Mileski, 28 Nov 2004: Fix PPC4xx SPD SDRAM detection bug * Patch by Hiroshi Ito, 26 Nov 2004: Fix logic of "test -z" and "test -n" commands
2005-01-09Patches by David Snowdon, 07 Sep 2004:wdenk
- add u-boot.hex target in the top level Makefile - add support for the UNSW/NICTA PLEB 2 board (pleb2) - use -mtune=xscale and -march=armv5 options for PXA
2003-12-07* Patch by Andre Schwarz, 24 Nov 2003:wdenk
add support for mvblue (mvBlueLYNX and mvBlueBOX) boards * Patch by Pavel Bartusek, 21 Nov 2003: set ZMII bridge speed on 440 * Patch by Anders Larsen, 17 Nov 2003: Fix mismatched #ifdef / #endif in include/asm-arm/arch-pxa/hardware.h
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-05-23Patch by Kyle Harris, 20 May 2003:LABEL_2003_05_23_1450wdenk
In preparation for an ixp port, rename cpu/xscale and arch-xscale into cpu/pxa and arch-pxa.
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
